Solving Imaginary Numbers: What is x^^2 = x^x = -4?
In summary: So we might as well choose the simplest one, namely the principal value, in the case of i, the angle between 0 and pi, say pi/2.So we define i^i = e^[i pi/2] = e^[pi/2] = i. (pi/2 is also the angle between 0 and i, so i^i is just i.)This is the same way that when we define the square root of a real number, say 4, we choose the positive square root, namely 2.So we define the square root of a complex number z to be the unique complex number w such that w^2 = z. (this w is called the
Alkatran
959
I've been doing a lot of thinking about imaginary numbers lately. My first question was "What is sqr(i)?".
I thought it was unsolvable until I punched it into my trusty (and often right) caclulator and found out it was (sqr(.5)i + sqr(.5))^2
So obvious now. Of course.
Anyways, a while later, I thought about series of powers (the same way a power is a series of multiplications and those a series of additions). (We'll call a series of power ^^)
So my question is:
x^^2 = x^x = -4
What is x?
My calculator tells me: false. But I have this tendency not to trust it sometimes, especially when it won't give me an answer.
Also, is i ^ i defined? ((-1)^.5)^((-1)^.5) = (-1)^(i/2) = ?
Mathematics news on Phys.org
Use the identity [itex]e^{i\theta}=\cos\theta + i\sin\theta [/itex]. Observe that [itex]e^{i(\pi/2)}=\cos(\pi/2) + i\sin(\pi/2)=i[/itex]
So, [itex]i^i=(e^{i\pi/2})^i=e^{i^2\pi/2}=e^{-\pi/2}\approx 0.2078795764[/itex]
Thanks
(I haven't... learned that identity yet :redface: )
I think it was Cardan who got concerned with such problems: Find two numbers such that their sum is 4 and their product is 13.
x+y = 4
x=4-y
x*y=13
x=13/y
13/y=4-y
13=4y-y^2
-y^2+4y-13 = 0
y^2-4y+13=0
y = (4 +- sqr(16 - 4*1*13))/2 = 2 +- sqr(16 - 52) = 2+- sqr(-36) = 2+-6i
Oh, your point was that he discovered imaginary numbers?
Well, Cardan seemed to have, now and then, suggested that imaginary numbers might have some actual mathematical worth, which was not the usual attitude.
alkatran,
the number e^x is always equal to 1+x + x^2/2 + x^3/6 + x^4/24 +...+x^n/n!+...
and whenever you want to evaluate a^b, the easiest way is to write a as e^(lan(a)),
so that a^b = [e^ln(a)]^b = e^[ln(a).b] = e ^b.ln(a). For example, since e^(r+si), with r,s real, equals (e^r)[cos(s)+isin(s)], and sin(pi/2) = 1, then e^(i pi/2) = i, so ln(i) may be taken to be i pi/2, although there are many other values of z such that e^z = i.
Anyway, one value of ln(i) is i pi/2, so i^i can be taken as e^i[ln(i)] = e^i [i pi/2]
= e^[- pi/2].
To see why e^it = cos(t) + i sin(t), work out the Taylor series
e^(it) = 1 + (it) + [(it)^2]/2 + [(it)^3]/6 + ...+ [(it^n]/n!+...
amd cos(t) = 1 - t^2/2 + t^4/4! -+...
and sin(t) = t - t^3/3! + t^5/5!-+...
and add them...
Assuming you have had Taylor series.
Or use the fact that any soution of f '' + f = 0, and f(0) = a and f'(0) = b, must equal acos(t) + bsin(t).
I.e. then check that f(t) = e^(it) solves f '' + f =0, and also f(0) = 1, and f '(0) = i.
hence f(t) = e^(it) must equal cos(t) + i sin(t).
Great post mathwonk, just so you know, I graduated from high school two months ago.
We learned that (if I remember correctly):
x^n = cos(nO) + i*sin(nO)
where x is a complexe number and O (theta) is the angle from (0,0) to your complexe number on a graph.
Actually, I'm positive that formula is wrong (in this post, not yours!). There's more to it.
The explanation you gave is excellent but is going to take some time to digest.
Actually your formula might be right for complex numbers of length one. For any arrow in the plane, such as a complex number, making angle O with the origin, the x coordinate is equal to rcos(O), where r is the length, and the y coordinate is equal to rsin(O). Hence it is true for any complex number x (not zero), that x = rcos(O) + i rsin(O). Now to raise a complex number to a power means to raise the length to that power, and multiply the angle by n,
so x^n would be r^n cos(nO) + i r^n sin(nO).
so yes you are right your formula is missing the r^n factor.
(I myself got this wrong also while writing the original version of this post a few minutes ago.)
As to exponentials of complex numbers, they are simpler when the base is a positive real number a, since then there is a unique natural choice of logarithm, the unique real number b = ln(a) such that e^b = a.
Then we can define a^c = e^cb.
But if the base is not a positive real number, then there is not so natural a choice for the log, so we have to choose between infinitely many of them, as for i. Still it makes no difference which one we choose, we get the same value of a^c.
Related to Solving Imaginary Numbers: What is x^^2 = x^x = -4?
What are imaginary numbers?
Imaginary numbers are numbers that can be written in the form a + bi, where a and b are real numbers and i is the imaginary unit equal to the square root of -1. These numbers are essential in solving equations that have no real solutions.
How do you solve an equation with imaginary numbers?
To solve an equation with imaginary numbers, you must first isolate the imaginary terms on one side of the equation. Then, take the square root of both sides to eliminate the imaginary unit. Finally, solve for the real number solution.
What does x^^2 mean in an equation?
The notation x^^2 represents the square of x, or x to the power of 2. This means that x is multiplied by itself, resulting in x squared.
What does it mean when an equation has no real solutions?
An equation with no real solutions means that there is no value for the variable that will make the equation true. In other words, the solution to the equation is not a real number.
How do you know if an equation has no real solutions?
An equation has no real solutions if the discriminant (b^2 - 4ac) is less than 0. This means that the equation has complex solutions, which involve imaginary numbers.
  • General Math
  • General Math
  • General Math
  • General Math
