Image Distance with two concave lenses
The discussion revolves around calculating the final image location formed by a system of two lenses: a convex lens followed by a concave lens. The first step involves using the thin-lens equation to find the image distance from the convex lens, which is initially miscalculated due to sign errors. It is clarified that the image formed by the first lens serves as a virtual object for the second lens, requiring careful attention to the distances and signs when applying the thin-lens equation again. The final image location depends on correctly interpreting the virtual object distance for the concave lens. Proper understanding of lens behavior and sign conventions is crucial for solving the problem accurately.
Jende
An object 1.25 cm tall is placed 100 cm in front of a convex lens with a focal length of magnitude 50 cm. A concave lens with a focal length of magnitude 20 cm is placed 90 cm beyond the first lens. Where is the final image located?
(1/s)+(1/s')=1/f
s= object distance from lens
s'= image distance from lens
f= focal length
I wasn't sure where to start so I tried find the image distance for the first lens.
(1/100cm)+(1/s')=(1/50cm) => (1/100cm)-(1/50cm)=(-1/100cm)=(1/s') => s'= -100
After this i got stuck because I wasn't sure what to do when the image distance is behind the second lens.
Thanks in advance.
(1/s)+(1/s')=1/f
f= focal length
(1/100cm)+(1/s')=(1/50cm) => (1/100cm)-(1/50cm)=(-1/100cm)=(-1/s') => s'= +100
You have sign errors here.
Thanks in advance.
Take the object distance negative.
Likes Jende
The image formed by the first lens acts as the object for the second lens. However, when you apply the thin-lens equation for the second lens you'll need to make sure that the object distance is the distance measured from the second lens, which you can do by taking into account the distance between the two lenses.
Be careful of the signs. As ehild says, you have an error in your first calculation.
Likes Jende
Being behind he second lens this image is then a virtual object for the second lens. The light rays are still entering the second lens, but they seem to originate from a object located on the "wrong" side of the lens. The rays will therefore not form the object and is thus a virtual object for the second lens.
Likes Jende
Ok thanks a lot. This was giving me a lot of frustration.
  • · Replies 26 ·
