Igma notation 2i-1 = 2n, for all n is an element of N
In summary, the given statement, n sigma notation 2i-1 = 2n, for all n is an element of N, is false. A counterexample is n = 1, where the left side is 1 but the right side is 2. The correct formula for the sum is \sum_{i=1}^{n} 2^{i - 1} = 2^n-1 and it can be proven using mathematical induction.
mbcsantin
prove or disprove
n
sigma notation 2i-1 = 2n, for all n is an element of N.
i=1
N = natural numbers
Rewritten using LaTeX,
[tex]\sum_{i=1}^{n} 2^{i - 1} = 2^n.[/tex]
Have you made any real attempt at this problem? Do you have a guess as to whether it's true or false? What I like to do on these types of "prove or disprove" questions is just plug in certain (small) values of n, and see if it works. If they all work, perhaps it really is true, and you should try to prove it; otherwise, it's false as you found a counterexample.
And once you find that it's false, can you guess a correct formula for the sum and prove that?
Here is my attempt at this problem:
n
sigma notation 2i-1= 2n, for all n is an element of N
i=1
n=1
sigma notation 21-1= 20 = 1 not equal to 21
i=1
n=1 is an element of N
Hence,
n
sigma notation 2i-1=2n doesn't hold for all n is an element of N
i=1
did i do this right?
Your solution is correct, although it's slightly unclear, and you should use more words to describe what you're doing.
You were trying to disprove
[tex]\sum_{i=1}^{n} 2^{i - 1} = 2^n \text{ for all } n \in \mathbb{N}.[/tex]
(It's much prettier in LaTeX; you should learn (at least by example) how to use it. [tex]n \in \mathbb{N}[/tex] is read "n in N" or even "natural numbers n" in this case. Click the images to see the code used to make them.) You put in n = 1 and showed that the two sides aren't equal; that is a counterexample, so your disproof is correct.
mbcsantin said:
prove or disprove
n
i=1
N = natural numbers
n
i=1
n=1
i=1
Hence,
n
i=1
Yes, you did! Now what is your answer to the question?
And you might like to look at
[tex]\sum_{i= 1}^n 2^{i-1}= 2^n- 1[/itex]
FAQ: Igma notation 2i-1 = 2n, for all n is an element of N
What is Igma notation?
Igma notation is a way of representing mathematical equations and expressions using symbols and letters, often used in the field of set theory.
What does 2i-1 = 2n mean in Igma notation?
In Igma notation, 2i-1 = 2n means that for any element n in the set of natural numbers (N), when the number 2 is raised to the power of i and then subtracted by 1, it will always be equal to 2 raised to the power of n.
How is Igma notation useful in mathematics?
Igma notation allows for a compact and concise representation of mathematical concepts and equations, making it easier for mathematicians to communicate and study complex ideas. It is particularly useful in the field of set theory, where it can represent infinite sets and their relationships.
What is the significance of using 2i-1 = 2n in Igma notation?
The equation 2i-1 = 2n is significant in Igma notation because it demonstrates the concept of equivalence in set theory. It states that two sets, one containing 2 raised to the power of i and the other containing 2 raised to the power of n, are equivalent or have the same cardinality.
Are there any limitations to Igma notation?
Like any notation system, Igma notation has its limitations. It may not be suitable for representing all types of mathematical concepts and equations, and it may not be easily understood by those unfamiliar with set theory. Additionally, as with any mathematical notation, it is important to use proper notation conventions and clearly define variables to avoid confusion or misinterpretation.
