If water is covalent, why is hydrogen H+ ?
In summary, water is a covalent compound with a polar H-O bond. Under certain conditions, such as dipole interactions, the bond can ionize to form H+ and OH-. While hydrogen typically wants to gain an electron, in the case of water, it loses an electron to oxygen, making it positively charged. This is due to oxygen's higher electronegativity. Pure water is primarily covalent and neutral, with free hydrogen ions being rare. In comparison, molten ionic compounds and strong acids and bases can easily form ions in solution.
hasankamal007
42
Water is covalent compound. But formation of water is written as:
H+ + OH- = H2O
I cannot understand why hydrogen is electrically positive in the above equation. Hydrogen wants one more electron to complete its first and last shell (total two valence electrons). Hence, hydrogen should be negative since it attains an extra electron.
So, then, why is it positive?
Please explain also.
Thanks a lot!
Chemistry news on Phys.org
Water is covalent and it is H2O, but the nature of H-O covalent bond is polar, thus, under the influence of external factors, like dipole interaction with other water molecules, one of the H-O bonds ionizes to form H+ and OH-.
Hydrogen you seek is positive because it's lone electron is taken by Oxygen, therefore H+ is positive and oxygen is negative in OH-.
Also, a hydrogen ion (H+) is positive when it loses an electron. You're talking about it gaining an electron to complete its "octet", but that would be noted as H-.
At rest, a single hydrogen has a single electron associated with it though. Atoms like to be neutral, rather than ionized in any fashion. You can either pull an electron away from that proton, or add another electron to it, in order to ionize the atom. Keep in mind that doing either takes energy, which has to come from somewhere.
You'll end up learning later on that pure water (which is actually fairly rare) doesn't just sit there all happy. There's this thing called entropy, which causes some of the water molecules at the surface to want to find something else to play with. More importantly though, there's energy in there keeping water from crystallizing as a solid, and some of that energy will cause miniscule amounts of water to form hydroxide and hydronium.
I'm guessing that you're learning about electrolysis right now, though. Just understand that if you throw a bunch of unassociated electrons at things (like elemental hydrogen and oxygen), then you're not talking about hydrogen and oxygen in their "normal" states. You're throwing energy at them, so they're going to do something "unusual".
Hydrogen is less electronegative than oxygen. So, hydrogen wants to attract an electron to get a pair; oxygen wants to attract an electron to get an octet; oxygen is better at attracting and therefore succeeds in getting its octet, so hydrogen loses its electron.
For comparison, if you react hydrogen with lithium, which is less electronegative than hydrogen, then hydrogen succeeds in getting its electron pair and lithium loses electron, forming lithium hydride.
Since water is "covalent", free hydrogen ions are actually rare in water. Heat movement does break a few O-H bonds, normally forming H+ and OH-; but this rarely happens. Most water molecules are covalent and neutral, and pure water (distilled and also degassed) is a bad conductor of electricity. Its pH is +7, not -1,75 which it should be if water were not covalent.
If you mix a strong acid with a strong base, the reaction
H+ + OH-=H2O
does happen. But it goes mainly to the right - large amount of heat is released by forming the covalent bonds, and only very few of these bonds are broken by heat.
If you melt ionic lithium hydride (at temperature 688 Celsius) then the melt is ionic, not covalent like water, and molten salts are much better conductors of electricity than clean water. Also, if you electrolyze molten hydrides, then hydrogen goes to anode, while it goes to cathode during electrolysis of water.
I understand your confusion and I am happy to provide an explanation. First, it is important to understand that the formation of water is actually a result of the combination of two chemical reactions: the ionization of water and the formation of a covalent bond between hydrogen and oxygen.
In the first reaction, water molecules dissociate into ions, with a small percentage of water molecules ionizing into H+ and OH- ions. This process is known as the ionization of water and it is the reason why water can conduct electricity.
In the second reaction, the H+ and OH- ions combine to form a covalent bond, creating the stable water molecule (H2O). This happens because the positively charged hydrogen ion (H+) is attracted to the negatively charged oxygen ion (OH-). The covalent bond is formed when the hydrogen atom shares its single electron with the oxygen atom, completing both their outer electron shells.
So, although hydrogen may have a tendency to gain an extra electron, in the context of water formation, it actually loses its single electron to form the positively charged H+ ion. This is because the overall energy state of the system is more stable when the ions combine to form the covalent bond.
I hope this explanation helps to clarify why hydrogen is positive in the equation for water formation. It is important to remember that in chemistry, the behavior of elements and compounds can vary depending on the specific reaction or environment they are in.
FAQ: If water is covalent, why is hydrogen H+ ?
1. If water is covalent, why is hydrogen H+ ?
Water is indeed a covalent molecule, meaning that the two hydrogen atoms and one oxygen atom share electrons to form bonds. However, in certain conditions, such as in an acidic solution, one of the hydrogen atoms may dissociate and become a positively charged ion, known as a hydrogen ion or H+. This occurs because the hydrogen atom only has one electron, making it easier for it to lose that electron and become positively charged.
2. Is H+ considered an acid?
Yes, H+ is considered an acid because it can donate a proton (H+) to another molecule or ion. This proton donation is the defining characteristic of acids.
3. How does H+ affect the pH of a solution?
H+ ions play a crucial role in determining the pH of a solution. When added to a solution, H+ ions combine with water molecules to form hydronium ions (H3O+). The concentration of hydronium ions in a solution directly affects its pH, with a higher concentration of H+ ions resulting in a lower pH (more acidic) and a lower concentration resulting in a higher pH (more basic).
4. Can H+ ions exist on their own in a solution?
No, H+ ions cannot exist independently in a solution because they are highly reactive and will quickly bond with other molecules to form hydronium ions. In some cases, H+ ions may also combine with water molecules to form H3O+ ions.
5. How does the formation of H+ ions affect the properties of water?
The formation of H+ ions in water can significantly alter its properties, such as its pH and ability to conduct electricity. This is because the presence of H+ ions changes the concentration of hydronium ions and shifts the balance of positively and negatively charged particles in the solution. This can also affect the ability of water to dissolve certain substances and participate in chemical reactions.
