If Uranium's half life is 4.5 billion years, why does it become waste
In summary, the conversation discusses the topic of nuclear energy and the disposal of radioactive waste. The main question is why uranium, with a half-life of 4.5 billion years, becomes waste at a reactor before it decays 4.5 billion years later. The conversation explores the concept of nuclear reactors and how they use enriched uranium to produce energy through fission. However, this process also creates radioactive waste, which is composed of fission products that are highly radioactive. The conversation also touches on the potential for reprocessing nuclear waste to reduce its volume.
AHUGEMUSHROOM
Okay, If Uranium's half life is 4.5 billion years, why does it become waste at a reactor before it decays 4.5 billion years later...
Forgive me if my question is badly worded or really stupid; I am a high-school student who has just finished the topic of "Nuclear Energy" in my physics class (I REALLY ENJOYED IT) and I've become very interested in the area and I want to know a lot about it :)
P.S. I am also sorry if I've posted in the wrong sub-forum :/
In a reactor it's made to deliberately split (not decay, but similar end result) so we can gather the energy of the splitting and use it.
In nature it becomes radioactive waste too, just a lot slower. The waste eventually decays into stable compounds making fission a clean, green, and fully renewable energy source over time.
This is off. It is not clean as radioactive waste needs thousands of years to decay, and it is not renewable, as stable isotopes that are at the end of the decay chain can't be reused. Whether it is green depends on how you define green - if everything works OK and if we will finally decide where to safely store radioactive waste, then yes, it will be green. Unfortunately, as for now there is no decision on where to build the safe depository.
They can't be reused in a reactor but they can be used to make cars and vacuum cleaners, just like recycled glass and plastic.
(yes, it takes a very long time; my point is that radioactivity in that LONG run is greener than say styrofoam which is probably more stable and less beneficial in the wild.)
With each iteration you are sinking deeper. Fission products - after separation and waiting till they decay - will be more expensive than gold. And styrofoam decays in the wild in years, perhaps tens of years, while some isotopes will be still dangerous even after many thousands of years. No matter how you will try, your original post can't be defended.
Radioactive waste is a regulatory term, not a scientific term. If we could find a use for it, it wouldn't really be waste. One man's DU waste is another man's shielding.
Why will they become so expensive where they are just waste?
I will defend my post to the death! Small amounts of radiation are good for you. They stimulate the immune system and hasten evolution through accelerated mutation. I'll bet your weak styrofoam can make no such claims. So there!
In nature, Uranium is 0.7% U-235 and 99.3% U-238. Nuclear reactor fuel is "enriched" in U-235 so that it is about 3-4% U-235 and 96-97% U-238. The U-235 has a half-life of 705 million years to U-238's 4.5 billion. However, the reason we are interested in the U-235 is because it is "fissile" - which means it fissions or splits when hit by even slow moving neutrons.
When U-235 fissions, it releases a great deal of energy - and it's the energy that we want. The splitting or fissioning of U-235 releases more neutrons, and we can keep the reaction going as a "chain reaction".
However, when a U-235 splits, the remnants of the U-235 nucleus after splitting are elements such as Strontium-90 or Cesium-135, or Iodine-131... Those are the things that are radioactive, and are of concern in the waste.
However, you are correct in wondering in the sense that 96% of what we call "nuclear waste" is U-238 that is no more radioactive than the day it was dug out of the ground. If we could "reprocess" the waste - chemically separate the U-238 from those highly radioactive "fission products", we could reduce the volume of nuclear waste by a factor of 25.
Dr. Gregory Greenman
I think in context of a realistic situation, the majority of the radioactive waste is not reusable for society. I say that because I don't see 10,000+ years down the road as a realistic time frame for this discussion.
So a reactors waste isn't exactly "waster" (i.e. used up), it's just radioactive isotopes such as Strontium-90 or Cesium-135, or Iodine-131.
Lets put it this way. IF we had the time to wait until all of these isotopes decayed into stable elements, we could use them. Unfortunately this process takes thousands of years before they are safe to use.
Ohhhhhhhh, so are you saying that we let's say "tire them out" and the only way to be able to use them again is when they aren't tired anymore, which is thousands of years from now.
