- 5,779
- 172
Physicists’ community at Acesurf is divided. The two-dimensional beings live (as we would call it) on the surface of a diamond – and have themselves created from the carbon matrix. They consist of graphene.
Some of them now claim that they had found the ToE – a spectacular theory full of beauty and richness, including the structure of the substrate they live on, and being able to explain their own properties.
The physicist community is shocked when another discovery about "extra dimensions" makes the round; apparently they can reorganize themselves into sphere-like structures (60-S² branes, 70-S² branes, 72-S²-branes and others) referred to as Unreel Elf, embedded into higher-dimensional space – and leave their matrix! In addition, the theory also describes a further speculative substance, in which the Acesurfers become disordered, stacked R²-branes. These ideas are rejected by other scientists as science fiction or unphysical speculation. Instead one should look after the investigation of the Acesurfer structure itself.
It finally comes to a break, as a brilliant physicist Dusk Sins – in addition to the existence of an extra dimension necessary for the mathematical description of Acesurf – postulates further possible "worlds" not resembling Acesurf at all. He describes so-called bulk theories, according to which the Acesurfer would live only on the surface of a very special bulk theory. These surfaces are mathematically not consistent, only via the introduction of one extra dimension the bulk and, ultimately, the surfaces can be accurately described. Acesurf itself is ultimately only a holographic projection!
In addition, Dusk Sins postulates the existence of millions of different bulk-universes, most of them differing significantly from Acesurf and being strange or even hostile environments. Dusk Sins also introduces a theory of so-called phase transitions, indicating that the bulk matter could completely convert into other forms, ultimately disintegrating the entire bulk and bring the familiar environment to disappear.
The totality of all possible bulk theories and the holographic projections thereon (Acesurf being one of them) is referred to as Aced Plan. Dusk Sins and his colleagues are able to develop some approximate solutions according to which certain areas in the Aced Plan may have similar properties as known by Acesurf – but Acesurf itself cannot (yet) be described accurately!
The physicist community is outraged as a gigantic effort is required to map out the entire Aced Plan. Although it soon becomes clear that the effort is indeed infinite and the map of the Aced Plan is mathematically ill-defined, the probability to identify the area in the Aced Plan corresponding exactly to Acesurf is “compatible with zero”. Why now just living on Acesurf, and why this just looks the way it looks, is “answered” by Dusk Sins with the so-called Acesurf principle, what most scientists judge as subterfuge, or at least a tautology. The “science” of Dusk Sins may not be science at all, but religion or even mysticism.
In the end the group of Dusk Sins turns to the so-called Aced Plan Roaming, a method that enables them to create targeted areas in the Aced Plan from the Acesurf matrix itself and thus to actively roam through the Aced Plan. During the preparations of the first operation it comes to havoc (what some conservative scholars have warned long ago). The specially developed machine IDH (Illegal Danced Horror) created when booting a singularity, which transforms Acesurf and all the inhabitants via an eternal blow-up phase transition into atomic carbon ...
