IHave no idea how to solve any os these.
In summary, we have discussed various probability distributions and used them to solve problems involving collecting samples and determining sample means. We used the formulas for binomial and uniform distributions to calculate probabilities and expected values. We also discussed the concept of confidence intervals and how they can be used to estimate the population mean.
dediganss
  1. It is intended to collect samples from a Normal population with a standard deviation of 9. For a confidence level of 80%, determine the amplitude of the confidence interval for the population average in the case of a sample of size 81. Pick one:a. 1,28
b. 1,92
c. 1,44
d. 2,30
2) A sample of 16 observations independent of a Normal (2, 4) is collected. If Xb is the sample mean, determine the probability P [Xb> 1]. Pick one:a. 95,45%
b. 50,00%
c. 97,73%
d. 84,13%
3) A random variable has a uniform distribution in the set {-2, 2, 3}. For a random sample of size 2, the sample mean is Xb = (X1 + X2) / 2. Determine hope E [Xb]. Pick one:
a. 4/3
b. -2/3
c. -1/3
d. 1
4) A sample of 36 observations from a Normal (mu, 9) was collected and provided a sample mean of 8. Build a 95% Confidence Interval for the population mean. Pick one:
a. (7,28 ; 8,72)
b. (7,1775 ; 8,8225
c. (7,02 ; 8,98)
d. (7,36 ; 8,64)
5) A Bernoulli random variable has a probability of success p = 0.50. Considering random samples of size 3, the sample mean is given by Xb = (X1 + X2 + X3) / 3. Determine the probability P [Xb! = 2/3]. Pick one:
a. 7/8
b. 5/8
c. 3/8
d. 3/4
Mathematics news on Phys.org
I find this very troubling. Where did you get these problems? They look like pretty standard homework for an introductory Probability and Statistics class. Are you taking such a class? But then you say "I have no idea how to solve any of these". Why don't you? If you are taking a class in "probability and statistics ", you should have learned what a "normal distribution", "uniform distribution", and "Bernoulli distribution" are!
I will take a look at the easiest of these,
Saying this is a "uniform distribution" means that each possible outcome has the same probability. And those probabilities must sum to 1. So P(-2)= 1/3, P(2)=1/3, P(3)=1/3.
Since are 3 possible outcomes a "random sample of size 2" (without replacement?) has 3*2= 6 possible outcomes: (-2, 2), (-2, 3), (2, -2), (2, 3), (3, -2), and (3, 2). And since we have the uniform distribution, each pair has probability 1/6 of happening.
But it is not the pairs we are concerned with. It is Xb, the average of the sample pairs. Those are (-2+ 2)/2= 0, (-2+ 3)/2= 1/2, (2+ -2)/2= 0, (2+ 3)/2= 5/2, (3+ -2)/2= 1/2, and (3+ 2)/2= 5/2. Each number, 0, 1/2, and 5/2 occurs twice so each has probability 1/6+ 1/6= 1/3. The expected value is 0(1/3)+ (1/2)(1/3)+ (5/2)(1/3)= 1/6+ 5/6= 1.
Interestingly, if you assume "with replacement" you get the same answer!
With replacement, there are 3*3= 9 possible pairs, (-2, -2), (-2, 2) ,(-2, 3), (2, -2), (2, 2), (2, 3), (3, -2), (3, 2), and (3, 3) (those are the previous 6 pairs with the three new pairs, (-2, -2), (2, 2), and (3, 3)).
The average of each is
(-2+ -2)/2= -2
(-2+ 2)/2= 0
(-2+ 3)/2= 1/2
(2+ -2)/2= 0
(2+ 2)/2= 2
(2+ 3)/2= 5/2
(3+ -2)/2= 1/2
(3+ 2)/2= 5/2
(3+ 3)/2= 3
Again we have 0, 1/2, and 5/2 appearing twice each so each with probability 2/9 but now we also have -2, 2, and 3, each appearing once each so with probability 1/9 (and 2/9+ 2/9+ 2/9+ 1/9+ 1/9+ 1/9= 9/9= 1).
