If vector A=10i+49j, and vector B=vector A/2, then does vector
  • Thread starter k8e591
  • Tags
    Vector
In summary, when vector A is divided by 2, vector B will have half the value of each component of A. Similarly, when vector A is multiplied by a number, the resulting vector will have each component of A multiplied by that number.
k8e591
If vector A=10i+49j, and vector B=vector A/2, then does vector B=1/2(10i+49j)?
Yep. So how would you write out vector B then?
Welcome to the PF.
would it be 5i+24.5j?
Yes. The main point here is that when it is written that e.g. B = A/2, it means that each component of the vector B is half the value of the corresponding component of A. The same thing goes for multiplication by a number, e.g. C = 2*A. In that case you would have C = 20i + 98j.
Yes, vector B would equal 1/2(10i+49j) because dividing a vector by a scalar simply scales the magnitude of the original vector by the scalar value. In this case, since vector B is equal to half of vector A, its magnitude will also be half of vector A's magnitude. Therefore, the components of vector B will also be half of vector A's components, resulting in vector B=1/2(10i+49j).
FAQ: If vector A=10i+49j, and vector B=vector A/2, then does vector
What is the magnitude of vector B?
The magnitude of vector B can be calculated using the formula: |B| = √(Bx² + By²), where Bx and By are the components of vector B. In this case, the magnitude of vector B is approximately 24.5.
What is the direction of vector B?
The direction of vector B can be determined by finding the angle it makes with the positive x-axis. In this case, the direction of vector B is approximately 78.7 degrees from the positive x-axis.
How does vector B compare to vector A in terms of magnitude?
Vector B is half the magnitude of vector A. This is because vector B is calculated by dividing vector A by 2, which means that the magnitude of vector B is half of the magnitude of vector A.
Is vector B parallel to vector A?
Yes, vector B is parallel to vector A. This is because both vectors have the same direction (78.7 degrees from the positive x-axis) and their magnitudes are directly proportional (B = A/2).
Can vector B be written in terms of unit vectors?
Yes, vector B can be written in terms of unit vectors. The unit vector in the direction of vector B can be calculated by dividing vector B by its magnitude. So, vector B can be written as B = 0.408i + 0.917j.
16K
