Imine/Amine with NaBH4/H3O+ question w/ pics
  • Thread starter rfig08d
In summary, the nitrogen on the carbonyl group gets a hydrogen attached to it using a nucleophilic attack. The first step of the reaction is done, but the product is not the amine that you are after. To liberate the amine, you have to hydrolyze the complex under acidic conditions.
rfig08d
Please note: this is NOT a homework question. I am reviewing my notes for next week's quiz and I need some clarification.
Hi everyone! I'm a little bit stumped on this as I cannot see the reaction!
Does anyone know a useful link for imine to amine reduction mechanism using sodium borohydride and hydronium ( 1) NaBH4 2) H3O+ ) as reagents? Specifically this mini-synthesis (in screenshot). I know how NaBH4 works with most compounds, but for some reason I cannot see how the nitrogen obtained another hydrogen.
[PLAIN]http://img829.imageshack.us/img829/720/imine.jpg
(Ignore the mechanism, look at the reactions below it)
How does the final product obtain the hydrogen attached to the nitrogen? What's the 1st step without hydronium acting on it?
[PLAIN]http://img832.imageshack.us/img832/5369/imine2.jpg
I hate to ask, but a picture would be 100% more helpful than words right now. If I can see it once, then I have it set... so if anyone has a link or can draw a quick mechanism (doesn't have to be detailed, I just want to see how the hydrogen attaching on the nitrogen gets there), I would REALLY appreciate it. I only need 1 reaction explained, I simply provided the other ones as extra.
Thank you!
Chemistry news on Phys.org
Well I can't draw a picture right now, so I hope you can settle with words. Draw a picture to follow along, you'll learn it better if you're comfortable drawing it. In water, Sodium Borohydride (NaBH4) dissociates according to the following reaction:
NaBH4 ---> NaBH3+ + H-
So now you've got your hydride acting as a nucleophile. It's the same picture as all the other nucleophilic attacks on carbonyl groups: H- bonds to the carbonyl group's carbon, shifting electron density up to the nitrogen atom. There is now a lone pair on the nitrogen atom, giving it a formal negative charge. But remember, you've got NaBH3+ in solution still; as such, it complexes with the formally negative nitrogen atom.
The first step of the reaction is now done, but the product is not the amine that you are after! To liberate the amine, you have to hydrolyze the complex under acidic conditions--that's why you use H3O+. THIS is where that extra hydrogen comes from. Remember, what's the fastest reaction in organic chemistry? Proton transfer. So when you've got that nitrogen with that extra lone pair on it under acidic conditions, it's going to grab the proton off the H3O+.
By the way, that third picture reminds me of my final in my second semester of O. Chem. We were asked to write a synthesis of that substance (whose discussion is not permitted on that forum) from that very precursor (the ketone).
Ahh thank you.
This is what I've been looking for!
I drew out the picture based on your words:
[PLAIN]http://img9.imageshack.us/img9/8369/imines3.jpg
(The scratched out lines in part 2 is a single bond... accidentally put a double bond)
Thank you very much, I really appreciate your help! :-)
I want to add a bit more of an explanation here and also a suggestion for if you're asked to draw this mechanism on your quiz. It's likely that a mixture of ionic complexes form after the nucleophilic addition of the hydride to the carbonyl group. It may simply be better to write "M+" instead of NaBH3+. The point is that in order to remove that cation, you must perform acid hydrolysis (which is where you extra proton comes from, again).
Kind of a minor detail, but I thought it was worth mentioning.
Hi there,
I understand your confusion and I will try my best to explain the reaction for you. The reduction of imines to amines using sodium borohydride and hydronium (H3O+) is a common reaction in organic chemistry. The mechanism for this reaction is known as the reductive amination reaction.
In the first step of the reaction, sodium borohydride (NaBH4) acts as a reducing agent and donates a hydride ion (H^-) to the imine functional group. This results in the formation of an intermediate compound called an iminium ion.
In the second step, the iminium ion reacts with hydronium (H3O+) to form an amine. This is a nucleophilic addition reaction, where the hydronium ion acts as a nucleophile and attacks the iminium ion, breaking the double bond and forming a new bond between the nitrogen and the hydrogen from the hydronium ion.
So to answer your question, the hydrogen attached to the nitrogen in the final product is obtained through the addition of the hydronium ion in the second step of the reaction. The first step, with NaBH4, is necessary to form the intermediate iminium ion, which is then reduced to an amine in the second step with H3O+.
I hope this helps clarify the reaction for you. If you need any further clarification or if you come across any other questions, please don't hesitate to let me know. Best of luck on your quiz next week!
Related to Imine/Amine with NaBH4/H3O+ question w/ pics
1. What is an imine/amine?
An imine is a functional group in organic chemistry that contains a carbon-nitrogen double bond. In comparison, an amine is a functional group that contains a nitrogen atom bonded to one or more carbon atoms.
2. How does NaBH4/H3O+ reduce imine/amine?
NaBH4/H3O+ is a reducing agent commonly used in organic chemistry to reduce imine and amine groups. It works by donating a hydride ion (H-) to the imine or amine functional group, thereby breaking the carbon-nitrogen double bond and creating a primary amine.
3. What are the benefits of using NaBH4/H3O+ to reduce imine/amine?
Using NaBH4/H3O+ to reduce imine and amine groups has several benefits. It is a mild and selective reaction, meaning it does not affect other functional groups in the molecule. It also produces a high yield of the desired product and is relatively easy to perform.
4. Can you provide an example of the reduction of imine/amine with NaBH4/H3O+?
One example of the reduction of an imine with NaBH4/H3O+ is the reduction of benzaldehyde and aniline to form N-benzylideneaniline. The reaction proceeds in two steps: first, NaBH4 reduces the imine to a secondary amine, and then H3O+ protonates the secondary amine to form the desired product.
5. Are there any limitations to the use of NaBH4/H3O+ for reducing imine/amine?
While NaBH4/H3O+ is an effective reagent for reducing imine and amine groups, it does have some limitations. It cannot reduce tertiary amines, and it may also reduce other functional groups such as aldehydes and ketones. Additionally, the reaction may require longer reaction times or higher temperatures for certain substrates.
  • Cosmology
  • Astronomy and Astrophysics