So the expected value is (0)(2/9)+ (1/2)(2/9)+ (5/2)(2/9)+ -2(1/9)+ 2(1/9)+ 3(1/9)=
4/18+ 2/18+ 10/18- 4/18+ 4/18+ 6/18= 22/18= 11/9.
But that is NOT one of the possible answer so apparently this intended "sampling without replacement".
The other "easy one" (i.e. not "normal distribution"!).
I take it that Xb! = 2/3 should have been Xb != 2/3- that Xb is NOT equal to 2/3.
A Bernoulli distribution (also called a "binomial distribution" has only two possible outcomes: 1 ("success") and 0 ("failure"). Here success has probability p= 1/2= 0.50 and failure has probability q= 1- p= 1- 1/2= 1/2= 0.5. In N trials, the probability of a "successes" and N- a "failures" is $\begin{pmatrix}N \\ a \end{pmatrix}p^aq^{N-a}$ where $\begin{pmatrix}N \\ a \end{pmatrix}$ is the "binomial coefficient" $\frac{N!}{a! (N-a)!}$.
Here, since there are 3 random variables, each with 2 possible outcomes there are $2^3= 8$ total outcomes:
(0, 0, 0), (0, 0, 1), (0, 1, 0), (0, 1, 1)
(1, 0, 0), (1, 0, 1), (1, 1, 0), (1, 1, 1)
(0, 0, 0) has probability $q^3= 1/8= 0.125$. It has average (0+ 0+ 0)/3= 0.
(0, 0, 1), (0, 1, 0), and (1, 0, 0) each have probability $pq^2$ which is also 1/8 since p and q are both 1/2. Each of these has average (1+ 0+ 0)/3= 1/3.
(0, 1, 1), (1, 0, 1), and (1, 1, 0) each have probability $p^2q$ which is also 1/8.
Each of those has average (1+ 1+ 0)/3= 2/3.
And (1, 1, 1) has probability $p^3= 1/8$.
It has average (1+ 1+ 1)/3= 1.
The question asked for the probability that the average of the sample was 2/3. That is precisely the three possible outcomes (0, 1, 1), (1, 0, 1), and (1, 1, 0) each or which had probability 1/8. Therefore the probability that "(X1+ X2+ X3)/3 is 2/3" is 3/8.
(More generally the probability that (X1+ X2+ X3)/3 is 0 is 1/8, the probability it is 1/3 is 3/8, the probability it is 2/3 is 3/8, and the probability it is 1 is 1/8. Those are the only possible outcomes and 1/8+ 3/8+ 3/8+ 1/8= 8/8= 1.)
FAQ: IHave no idea how to solve any os these.
How can I improve my problem-solving skills?
Improving problem-solving skills requires practice and developing a systematic approach. Start by breaking down the problem into smaller, more manageable parts. Then, gather information and analyze it to identify patterns or possible solutions. Finally, test your solutions and evaluate their effectiveness.
What are some common problem-solving strategies?
Some common problem-solving strategies include trial and error, brainstorming, using algorithms or formulas, and seeking outside help or resources. It's important to choose a strategy that best fits the problem at hand.
How can I stay motivated when facing a difficult problem?
Staying motivated can be challenging when facing a difficult problem. One way to stay motivated is to remind yourself of the potential rewards or benefits of solving the problem. You can also try taking breaks, seeking support from others, or finding creative ways to approach the problem.
How can I prevent feeling overwhelmed when solving a complex problem?
Complex problems can be overwhelming, but there are strategies to help manage this feeling. Start by breaking the problem into smaller, more manageable parts. This will help you focus on one aspect at a time. Additionally, try to stay organized and prioritize your steps to avoid feeling overwhelmed.
What should I do if I am stuck and can't solve a problem?
If you are stuck and can't solve a problem, take a step back and try to approach it from a different angle. You can also seek help from others, do more research, or take a break and come back to it with a fresh perspective. Remember to stay patient and persistent, as solving problems can take time and effort.
