annoymage
- 362
testing.
annoymage said:hmm, why there's no notification if someone reply?? did i turn it off?
im sorry if I am asking question here, if it is not legal, tell me.. xP
To create a new post, first navigate to the platform or forum where you want to make the post. Then, locate the button or link that says "Create New Post" or something similar. Click on it and you will be directed to a page or form where you can enter the content for your post. Make sure to follow any guidelines or rules set by the platform or forum.
It depends on the platform or forum you are using. Some platforms allow you to upload images or videos directly, while others may require you to use HTML code to embed them. Make sure to check the guidelines or rules of the platform before including any media in your post.
Again, this varies depending on the platform or forum. Some may have a strict limit, while others may allow longer posts. If there is a limit, it is usually mentioned in the guidelines or rules. If not, try to keep your post concise and to the point.
Most platforms and forums have built-in formatting options that allow you to change the font, add headings, use bold or italic text, and more. If you are familiar with HTML, you can also use basic HTML tags to format your post. Make sure to use formatting sparingly and to keep the overall design simple and easy to read.
Again, this depends on the platform or forum. Some may allow you to edit or delete your post at any time, while others may have a time limit or may not allow any changes once the post is published. If you need to make any changes, try to do so before publishing or contact the platform or forum administrators for assistance.
