I'm young and my hair is thinning
  • Thread starter Perceptron
  • Tags
    Hair Young
In summary, the conversation discusses the issue of hair thinning and baldness in males, specifically at a young age. There is a debate about whether male pattern baldness is inherited from the mother's side or if there are other factors at play. Some suggest using over-the-counter dandruff shampoos or minoxidil to treat the issue, while others advise embracing baldness and having a positive attitude towards it. Ultimately, it is recommended to consult with a doctor for proper advice and treatment.
Perceptron
I'm 16 years old male, and I noticed last year that my hair was thinning. I do not know if it's because of my dry scalp or because of the shampoo I'm using. Is it normal to have thinning hair at this age?Can I regrow my lost hair? Also, how can I get rid of my dry, itchy scalp?
Thank you.
Do you have an uncle on your mother's side? If so, is he bald? If so, get used to it sooner rather than later. This is not always the case, but male pattern baldness is inherited from the mother. How weird is that?
Until then, use a normal over the shelf dandruff shampoo. They are all the same.
Thank you.
My hair has been steadily thinning for as long as I remember. (I'm only 28) For my own dry scalp issues I use Head and Shoulders. Try that or another dandruff shampoo. Remember to let it soak in your hair for a few minutes before you rinse it off, otherwise it won't work.
Minoxidil works. But ultimately your genes will win out.
My college roommate had a full head of hair at 18 and when he graduated at 22 he was a cue ball. It happens.
Bald is not unsexy if you embrace it. Don't do the combover- just shave it every day and accept it.
Old Hungarian proverb: there's no such thing as baldness; just a forehead reaching clear back to your *ss.
+1. It's all in the attitude.
Castration is a 100% surefire and permanent solution.
I thought that was a myth.
Also, to the OP, baldness isn't all bad. Look a Jason Statham; he has AGA, and he's considered to be attractive.
Yea it is possible to start balding at a very young age. I see a few kids in my classes around campus who are 20-21 and are balding very noticeably.
It could be caused by some other issue though. Maybe ask your doctor about it.
I'm waiting until I can pull off "The Picard" as I call it. You know, the Captain Picard from Star Trek TNG when he has that ring of hair and is bald on top.
Thank you.
See your doctor, they can give you appropriate advice. Yes: in certain cases it's possible to get treatment, but don't waste your money on products that promise more than they can fulfill (thus get expert advice).
Is it? That was taught when I took bio in high school. I'm personally an exception to that rule, so I knew it wasn't 100%. My mother's brother was a bald red-head. When I was young I had super thick ("Danny Partridge") hair that was a combination of red and brown.
Today, all the red has gone, and my hair is "normal" thickness. I sort of concluded I was born with 2 set of hair, one of which went bald.
I never looked into it, I guess because it never mattered too much.
My roommate was already on his way to being bald when we entered college at 18. He ALWAYS wore this baseball cap, no matter what the situation. It was so out of place that it became obvious to anyone that he was hiding his baldness. I don't blame him for being insecure about it, but he didn't make things better by hiding it from everyone.
He has embraced it now and it works for him rather than against him.
You can inherit male baldness from your mother's side, but it's not the only way.
The results reveal that more than one gene is involved in the development of male hair-loss. These results also throw interesting light on the inheritance of baldness in that hitherto the only known risk gene for the androgen receptor lay on the X-chromosome, and was thus inherited from the mother – which accounts for the fact that in the case of hair-loss men often take after their maternal grandfathers. However, the newly discovered gene lies on chromosome 20, and can be inherited from both the mother and the father. "This helps to provide an explanation for the similarity between father and son", declares Professor Nöthen.
http://www.sciencedaily.com/releases/2005/05/050520172151.htm
My uncle on my mother's side has AGA, and I have three brothers around the age at which he started going bald, and they have no signs of baldness. Instead, they have their dad's thick hair (half brothers). Now, that doesn't mean they won't start losing hair around 50 (something like 50% of men do).
This is exactly what I was thinking. I could have phrased it better, but it's a myth that it's only inherited from the mother's side.
When you lose all your hair, you won't feel old, you'll feel like you're 16.
