If you have a mixture, can you use a saturated liquid table?
In summary: , in summary, the saturated mixture tables can be used to calculate the mass and pressure of ammonia at a given temperature.
Bluestribute
194
I'm working on a problem and need to find quality, mass, and pressure. I'm given a temperature (2°C), a volume (1200m^3), and a percent volume occupation (1% saturated liquid). Is it "legal" to use the saturated liquid tables, at 2°C, to find the volume or pressure (I forget which one we were discussing) and THEN move on to the correct saturated mixture table?
Basically, given a temperature, volume, and percent volume, how would one find the quality and pressure. it's ammonia by the way, but that's not important right now. Figuring out how to find the right things is where we're at.
Are there saturated mixture tables for ammonia? There aren't any for water.
A saturated liquid implies that an equilibrium exists between the liquid phase and the vapor phase of a particular substance.
http://seitzman.gatech.edu/classes/ae3450/phases.pdf
You just answered a question I didn't realize I had. There's a Saturated Ammonia and superheated Ammonia table. So I can just interpolate my data points to fit the 2°C temperature? Essentially, since I know nothing about Ammonia, can I look up my information with JUST the temperature?
You're still confused.
Superheated vapor is just that: vapor. There's no liquid present because it's all been evaporated.
The saturation line for a given substance is the combination of temperature and pressure where 100% vapor exists. At any point below this line, there will be a mixture of vapor and liquid, until a point is reached when only the liquid phase exists.
If you look in the saturated liquid tables, you should find a listing of properties (specific volume, internal energy, enthalpy, entropy) for both the liquid and the vapor phases, because the saturated liquid can be a mixture of both phases. The properties of the mixture are determined by the quality of any vapor fraction present. A quality of 0% means you have only the liquid phase, and a quality of 100% means that only vapor is present. A quality figure in between 0% and 100% means that that proportion of vapor is present with the remainder being liquid.
In the link in Post #2, from p. 7 onward, the procedure to calculate the properties of the saturated mixture is explained using the tabulated properties for ammonia, water, whatever.
Sorry, it's the terminology that's different.
I've been using compressed liquid, saturated mixtures, and superheated vapour tables, but the ammonia only has a Saturated table and Superheated table. That was the problem =\ But I think we got the appropriate interpolation now!
Compressed liquid suggests there's no vapor present.
Superheated vapor suggests there's no liquid present.
That leaves ...
Likes gracy
For your purposes, the Saturated Table is the one to use. This table gives the pressure, temperature, and specific volumes of the liquid and vapor at equilibrium with one another. Knowing the total amount of ammonia present, the volume of the container, and the specific volumes of the liquid and vapor enables you to calculate the mass split between the liquid and the vapor.
Chet
Likes gracy
Related to If you have a mixture, can you use a saturated liquid table?
1. Can a saturated liquid table be used for mixtures?
Yes, a saturated liquid table can be used for mixtures. However, it is important to note that the data in a saturated liquid table is based on pure substances and may not accurately represent the properties of mixtures.
2. How do you use a saturated liquid table for mixtures?
To use a saturated liquid table for mixtures, you need to know the composition of the mixture, specifically the mass or mole fractions of each component. Then, you can use the tables to find the properties of the individual components and calculate the overall properties of the mixture.
3. What are the limitations of using a saturated liquid table for mixtures?
The main limitation is that the data in a saturated liquid table is based on pure substances and may not accurately represent the properties of mixtures. Additionally, the tables may not include data for all possible mixtures, making it difficult to find accurate values for mixtures with unique compositions.
4. Can a saturated liquid table accurately predict the properties of a mixture?
No, a saturated liquid table may not accurately predict the properties of a mixture. As mentioned before, the data in these tables is based on pure substances and may not accurately represent the properties of mixtures. It is always best to use experimental data or more advanced thermodynamic models for accurate predictions.
5. Are there any alternatives to using a saturated liquid table for mixtures?
Yes, there are alternative methods for finding the properties of mixtures, such as using experimental data or more advanced thermodynamic models. These methods may provide more accurate predictions for mixtures with complex compositions.
  • General Engineering
  • Materials and Chemical Engineering
