Image distance of a Keplerian telescope
  • Thread starter guv
  • Tags
    Telescope
In summary: The solution at the site is ##d_i=d_o\left(\frac{f_e}{f_o}\right)^2##, not what you have. The ##10^4## is ##d_o = 10## km, not the square of the height of the building.Here is how one obtains the answer following the outline in post #2. The real image is formed by the objective at distance ##f_o+\epsilon## beyond the focal point.$$\frac{1}{d_o}+\frac{1}{f_o+\epsilon}=\frac{1}{f_o}\implies \
guv
123
Thread moved from the technical forums to the schoolwork forums
I found a problem where the question is asking for image distance.
The focal lengths of the objective and eyepiece convex lenses are in the ratio 8:1 for aparticular telescope. The telescope is pointed at a building that is 10 km from thetelescope and is 100 m tall. What is the distance to the image?
Normally this type of question only concerns with the magnification factor. The provided solution has a formula for the image distance,
##d_i = d_o^2 (\frac{f_e}{f_o})^2 = 10^2 (\frac{1}{8})^2 = 156.2 m ##
Can someone explain this equation? Thanks,
It seems that the provided solution is dimensionally incorrect. The left hand side has dimensions of length whilst the right hand side has dimensions of length squared.
In any case, you should be able to get the correct expression by considering that the telescope is constructed so that the objective creates a real image of the building at distance ##f_o+\epsilon## which becomes an object for the eyepiece at distance ##f_e-\epsilon##. The calculation requires the use of the lens equation in tandem.
I also think it should be distance squared. But then everything could be square rooted . . . .?
But the lens equation, for the eyepiece, needs more information (like the intermediate object distance from the EP). It's up to the user to adjust that 'to taste' and the image distance can be chosen over a range from the user's near point to infinity (and beyond!).
Normally the magnification factor is concerned with angles and not heights. Is it possible that there is some more information somewhere in the printed question? There's one clear error so another one is quite possible.
We need to see the actual question of a reference to it.
sophiecentaur said:
I also think it should be distance squared. But then everything could be square rooted . . . .?But the lens equation, for the eyepiece, needs more information (like the intermediate object distance from the EP). It's up to the user to adjust that 'to taste' and the image distance can be chosen over a range from the user's near point to infinity (and beyond!).
That's exactly correct, there will be an adjustable delta between the two foci of the objective and eye piece ##\delta##. Therefore exact calculation will yield a final image distance from eye piece
##- \frac{f_e (f_e - \delta )}{\delta }##
Note that this has nothing to do with objective lens focal length and it depends on the adjustable distance which is not given.
I posted the exact problem (Physics Bowl 2023 Question 48) without cutting out anything. I quoted the solution wrong, the provided solution is
##d_i = d_o^2 (\frac{f_e}{f_o})^2 = 10^4 (\frac{1}{8})^2 = 156.2 m ##
Here is the direct link to the problem and solution https://aapt.org/programs/physicsbowl/currentexam.cfm
I wonder if aapt got this problem/solution wrong.
##d_i = d_o (\frac{f_e}{f_o})^2 = 10^4 (\frac{1}{8})^2 = 156.2 m ##
$$\frac{1}{d_o}+\frac{1}{f_o+\epsilon}=\frac{1}{f_o}\implies \frac{1}{d_0}=\frac{\epsilon}{f_o(f_o+\epsilon)}\approx\frac{\epsilon}{f_o^2}.$$This real image is just inside the focal length of the eyepiece at distance ##f_e-\epsilon##. Then $$\frac{1}{d_i}+\frac{1}{f_e-\epsilon}=\frac{1}{f_e}\implies \frac{1}{d_i}=-\frac{\epsilon}{f_e(f_e-\epsilon)}\approx-\frac{\epsilon}{f_e^2}.$$You can finish the solution to get the magnification and the AAPT answer from here. Note that this relation is only approximate.
Likes SammyS and hutchphd
That's the same thing I derived earlier,
How do you determine ##\delta## or ##\epsilon## from here?
kuruman said:
The solution at the site is di=do(fefo)2, not what you have. The 104 is do=10 km, not the square of the height of the building.
I was over thinking it. The "telescope" is assumed to be set up for infinite object and image distances and that's the missing info. As a bino and scope user I would never have assumed that.
Not a fair question because it triggers panic and not 'I can do this'.
FAQ: Image distance of a Keplerian telescope
What is the image distance in a Keplerian telescope?
The image distance in a Keplerian telescope refers to the distance from the eyepiece lens to the final image formed by the telescope. In a Keplerian telescope, this distance is typically the focal length of the eyepiece lens, as the final image is formed at the focal point of the eyepiece.
How do you calculate the image distance in a Keplerian telescope?
To calculate the image distance in a Keplerian telescope, you need to know the focal lengths of both the objective lens (F_o) and the eyepiece lens (F_e). The image distance is approximately equal to the focal length of the eyepiece lens, as the final image is formed at the focal plane of the eyepiece. Therefore, the image distance (d_i) can be approximated as d_i ≈ F_e.
Why is the image distance important in a Keplerian telescope?
The image distance is important in a Keplerian telescope because it determines where the final image will be formed in relation to the eyepiece. This affects the overall magnification and clarity of the image viewed through the telescope. Proper alignment and focusing are crucial for obtaining a clear and sharp image.
Does the image distance change with different eyepiece lenses in a Keplerian telescope?
Yes, the image distance changes with different eyepiece lenses in a Keplerian telescope. Since the image distance is approximately equal to the focal length of the eyepiece lens, using an eyepiece with a different focal length will result in a different image distance. This also affects the magnification and field of view of the telescope.
How does the image distance affect the magnification of a Keplerian telescope?
The image distance affects the magnification of a Keplerian telescope indirectly through the focal length of the eyepiece lens. The magnification (M) of a Keplerian telescope is given by the ratio of the focal length of the objective lens (F_o) to the focal length of the eyepiece lens (F_e), i.e., M = F_o / F_e. Since the image distance is approximately the focal length of the eyepiece lens, a shorter image distance (shorter focal length eyepiece) results in higher magnification, and a longer image distance (longer focal length eyepiece) results in lower magnification.
