I'm having trouble finding this sum
  • Thread starter Jncik
  • Tags
    Sum
In summary, the sum of e^{-j\omega n} from -N1 to +N1 can be simplified using the formula \sum_{k=0}^{N}x^{k} = \frac{1-x^{N+1}}{1-x}. By letting \lambda = e^{-j\omega}, we can express the sum as \frac{e^{j\omega N1}-e^{-j\omega N1}e^{-j\omega}}{1-e^{-j\omega}}. Multiplying the numerator and denominator by e^{j\omega/2} and using the identity e^{jx}-e^{-jx}=2jsin(x), we can simplify the expression to \frac
Jncik
103
find
[tex]\sum_{-N1}^{+N1}e^{-j\omega n}[/tex]
Let [tex]\lambda = e^{-j\omega} [/tex]
we have
[tex]\sum_{-N1}^{+N1}\lambda ^{n} = \sum_{-N1}^{-1}\lambda ^{n} + \sum_{0}^{+N1} \lambda ^{n}[/tex]
for the first i have
[tex]S = \lambda ^{-N1} + \lambda ^{-N1+1} + \lambda ^{-N1+2} + ... + \lambda ^{-2} + \lambda ^{-1}[/tex]
[tex]-\lambda S = -\lambda ^{-N1+1} - \lambda ^{-N1+2} - \lambda ^{-N1+3} - ... - \lambda ^{-1} - \lambda ^{0} [/tex]
hence
[tex] S = \frac{\lambda ^{-N1} - 1}{1-\lambda }[/tex]
for the second i have
[tex] S2 = \lambda^{0} + \lambda^{1} + ... + \lambda^{N1-1} + \lambda^{N1}[/tex]
[tex] -\lambda S2 = -\lambda^{1} - \lambda^{2} - ... - \lambda^{N1} - \lambda^{N1+1}[/tex]
hence
[tex] S2 = \frac{1 - \lambda^{N1+1}}{1-\lambda}[/tex]
so the sum is
[tex]\frac{1-\lambda^{N1+1} + \lambda^{-N1} - 1}{1-\lambda} = \frac{\lambda^{-N1} - \lambda^{N1+1}}{1-\lambda} = \frac{e^{j \omega N1} - e^{-j \omega N1}e^{-j\omega}}{1-e^{-j\omega}}[/tex]
but the book says [tex]\frac{sin\omega(N1 + \frac{1}{2})}{sin(\frac{\omega}{2})}[/tex]
Multiply numerator and denominator by e^(j*w/2). Now remember e^(jx)-e^(-jx)=2jsin(x).
thanks a lot :)
FAQ: I'm having trouble finding this sum
Why am I having trouble finding this sum?
There could be several reasons for having trouble finding a sum. It could be because the sum is complex or involves multiple steps, or there could be an error in your calculations. It is also possible that you may not have the necessary knowledge or skills to solve the sum.
How can I simplify a sum to make it easier to find?
To simplify a sum, you can try breaking it down into smaller parts or using known mathematical rules and properties. You can also use a calculator or online resources to assist you in simplifying the sum. It is important to always double-check your calculations to ensure accuracy.
What should I do if I get a different answer than what is expected?
If you get a different answer than what is expected, carefully review your steps to see if you made a mistake. Check for any errors in your calculations or if you missed any steps. You can also ask for help from a teacher or a peer to review your work and identify any mistakes.
What resources can I use to help me find a sum?
There are many resources available to help you find a sum. You can use textbooks, online tutorials, and educational websites to learn different problem-solving strategies. You can also seek help from a teacher, tutor, or study group for additional support.
Is there a specific order I should follow when solving a sum?
Yes, there are certain rules and order of operations that should be followed when solving a sum. This includes solving parentheses or brackets first, then exponents, followed by multiplication and division from left to right, and finally addition and subtraction from left to right. Remember to always double-check your calculations and follow the correct order of operations to ensure an accurate answer.
