Chenkel
- 482
- 109
Hello everyone,
I'm currently working on a physics problem involving the rotation of a 5 kilogram ##M=5## solid sphere subjected to a force of 5 newtons ##F=5##, and I've encountered an inconsistency in my calculations. I'm seeking guidance or insights into where I might have gone wrong.
My initial goal was to apply a force of 5 Newtons tangentially to a solid sphere with a 1-meter radius through a distance of 1 meter. The objective was to examine whether the total kinetic energy (sum of linear and angular kinetic energy) of the system equals the energy I put into it. I postulate that I put in 5 joules of energy but my calculations say I put in 6.97 joules.
I calculated with a solid sphere that has a mass of 5 kilograms, and I used the following formula to find the moment of inertia about the center of mass of a solid sphere ##I=(2/5)*M*R^2##, ##M=5## and ##R=1## so I plugged my values in and I got a moment of inertia of ##I=2##
Then I calculated the work I put into the system as 5 joules or 5 Newtons applied through a distance of 1 meter.
But the force also creates a 5 Newton meter torque about the center of mass during the impulse.
I postulated that if the force acts through a distance of 1 meter tangentially to the sphere then the sphere will rotate by an angular displacement of 1 radian during the impulse (because the sphere has a radius of 1 meter).
So now I wanted to calculate how long the impulse was so I calculated the torque, and divided the torque by the moment of inertia to find the angular acceleration and then integrated the angular acceleration to find the angular displacement and I solved for t. So ##{\theta} = (1/2)*{\alpha}*t^2## where ##\theta## is the angular displacement, and ##\alpha## is the angular acceleration.
To find the angular acceleration I divide the torque ##\tau## of 5 Newton meters by the moment of inertia ##I## which is 2 and I get an acceleration of 5/2 which is an ##\alpha## value of 2.5 radians per second squared.
Now I can solve for t when ##\theta## (angular displacement) is one radian (the angular displacement during the impulse) and I get ##t=sqrt(2/{\alpha})=sqrt(2/2.5) = .894## seconds
Then I calculated an angular impulse of time_of_impulse*applied_torque or
sqrt(2/2.5)*(5 Newton meters) = 4.47 Newton meter seconds.
I divide this value by the moment of inertia to get the angular velocity after the impulse and I get an angular velocity of 4.47/2 or 2.23 radians per second.
Now I need to calculate the linear impulse and divide by the total mass of the object to get the linear velocity and I get (sqrt(2/2.5)*5)/5 = .894 meters per second
Now I plugged these values into the total kinematic energy formula (1/2)*5*(.894^2) + (1/2)*2*(2.23^2) and I get 6.97 joules instead of what I postulated I put in which was 5 joules.
Any assistance or suggestions regarding the approach or calculations would be highly appreciated. Specifically, I'm looking for insights into the discrepancy between the expected and calculated total kinetic energy.
My apologies if my analysis was tedious and and thanks to anyone who read through it.
If you can shed any light on this matter I would appreciate it and I thank you!
