If there is no force being applied can there still be a net force?
annamal
387
33
If there is no force being applied can there still be a net force? For example, supposed you apply a force F forward on an object on a frictionless plane, the moment you stop applying the force, the object may still be accelerating towards its final velocity but there is no applied force. So if there is no force being applied, there can still be a net force?
If so, that would be confusing for all the physics word problems.
  • Skeptical
Likes PeroK
Why?
weirdoguy said:
Why?
Can you clarify? What do you mean?
Why object may still be accelerating without the force?
Mr Newton says "No force, no acceleration". Basic laws of motion.
Likes vanhees71
It takes time for the object to finish accelerating from the original force
  • Wow
Likes PeroK
Doesn't it take time for the object to finish accelerating from the original force? So if you push an object, it will stop accelerating the moment you stop pushing it?
Are you trying to apply your ideas to a particular situation and finding it's not making sense? Start off assuming that Newton 1 will always apply. If something actually appears to accelerate after the applied force then there could be some change of shape so that, although the centre of mass is no longer accelerating, the surface may appear to be still accelerating a bit until its equilibrium shape is reached. (e.g. a balloon with a mass suspended in its centre by rubber bands)
Likes Frabjous
It will stop accelerating when the force is zero.
In practice, it takes a finite time for a force to be removed during which the force decreases with corresponding lower accelerations.
In practice, objects deform when pushed. Nothing happens instantly - there are always masses and elasticity at work.
Likes Frabjous
It's hard to imagine where you got this idea.
Likes sophiecentaur
"Momentum of acceleration?"
"Take your foot off the gas at fifty, 'and the momentum of acceleration will take you right on up to sixty,'" from an idiot to my dad back in the sixties.
  • Haha
Likes sophiecentaur and PeroK
I know you didn't mean it this way but I feel it's important to clarify the OP is not an idiot for asking the question or for surmising his answer.
Others have pointed out edge case scenarios (forces do not reduce to zero instantly, objects deform, etc.) but the short answer is the moment no force is applied, it will stop accelerating, yes.
Likes berkeman
Yeah, in high school I was talking with a hunting buddy who insisted that the bullet didn't get up to speed until it was way out of the barrel... I had the same thought about him that your dad did about his friend... o0)
Likes Bystander
Indeed Aristotle was not stupid and his intuition was really (and yet understandibly) incorrect.
Newton's first law is actually quite obscure, as there are almost no clear examples of it. Things do naturally tend to lose speed. It was a great insight that this is entirely due to dissipative forces; and, that in the absence of such forces uniform motion would continue indefinitely.
I've never heard of the idea that things keep speeding up even after the impulse has ceased. "The momentum of acceleration" seems a somewhat bizarre concept.
Likes hutchphd
The heavenly bodies are hardly subjected to dissipative forces. I'm sure that's where Newton got the idea.
Those were subject to the laws of heaven and kept moving by the hand of god. Newton's Principia also established the idea of universal laws of physics: not one law for Earth and another for the heavens. This idea may not have originated with Newton, but the first law required that insight as well.
It is genuinely hard to construct your own experiment to demonstrate the first law.
Intuition can lead to all sorts of 'wrong' ideas. There was a very reasonable theory, based on observation, that "Everything" slows down (+"eventually", not actually stated). It's common (was universal) terrestrial experience, even with low friction clock mechanisms.
It was much easier to deny that Physics would apply everywhere and that God was turning the handle up there.
To be fair, it took a lot of arguing the subject out, at a very high level, to arrive at a consistent model that includes Force, Mass, Momentum and Kinetic Energy. It can take a lot of self discipline sometimes to approach a new situation, using the 'right' terms to describe and predict what happens.
Likes Bystander