Welcome to the hottest forum on the internet of late (pun intended)
As was explained, most of the spent fuel is not waste, in the sense of something useless. The waste part is the radioactive elements created from Uranium, through fission. Plutonium is one of the most serious concerns, as it is both waste, and more valuable than gold. By the end of a nuclear cycle, the fuel is creating 40% of the heat from the Plutonium that was created from Uranium.
You might ask, if there is all that heat from Plutonium, why not keep using the fuel? Why reload fresh fuel if the fuel is still hot?
That is a very good question, but not directly part of the answer.
Same for the question, "Why not use the spent fuel rods to generate heat?". Why is it waste if it still has all that power available?
Or, "Why not use the plutonium to run a reactor?"
Why is considered waste if it's valuable? Or useful?
I'm asking all those questions! :P
So... Can I have answers?
Nope. When uranium decays, there is no more uranium.
Look up Nuclear Fission here: http://en.wikipedia.org/wiki/Nuclear_fission
Go through that article and bounce over to the Nuclear Power one along with any other ones you need to go through to get a basic understanding of the process.
I think the point is not that anyone wants to use the cesium and other daughter products in the spent fuel. What is desired, is the plutonium, which is mixed in with everything else. While a thousand years from now many of the non valuable elements will be much less dangerous, the plutonium and other highly radioactive products will still be quite hot, and a valuable commodity.
This is one major issue for "storing" spent fuel. 10,000 years from now the plutonium will still be desired. Plutonium is always worth something. Even just the ton or so produced each year by a reactor is worth a lot. So the concerns over secure storage are very valid.
How is this relevant? Waste is waste. Even if we wanted to use it we couldn't because it is not safe. Whether we will or will not want to use later it is a different story.
Actually, there is interest in the rare Earth's produced. However, the complication is one of extracting (economically as well as technically) the inert (non-radioactive) isotopes from the radioactive isotopes.
Pu from LWRs has several isotopes from Pu-237 to Pu-242, and there are isotopes of Am and Cm as well. Some of these are more useful for fuel than others, but it is a matter of fabricating fuel economically for operating in commercial reactors.
As for the OP - please see
http://hyperphysics.phy-astr.gsu.edu/Hbase/nuclear/radser.html
http://hyperphysics.phy-astr.gsu.edu/Hbase/nuclear/radact.html
http://hyperphysics.phy-astr.gsu.edu/Hbase/nucene/fission.html
Some of the answers involve money, politics and war, so this would be the wrong place to discuss them.
100% WRONG again.
The Plutonium in the waste can be used as reactor FUEL. It's not "unsafe" to use the Plutonium as reactor fuel. After all, about 40% of the energy that you get from a reactor comes from Plutonium that is created and burned in situ.
Obviously, it is called waste, because it has been used. Yet, it the term itself is subjective. We can have this debate for many other things. Some say in the future human will end up mining landfills for materials.
Nearly all, if not all, plastics can be recycled, yet most recycling only do Plastics #1 and #2 and not #3-#7. Some places support other types, but rare. It is a matter of economics.
But for spent fuel (or nuclear waste), we do not have to wait for it to be useful. Actually, I would think if you store spent fuel without reprocessing, then you are creating a proliferation issue, because the shorter lived radionuclide will decay leaving Uranium and Pu-239 pretty much.
As others have said, U-235 and Pu-239, and some isotopes of transuranics can be used as fuel. Other transuranics isotopes are "burned" up. U-238 can be used to breed Pu-239. This requires reprocessing and various reactor technologies.
Some radionuclides like I-131 has uses, but in practice are produced more efficiently using other methods. Again, I-131 has medical uses like treating hyperthroidism and thyroid cancer and is made with the neutron irradiation of Te-130 (http://www.nordion.com/documents/products/I-131_Solu_Can.pdf ).
Important nucildes from nuclear fission that can be used are:
Xe-133 for vascular and lung imaging; (http://www.sciencedirect.com/science/article/pii/S0001299880800080)
Sr-90 has some uses in industry and medicine. Some are wanting to make beta-voltaic batteries with Sr-90 (http://www.hps.org/publicinformation/ate/q219.html ).
