Image formed from object at focal point of concave mirror
In summary, the question posed is about the location and size of an image formed by an object placed on the focal point of a concave mirror. Our class and textbook agree that no image is formed in this scenario, but our professor has offered four answer choices and maintains that the correct answer is B, indicating a virtual image to the left of and behind the mirror with a negative magnification. It is unclear if this is a mistake or if we are missing a key factor in our understanding of spherical reflecting surfaces. It may be helpful to ask for a demonstration to better understand the working of the mirror.
Max Matiauda
The question posed: "An object is located to the right of a mirror that in concave in its [the object's] direction. If the object sits on the focal point of the mirror, what answer best describes the image formed?"
Our class is united in the notion that as the rays would be parallel, intersecting only at infinity, no image is formed on either side of the mirror (or at infinity on both sides). Our textbook corroborates this, but our professor has only offered four answer choices:
A. The image is to the left of the mirror and larger than the object.
B. The image is to the left of the mirror and smaller than the object.
C. The image is to the right of the mirror and larger than the object.
D. The image is to the right of the mirror and smaller than the object.
and maintains that the answer is B, which would indicate--to assume I've read the setup correctly--a virtual image, being to the left of and therefore behind the mirror, with a negative magnification. Does the solution lie in the wording of the question ("best describes") or are we all missing a key factor in our understanding of spherical reflecting surfaces?
I'd call it a mistake on her part, but she seems entirely sure of herself and undergraduates are nigh-guaranteed to be outclassed in optics knowledge by a full-time optoelectronics researcher with a Ph.D in experimental solid-state physics. Really appreciate the help, folks!
Science news on Phys.org
Ask for a demonstration of the working.
The model answer is correct for the mirror convex in the objects direction... may be a typo on the question.
Related to Image formed from object at focal point of concave mirror
1. What is the image formed from an object placed at the focal point of a concave mirror?
When an object is placed at the focal point of a concave mirror, the image formed is virtual, upright, and magnified. It appears to be located at infinity.
2. How does the size of the image compare to the size of the object?
The size of the image formed from an object at the focal point of a concave mirror is larger than the size of the object. The magnification depends on the distance between the object and the mirror.
3. Is the image real or virtual?
The image formed from an object at the focal point of a concave mirror is virtual, meaning it cannot be projected onto a screen. It can only be seen by looking into the mirror.
4. What happens to the image if the object is moved closer to the mirror?
If the object is moved closer to the mirror, the image will become larger and move further away from the mirror. It will also become more distorted and may eventually disappear.
5. How does the image formed from an object at the focal point of a concave mirror change as the object moves away from the mirror?
As the object moves away from the mirror, the image will become smaller and move closer to the mirror. It will also become less distorted and clearer. When the object is at infinity, the image will be the same size as the object and located at the focal point of the mirror.
15K
  • Optics
