MHB Image, Range, and Matrix of a Linear Transformation
SiddharthThakur
Question
Consider the linear transformation T(x1,x2,x3)= (2*x1 -2*x2- 4*x3 ,x1+2*x2+x3)
(a) Find the image of (3, -2, 2) under T.
(b) Does the vector (5, 3) belong to the range of T?
(c) Determine the matrix of the transformation.
(d) Is the transformation T onto? Justify your answer
(e) Is the transformation one-to one? Justify your answerPlease see the attachement.it will be more clear to you.
Thread closed until issue of helping with a graded assignment addressed. Please send me a PM or reply to the other thread SiddharthThakur. This is not to embarrass you, it's just MHB policy. Let's talk about this so we can help you as much as possible.
SiddharthThakur said:
Question
(a) The image of $(3, -2, 2)$ here is simply plugging in $x_1=3$, $x_2=-2$ and $x_3=2$ into the expression you are given.
(b) You want to solve $$A \hspace{1 mm} \vec{x} = \left[ \begin{array}{c}5 \\ 3 \end{array}\right]$$. You can do that by the following method.
$$\left[ \begin{array}{ccc} 2 & -2 & 4\\ 1 & 2 & 3 \end{array}\right] \left[ \begin{array}{c}x_1 \\ x_2 \\ x_3 \end{array}\right] = \left[ \begin{array}{c}5 \\ 3 \end{array}\right]$$
Change that to an augmented matrix and solve.
Question
Since the deadline for the assignment in question has passed, I will make some more comments on solving the problem so others can use the information in the future.
(а) $Т(3,-2,2)=(2(3)-2(-2)-4(2), 3+2(-2)+2)=(2,1)$
(b) To answer this we can start by answering part (c). The transformation matrix of $T$ is $\left[ \begin{array}{ccc} 2 & -2 & 4\\ 1 & 2 & 3 \end{array}\right]$ To find if the vector $[5,3]$ is in the range of $T$ we can solve the following matrix equation:
$$ \left[ \begin{array}{ccc} 2 & -2 & -4\\ 1 & 2 & 3 \end{array}\right] \left[ \begin{array}{c}x_1 \\ x_2 \\ x_3 \end{array}\right] = \left[ \begin{array}{c}5 \\ 3 \end{array}\right]$$
I will leave the computation to the reader, but if you row-reduce the augmented matrix from the above equation then you'll find that the the system is consistent, thus there exists a solution and the vector $[5,3]$ is in the range of $T$.
(c) Answered above.
(d) The transformation matrix is composed of 3 column vectors in $\mathbb{R}^2$ and after noticing that there are two of them which are linearly independent it follows that $T$ is in fact onto $\mathbb{R}^2$. This can also be shown by using the fact that there is a pivot position in every row.
(e) We have three column vectors in $\mathbb{R}^2$, so at least one of them must be a linear combination of the other two so $T$ isn't one-to-one. We can see this fact when row-reducing the augmented matrix for part (b). The solution contains a free variable which means that there is more than one solution, which doesn't fit the definition of being one-to-one. Two ways to check this in general is the columns of the transformation matrix must be linearly independent and when row-reducing the augmented matrix to solve for any $\vec{b}$, there can't be any free variables.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
