Im ready for this test except I cant get started on these 2 questions.
  • Thread starter davie08
  • Tags
    Test
In summary: It's good that you've grasped some of the concepts behind vector addition, so you should be able to solve for the sin and cos of angles without much trouble. All in all, I think this problem should be easy for you.
davie08
115
A force of 20N,180degrees (W) and 30N,-110degrees (S20degrees (W) ) are both acting on a 3.0kg mass at rest. If there is 10N of friction:calculate the acceleration.
I think you just need kinematic equations so here they are:
V2=V1+a*t
d=V1t+1/2a*t^2
Im going to try the R theta and change that to x and y I just wanted to put this up first stop me if this is wrong.
wait you need forces equations:
Fn=m*a
Fn=Fa+Ff
Fg=m*g
Ff=m*F perpendicular sign
What's the total applied force?
Which way does the friction act?
First find the net force acting on the mass.
well the friction would be negative right since its going against the object
oh wait the total applied force are the first numbers
so I use Fn=Fa+Ff how do I change the first numbers into something I can use
To add the two applied forces, first break them into their components. Then you can add the components and find the new resultant.
im not sure how you chnge them don't you just use pol on the calculator and then F to get them but what about the S20degrees (W)
This problem I think is a little easier than you're making it. You started on the correct approach. Break each force into it's components. Add the two forces together to get the resultant components. From these forces, calculate the resultant force vector.
You now have a force mangitude and direction. Focus for a moment on the magnitude. You're given the friction force. This force acts opposite of motion, so you don't need to worry about direction. Simply subtract the friction force from the total resultant force.
You now have a resultant force and direction; divide by mass to get acceleration. I get 10.45 m/s² as the magnitude of the acceleration. Remember acceleration is a vector, you'll need to specify the direction as well.
You shouldn't really need a calculator to break a vector into its components. Just trigonometry. Well, I guess you'll need the calculator to solve for the sin and cos of the angles...
Breaking up a vector into its components should be second nature by this point in the semester/school year.
using that pol F stuff makes it 10 times easier
im just going to hope this isn't on the test lol I actually understand most of this unit now so I should be ok on the test
First of all, you need to take heed of what Jack said. Breaking vectors into components needs to be second nature by now. You can't always rely on calculator to add things in polar coordinates, hell you can't always use a calculator.
FAQ: Im ready for this test except I cant get started on these 2 questions.
1. What can I do if I can't get started on these 2 questions?
There are a few strategies you can try if you're having trouble getting started on specific questions. First, take a deep breath and try to relax. Next, reread the questions and make sure you understand what they're asking for. You can also try breaking the questions down into smaller, more manageable parts. If you're still stuck, consider asking a classmate or teacher for help.
2. How can I improve my focus and motivation to tackle these questions?
It's normal to feel overwhelmed or unmotivated when faced with challenging questions. To improve your focus and motivation, try setting small goals for yourself, such as completing one question at a time. Take short breaks in between questions to give your mind a rest. You can also try using study techniques like making flashcards or creating a study guide to help you better understand the material.
3. What should I do if I don't know the answer to a question?
If you encounter a question that you don't know the answer to, don't panic. First, see if you can eliminate any obviously wrong answer choices. Then, try to use any information you do know to make an educated guess. If you're still unsure, move on to the next question and come back to it later if you have time. Remember that it's okay to skip a question if you're not sure of the answer.
4. How can I manage my time effectively to complete the test?
Time management is crucial when taking a test. Before you begin, take a few minutes to quickly scan through the entire test and plan out how much time you'll spend on each section or question. This will help you pace yourself and ensure that you have enough time to complete all of the questions. If you find yourself running out of time, prioritize the questions that are worth the most points.
5. What can I do to reduce test-taking anxiety?
Test anxiety is a common issue for many students. To reduce your anxiety, try practicing relaxation techniques such as deep breathing or visualization before the test. Make sure you get a good night's sleep and eat a healthy breakfast on the day of the test. During the test, stay calm and focused by taking breaks if needed and reminding yourself that you have prepared for this test. If your anxiety is severe, consider talking to a teacher or school counselor for additional support.
21K