There's a shampoo I use called Nizoral that works really well on dandruff, and I've heard from a lot of sources that the active ingredient in it supposedly slows baldness or something along those lines.
I'm not sure about that, but it works for the dandruff. Dandruff shampoos would get rid of the dandruff between showers, but the Nizoral seemed to cure it. I ran out of it and the dandruff never came back.
A lot of people do that, which is why there's a myth that wearing hats can cause baldness. People are just mistaking cause and effect.
Thanks to the myth (as mentioned), I was all prepared to go bald myself. Decided to go skin-head during the mid-80s, but that became problematic, due to all the skin-heads and the fact that it made me look 12 (I was in college). It's an odd effect that "balding" makes you look older, but "shaved head" makes you look younger.
Tight head garments or hairstyles can cause (permanent) hair loss, known as traction alopecia:
"Traction alopecia in two adolescent Sikh brothers – an underrecognized problem unmasked by migration." http://www.ncbi.nlm.nih.gov/pubmed/21371118
"Extensive traction alopecia attributable to ponytail hairstyle and its treatment with hair transplantation." http://www.ncbi.nlm.nih.gov/pubmed/16044234
I have two hairs left on the top of my head.I groom one of them every day but keep the other one casual.
I started going bald when I was about 16. I'm almost 30 now and the typical male-pattern baldness is nearly complete. I just keep my head shaved completely. Up until a few years ago, I just kept it very short (I'd let it grow to about an inch in length before shaving), but now I just Bic it in the shower twice a week. (Note: I don't mean I use the Bic brand of razor, that's just the terminology for taking it down to the skin).
For what it's worth, no male on my mother's side of the family is bald. Not my uncle, not my grandfather, not any of my grandmother's brothers... Nobody on that side of the family is bald. On the other hand, my father went bald before 20, so did every one of his 3 brothers, their father, my cousin... It's clearly from my father's side.
There are benefits to a shaved head. For one, I can leave the house without showering if I had to without everybody being able to notice, because I didn't have to worry about greasy hair or anything. Using a razor twice a week is cheaper than paying for a hair cut, and you never have to worry about your hair getting messed up. Plus, it's marginally safer if you're ever near any heavy machinery. Besides, shaved heads are a fairly popular look these days.
I've heard of that. That must be an extreme case though, and the male pattern baldness can't possibly be blamed on hats.
It has an effect on the health of hair. Wearing a hat won't cause male-pattern baldness, but it's not so hard to imagine that extra stress on the hair could accelerate the process of balding if the hair is already weak.
The OP never talked about male-pattern baldness though. The thinning could have several causes, that's why I suggested seeing a doctor for a diagnosis.
Whenever I wear a hat, there isn't any stress on the areas where men normally go bald. If a hat is tight, it's tight around the circumference of the head. It barely touches the top of the head, much less causes stress on the hair.
The thinning he's talking about is probably in the areas where men develop the typical baldness pattern. If it's thinning all over, he needs to see a doctor immediately, because that's not normal.
Related to I'm young and my hair is thinning
What causes hair thinning in young people?
Hair thinning in young people can be caused by a variety of factors, such as genetics, hormonal imbalances, stress, and nutritional deficiencies. It is important to consult a doctor to determine the specific cause of hair thinning.
Can hair thinning be reversed in young people?
In some cases, hair thinning can be reversed in young people through lifestyle changes, medication, or hair transplant procedures. However, it is important to address the underlying cause of hair thinning to effectively reverse it.
Does using hair products or styling techniques cause hair thinning?
Using excessive heat, chemicals, or tight hairstyles can damage the hair follicles and lead to hair thinning. It is important to use hair products and styling techniques in moderation and take breaks to give your hair a chance to recover.
Are there any natural remedies for hair thinning in young people?
There are some natural remedies that can help with hair thinning, such as using essential oils, scalp massages, and a balanced diet. However, these remedies may not work for everyone and it is important to consult a doctor before trying any natural remedies.
Is hair thinning in young people a sign of a serious health condition?
In some cases, hair thinning in young people can be a symptom of an underlying health condition, such as thyroid problems or autoimmune diseases. It is important to consult a doctor to rule out any potential health issues and address them accordingly.
  • Biology and Medical
11K
