Impact of container on final temperature of system
In summary: If the container is insulated on the outside, then it would be exchanging heat with the room, but the room would also be exchanging heat with the metal. Including the container would then reduce the final temperature of the system by adding an extra entity that is resisting temperature increase.
sharpnova
43
A container contains a given mass of ice and a given mass of water both at 0 degrees Celsius. A given mass of aluminum is heated up to some temperature and submerged in the water-ice mixture. No heat enters or leaves the container. Given the specific heat of water and Aluminum and the energy it takes to melt a kilogram of ice, find the final temperature of the solution.
If we let the container absorb some heat and it has a given mass and a given specific heat, what will be the final temperature of the solution.
Q = C*M*T_change
I have solved the first part of the question. Just two equations in the unknown (final temperature) then solved for it.
The second part has me stumped though. It seems like I'd need to know the initial temperature of the container to solve this one. But no temperature was given for the container. Am I misunderstanding the question or overlooking something subtle? Or should I just assume the container starts at 0 degrees Celsius?
Q = C*M*T_change
Remember, no heat enters or leaves the container, according to the problem statement.
What does this tell you about the temperature of the container and the water-ice mixture?
I'm guessing that means it starts at 0 degrees Celsius but I don't understand why. I was thinking the "no heat enters or leaves" was just a magical constraint because if the container was cooler than room temperature then it should be bringing heat into the system... or if it's warmer then it should be radiating heat
sharpnova said:
I'm guessing that means it starts at 0 degrees Celsius but I don't understand why. I was thinking the "no heat enters or leaves" was just a magical constraint because if the container was cooler than room temperature then it should be bringing heat into the system... or if it's cooler then it should be radiating heat
Are you studying physics or magic?
Heat cannot be transferred to or from something without that something being at a different temperature than its surroundings. This is one of the laws of thermodynamics, specifically, the Zeroth Law:
https://en.wikipedia.org/wiki/Laws_of_thermodynamics
Sorry I wasn't clear. When I said that "I was thinking the 'no heat enters or leaves' was just a magical constraint" I was saying that I thought that a somewhat nonsensical constraint had been placed on the system in order to simplify the problem.
I assume by emphasizing that the constraint was not magical, that you are saying that it would actually be exhibited in this experiment.
So are you saying that the container would be at room temperature at the start?
Then I would think I'd need to know the room temperature to solve this problem.
If the container started at 0 degrees Celsius then it would be slightly cooling the room and the room would be slightly heating the container.
Or are you saying that the room-temperature and container temperature are both starting at 0?
Because even in this case the heated metal would raise the temperature of the container/water system which would in turn slightly cool the room and lose some of the energy that would be going into the container to the room.
Anyone?
sharpnova said:
Anyone?
Suppose that the container is capable of exchanging heat with its contents, but is insulated on the outside, so it can't exchange heat with the room. Also assume that the container is initially at 0 C. Also assume that not all the ice melts when the system equilibrates with the aluminum. What effect do you think including the container vs not including the container would have?
I believe it would then reduce the final temperature of the system since it would have a resistance to temperature increase that would suck up some of the thermal energy (and started at a lower temperature than the system's average at the start)
Assuming I have that right I think I understand it now.
I wasn't sure if I should assume the container started at 0 inside and didn't exchange with outside
Thanks for your help (if I'm understanding you correctly)
If all the ice doesn't melt, the final temperature of the contents must stay at 0C. The container temperature can't rise above 0 C because, if it did, the contents would cool it back down. So the container would stay at 0C, and its change in internal energy would be zero. So as long as there is ice remaining in the container, the container has no effect on the final state of the system. However, if all the ice melts, the container can increase in temperature along with the contents, and then, it would have an effect.
Related to Impact of container on final temperature of system
1. How does the material of the container affect the final temperature of the system?
The material of the container can affect the final temperature of the system in a few ways. First, certain materials may have a higher or lower thermal conductivity, meaning they can transfer heat more or less efficiently. This can impact how quickly the system reaches its final temperature. Additionally, some materials may absorb or reflect heat differently, which can also affect the final temperature.
2. Does the size or shape of the container make a difference in the final temperature of the system?
Yes, the size and shape of the container can have an impact on the final temperature of the system. A larger container may require more heat to reach the same final temperature as a smaller container. Similarly, a container with a larger surface area may allow for more heat transfer with the surrounding environment, which can affect the final temperature.
3. Can the lid or cover of the container affect the final temperature of the system?
Yes, the lid or cover of the container can have an impact on the final temperature of the system. A tight-fitting lid can help trap heat within the container, resulting in a higher final temperature. On the other hand, a loose or open lid can allow for heat to escape, resulting in a lower final temperature.
4. How does the initial temperature of the container affect the final temperature of the system?
The initial temperature of the container can impact the final temperature of the system in a few ways. If the container is at a significantly different temperature than the system, it can affect the rate at which the system reaches its final temperature. Additionally, if the container has a higher or lower initial temperature, it may require more or less heat to reach the desired final temperature.
5. Is the impact of the container on the final temperature of the system the same for all types of systems?
No, the impact of the container on the final temperature of the system can vary depending on the specific system in question. Factors such as the type of substance being heated, the amount of substance, and the desired final temperature can all play a role in how the container affects the final temperature of the system. Additionally, different systems may have different heat transfer mechanisms, which can also impact the role of the container in the final temperature.
