IGCSE Physics Boyle's law question
In summary, using the equation P1V1=P2V2, it is determined that the initial volume of helium in the cylinder is 0.15 m³. Assuming each balloon has a volume of 0.0030 m³, the number of balloons inflated would be 50. However, taking into account that the cylinder cannot be emptied completely and atmospheric pressure, the final answer is 48 balloons. The reason behind this is that the last balloon may not be fully inflated due to the available pressure in the cylinder being 2.64 x 10^6 Pa instead of the initial pressure of 2.75 x 10^6 Pa.
yohanes775
The helium in the cylinder has a volume of 6.0 × 10^–3 m3^-1 (0.0060 m^3) and is at a pressure of 2.75 × 10^6 Pa.
(i) The pressure of helium in each balloon is 1.1 × 10^5 Pa. The volume of helium in an inflated balloon is 3.0 × 10^–3 (0.0030 m3). The temperature of the helium does not change. Calculate the number of balloons that were inflated.
so basically using P1V1=P2V2 :
=> [1.1 x 10^5] [Vᵢ ] = [2.75 x 10^6] [6x10^(-3)]
=> Vᵢ = [2.75 x 10^6] [6x10^(-3)] / [1.1 x 10^5] m³
so Vᵢ = 15 x 10^(-2) m³ or 0.15 m³
# of balloons = 15 x 10^(-2) m³ / vol. of 1 balloon = 15 x 10^(-2) m³ / [3 x 10^(-3)] m³
which should be 50 balloons
HOWEVER the answer is 48 balloons as one has to assume the cylinder doesn't fully empty and still holds helium at [1.1 x 10^5] Pa hence [6x10^(-3)] volume equivalent to 2 balloons would still remain in the cylinder at the balloon pressure hence Ans: is 50 - 2 = 48 balloons
but how can you assume the cylinder is still at 1.1 x 10^5 pascals? Basically what's the logic behind the last step?
Thanks!
Take into account that normal atmospheric pressure at sea level is also about 1.1 x 10^5 Pa.
Hi,
The gas in the cylinder cannot be emptied to create vacuum. So, once the pressure inside the cylinder equals atmospheric pressure, it stops pushing gas to the balloon. Hence the last balloon may not be inflated to full. Considering this, the available pressure in the cylinder initially has to be initial cylinder pressure - atmospheric pressure which is
2.75 × 10^6 - 1.01 × 10^5 = 2.64 x 10^6 Pa.
Bimal
Related to IGCSE Physics Boyle's law question
1. What is Boyle's Law?
Boyle's Law is a gas law that describes the relationship between the volume and pressure of a gas at a constant temperature. It states that as the volume of a gas decreases, the pressure of the gas increases, and vice versa, as long as the temperature remains constant.
2. What is the mathematical equation for Boyle's Law?
The mathematical equation for Boyle's Law is P1V1 = P2V2, where P represents pressure and V represents volume.
3. How does Boyle's Law relate to real-life situations?
Boyle's Law can be observed in many everyday situations, such as using a bike pump. As you pump air into a tire, the volume of the air decreases, causing an increase in pressure, which eventually leads to the tire becoming inflated.
4. What units are used to measure pressure and volume in Boyle's Law?
Pressure is typically measured in units of pascals (Pa) or kilopascals (kPa), while volume is measured in units of cubic meters (m3) or cubic centimeters (cm3).
5. How is Boyle's Law used in the field of physics?
Boyle's Law is used in various fields of physics, such as in the study of thermodynamics and fluid mechanics. It is also an important concept in understanding the behavior of gases and their properties.
