If we were to absorb all the incident light falling upon us
In summary: Actually, various animals use different methods of maintaining body temperature. Humans use sweat, breath, clothing and shade (and, in modern times Air Conditioning ;-) ) to maintain body temperature. Humans have a higher body temperature because they use a lot of different methods to keep it cool.
LogicalAcid
137
We would most likely grow in temperature greatly correct? I know this sounds to basic but the answer would help me very much.
Because if our body absorbs all of the visible spectrum except the part it reflects, why don't we grow very high in temperature?
Science news on Phys.org
We lose heat mostly via convection and evaporation so it balances out.
I know, but then why does metal get much hotter left out than we do? I have a feeling its cause since it reflects so much of the incident radiation coming of it, we feel it through that.
There is slightly over 1kW of energy in 1m^2 of direct sunlight. If your mass is 100kg, and 80% of your body is water, it follows that you have 80 liters of water. 1kWh of heat energy will raise 80 liters of water ~10.75C. Depending on the ambient air temperature and relative humidity this heat may be lost or gained.
For instance if we have an 80 liter black bucket of water in direct sunlight: if it is -10C it will likely freeze solid even with the 1kWh heat input. If the air temp is 35C it may heat up to a few degrees above ambient if their is no wind. In general it is the ambient air temperature that affects changes in water temperature. This has a lot more to do with the properties of water and air than heat input by sunlight.
Water has a fairly high specific heat capacity, ~4.2J/gC while iron has a fairly low specific heat capacity ~0.44J/gC. This means that while 4.2 Joules of energy will only raise a gram of water 1C, the same 4.2 Joules will raise 1 gram of iron nearly 10C. In addition to this, iron is generally dark in color, meaning it absorbs more energy from sunlight than water which is a combination of reflective and translucent.
Hope that answers your question!
Fish
A perfectly absorbing object placed outside, exposed to direct sunlight would absorb about 1 kW/m^2 of power, and would also emit 1 kW/m^2 of power. A blackbody emits this amount of power when it's temperature is about 360K, with a peak emission at about 8 microns.
So, absent any convective/conductive heat loss to the atmosphere, the object would heat up until it reached 360K (about 87 degrees C/ 188 degrees F), and then be in thermal equilibrium with solar radiation.
The light landing on your body is mostly turned into heat. But your body automatically does things to keep the same temperataure. If your skin is warm, blood will come to your skin and be cooled more than if your skin were cold. If it were cold, the blood vessels would contract, and stop your blood from being cooled.
Metal does not regulate its temperature the way your body does. Metal seems hotter or colder than you expect because it can hold a lot of heat. If you have a block of steel and a block of wood (both the same color, so they absorb the same amount of heat from the light), then both will be at the same temperature after a while, but if you touch the metal it will seem warmer than the wood. Thats because your fingers will cool down the wood much faster than the metal, and it will feel cooler. Your fingers don't tell you the temperature of what they TOUCH, they tell you what temperature they ARE. The metal will heat your fingers up much faster than the wood, and it will feel hotter.
FAQ: If we were to absorb all the incident light falling upon us
What does it mean to absorb all the incident light falling upon us?
Absorbing light means to take in and retain the energy from the light waves that are incident, or falling, upon a surface. This process is what allows us to see objects and colors.
Is it possible to absorb all the incident light?
No, it is not possible to absorb all the incident light. Some light will always be reflected or scattered, and not all surfaces are capable of absorbing 100% of the light that falls upon them.
What factors affect the amount of light that can be absorbed?
The material and texture of the surface, the angle and intensity of the incident light, and the color of the surface all play a role in how much light can be absorbed. Darker and rougher surfaces tend to absorb more light compared to lighter and smoother surfaces.
How does light absorption relate to color?
The color of an object is determined by the wavelengths of light that it reflects or transmits. Objects that absorb all wavelengths of visible light appear black, while objects that reflect all wavelengths appear white. The color we perceive is the result of which wavelengths are absorbed and which are reflected.
Can absorbing all the incident light have any negative effects?
Yes, absorbing too much light can potentially lead to overheating or damage to the absorbing material. This is why certain surfaces, such as solar panels, are designed to reflect or transmit some of the incident light to prevent this issue.
