Ii cant seem to figure this out
  • Thread starter Thread starter 1waystrpark
    Figure
When a meter stick travels at the speed of light relative to an observer, it does not appear to retain its original length due to the effects of relativistic length contraction. According to the principles of special relativity, as an object approaches the speed of light, its length contracts in the direction of motion, making it appear shorter to the observer. The question posed is a trick, as no object with mass can actually reach the speed of light. Therefore, the observer would not measure the meter stick as being one meter long. This discussion emphasizes the importance of understanding the implications of relativistic physics in such scenarios.
1waystrpark
IF a meter stick travels at the speed of light relative to an observer, how long does the meter stick appear to the observer? show you calculations.
Please show an attempt as per PF guidelines.
Jared
if speed of light is 299 792 458 m / s would the meter stick also seem this long?
I think this is an important point from a past thread:
DaveC426913 said:
Trick question. You should not *get* a reasonable answer. Why?
I've deliberately removed the post reference as I can't give you the full answer, but if you give it a shot I can help.
Note: Credit goes to DaveC and Co from the other thread for this answer.
Are you required to give a numerical answer? I see that "IF" is in capitals in the OP and so I'd assume they want a bit more than a blunt statement.
Jared
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