Cs-137 can be used in food irradiation. However, it is not as popular as Co-90, because it is water soluble--from being an alkaline metal and not radioactivity. (http://earth1.epa.gov/radiation/docs/source-management/csfinallongtakeshi.pdf).
These are the ones I can think off the top of my head.
Speaking of billions, millions, and tens of thousands of years, if reprocessing is done, then we can shorten the duration waste remains radioactive. Advanced reprocessing and fast reactors can pretty much eliminate most of the long lived stuff. This would put less restrictions on geological disposal. As we are now a few thousand to several hundreds of years.
So it takes 4.5 billion years for Uranium to decay [naturally], but the reactors where they are used speeds up the time in which it takes for Uranium to decay. ?
Morbius said:
100% WRONG again.
Again? Sorry what was I wrong about in the first place? Why don't you try asking what I mean before jumping to conclusions. Anyways, while the radioactive isotopes can be used again as a source of heat, I was attempting to keep it simple for the OP. We don't use all those other decay products in the same way we do their non-radioactive isotopes because they are not safe to use. AKA the Iodine, Cesium, and ETC.
If you have a block of Uranium, in 4.5 billion years approximately half of that block will have decayed. Hence the term "Half-Life". In another 4.5 billion years half of what is left will have decayed.
A fission reactor doesn't rely on the natural decay to provide the heat it needs, it uses a controlled chain reaction. This doesn't speed up the natural decay as that is a completely different process. See the following links for more info.
http://en.wikipedia.org/wiki/Nuclear_reactor
http://en.wikipedia.org/wiki/Radioactive_decay
So waste Uranium isn't decayed Uranium?
Have you actually read any of the pages you were linked to? Because your questions clearly shows that you have still no idea what it is all about, which suggests we are all wasting our time trying to help you.
Okay to be brutally honest I only scanned them. I have exams coming up and I am studying 24/7, I will do my best to get around to reading them.
Sorry.
If so, please concentrate on your exams and come back later - it will help you now, and it will ease the discussion later. Win win situation.
  • #31
If you say that radioactive 'waste' is not waste because it has some use and will eventually decay to something harmless that is like saying that Dioxins will eventually break down in the environment and be harmless and that the red hot coal I picked up in my hand just then is harmless because it will, eventually cool down. Both of the above are bad news and so is (what we call) radioactive waste. Does the word we use make any difference to this?
  • #32
Waste is a subjective term. If I put my soda cans in the trash and it goes to a landfill, then it is pretty much waste even though it can be recycled.
A talented chemist can extract/recover many things from waste and what not. Problem is how expensive it is. Some things are a matter of technology as one poster said, but it applies to everything not just nuclear waste.
Computers have noble metals in them, but its hard to extract so you don't see many places buying them up to get the material. I bet you can actually get more gold by going out to old mines and pan for it than trying to get some from a modern computer.
Problem with nuclear waste is how and where to store it--it is a pretty big debate. However, up 95%, give or take a few percent, is still uranium. This would reduce the amount of waste that needs to be stored. It will also remove some of the longer lived isotopes. With advanced fast reactors, we could "burn up| some the minor actinides. This can lessen the geological requirements needed for storing the waste.
At the OP, decayed Uranium would actually be a different element. It is just called waste because they put it in a reactor and where it was used and removed.
  • #33
I think, in the context of Spent Nuclear Fuel we could substitute the term 'Waste' with 'sodding nuisance' or 'open-ended liability' to be nearer the mark.
  • #34
I always wondered why one could not use DU for weight plates in lifting. I would think there would actually be a market for them. There are plenty lifters always trying to pack as much weight as possible on barbells. In Olympic lifting they put thick rubber coatings to make them safer. For DU, that would cover them so you do not have to handle the DU itself--I am thinking about its chemical toxicity as radiologically its activity is quite low. As for Radon build up, I would think a properly ventilated room could eliminate that. It would be the perfect prank for those accustomed cast iron plates.
  • #35
I don't think the need is great enough to use Depleted Uranium. Plus then you'd have to look at health risks, even if it is low.
  • Nuclear Engineering
  • Astronomy and Astrophysics
