MHB Im back with change subject of formula
  • Thread starter Thread starter fordy2707
    Change Formula
The discussion focuses on rearranging the formula for frequency, specifically how to make L the subject of the equation. The user initially makes a mistake in squaring the term 2π and misinterprets the rearrangement process. Correct steps involve applying basic operations consistently across the equation to isolate L. The final correct formula for L is derived as L = 1/((2π)²f²C). The user expresses satisfaction with the guidance received and plans to incorporate the advice into their learning.
fordy2707
so I've been taught basic rearranging of formula which I've found easy now I am given questions which are obviously a lot harder and I've entered the mind black hole if you could point me in the right direction with this where I go wrong
make L the subject
$f=\frac{1}{2\pi}$ $\sqrt{\frac{1}{LC}}$
=${f}^{2}=\frac{1}{{2\pi}^{2}}\frac{1}{LC}$
=${f}^{2}=\frac{1}{{2\pi}^{2}LC}$
above I may have already gone wrong but in my head its ok,but here on I am quite unsure if I am allowed to move the formula as I have
=${2\pi}^{2}C{f}^{2}=\frac{1}{L}$ ?? is that correct ?
then I am at a total loss as what to do with that fraction left over in my guess I am wanting make a new fraction and throw the 1 under the rest to make
L=$\frac{{2\pi}^{2}C{F}^{2}}{1}$ but this is just guess territory now as I've not been shown this type of question
Mathematics news on Phys.org
make L the subject
There are 2 mistakes ( one is because of latex)
There are
1) ${f}^{2}=\frac{1}{(2\pi)^{2}LC}$ you should put $2\pi$ in () and not in $\{\}$ because $2\pi$ should get squared
2) $L=\frac{1}{(2\pi)^{2}C{f}^{2}}$
I see, so i treated $2\pi$ as 1 value where its actually 2 different values to be multiplied together .
thanks for your help,im happy with how close I got.i will write your advice into my learning material and should be able to do a sum like that on my own next time
The "trick" is, when in doubt, to apply basic operations to the left and to the right of the equal sign.
That is, multiply left and right by the same expression:
$$f^2=\frac 1{(2\pi)^2LC} \\
\Rightarrow f^2 \cdot (2\pi)^2C =\frac 1{(2\pi)^2LC} \cdot (2\pi)^2C$$
After that we can simplify the fraction by canceling common factors:
$$\Rightarrow f^2 \cdot (2\pi)^2C =\frac 1{\cancel{(2\pi)^2}L\cancel C} \cdot \cancel{(2\pi)^2}\cancel C \\
\Rightarrow(2\pi)^2f^2C =\frac 1{L}$$
Now we take the inverse $\frac 1 x$ left and right, to get:
$$\Rightarrow \frac{1}{(2\pi)^2f^2C} = L \\
\Rightarrow L = \frac{1}{(2\pi)^2f^2C}
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
