If you halve the radius of a planet what happens to the volume/mass/density ?
In summary, changing the radius of a planet will have a significant impact on its mass and gravitational pull. Doubling the radius will increase the mass and gravitational pull eight-fold, while halving the radius will decrease them by a quarter. However, these effects are not mutually exclusive and can vary depending on the specific circumstances. It is important to distinguish between the radius of the planet itself and an object's distance from the planet. Using Newton's equation of gravitation, we can see that the mass and radius of a planet are directly related to its gravitational pull.
Yehia11
If you halve the radius of a planet.. what happens to the volume/mass/density ??
Okay so g on Earth is about 9.8
I know that Mass = Density X Volume... so if you double the radius you quarter the "g" ?
What if you double the density and halve the radius.. can you please show me clearly using Newtons equation of gravitation what happens to "g" ?
Help is very appreciated! Thanks in advance!
Is this homework? You need to show your attempts at solutions.
Note: for clarity, it will be important to distinguish between your uses of "radius".
Changing the radius of the planet will have a dramatically different result than changing the radius of (an) object's distance from the planet.
Doubling the radius of the planet itself will increase its mass (and therefore its gravitational pull) eight-fold.
Conversely, doubling the radius of an object('s distance) from the planet will quarter the gravitational pull.
And these two are not mutually exclusive. Simply standing on a planet with a doubled radius involves both of the above, so the net effect is (1/4 of 8 =) 2x gravity.
no this isn't homework... its studying for a test. I ended up with the right answer in the exam today anyways. your answer didnt help me much, but thanks for the input anyway.
Okay sure, let's call the mass of the Earth [tex] M_{e} [/tex] and mass [tex] R_{e} [/tex]
We can write the mass of the Earth interms of it's density as you rightly said (density*volume, assuming the Earth is spherical);
[tex] M_{e} = \rho \frac{4}{3} \pi R_{e} ^3 [/tex]
Note this is ONLY for the surface of the planet
[tex] g_{e} = \frac{\rho \frac{4}{3} \pi R_{e} ^3 G}{R_{e} ^2} = \rho \frac{4}{3} \pi R_{e} G [/tex]
Now you can make your conclusions from here
Same thing. (The key is that we can guide you but not tell you.)
FAQ: If you halve the radius of a planet what happens to the volume/mass/density ?
What happens to the volume of a planet if you halve its radius?
If you halve the radius of a planet, its volume will decrease by a factor of 8. This is because the volume of a sphere is proportional to the cube of its radius, so reducing the radius by half will result in a volume that is 1/2 x 1/2 x 1/2 = 1/8 the original volume.
Does halving the radius of a planet affect its mass?
Yes, halving the radius of a planet will also halve its mass. This is because mass is directly proportional to volume, and as stated in the previous answer, reducing the radius by half will result in a volume that is 1/8 the original volume, and therefore the mass will also be 1/8 the original mass.
How does halving the radius of a planet impact its density?
If you halve the radius of a planet, its density will increase by a factor of 8. This is because density is defined as the mass divided by the volume, and as stated in the first answer, the volume will decrease by a factor of 8 while the mass remains the same. Therefore, the density will increase by 8 times.
Will halving the radius of a planet affect its gravitational pull?
Yes, halving the radius of a planet will decrease its gravitational pull by a factor of 4. This is because gravitational pull is inversely proportional to the square of the distance between two objects. So, reducing the radius by half will result in a distance that is 1/2 x 1/2 = 1/4 the original distance, and therefore the gravitational pull will be 1/4 the original pull.
Is it possible to halve the radius of a planet?
No, it is not possible to physically halve the radius of a planet. This is because the radius of a planet is determined by its mass and density, and altering either of these factors would fundamentally change the nature of the planet. However, this question is often used as a hypothetical scenario to understand the relationship between radius, volume, mass, density, and gravitational pull of a planet.
