Impedances for RLC circuits in the limit of zero frequency
Let's see. I all starts from AC circuit theory. In the time domain the equation for an RLC circuit reads$$L \ddot{Q} + R \dot{Q} + \frac{1}{C} Q=U,$$where ##Q## is the charge on the capacitor. Now usually you are interested in AC with a given frequency ##\omega## and it's most convenient to use the complex approach with the understanding that the physical charge is the real part of the complex one.$$Q(t) = \Re \left( Q(t)e^{i\omega t} \right).$$If we insert the complex ##Q(t)## into the time domain equation, we get$$L
etotheipi
If a voltage source is sinusoidal, then we can introduce a phasor map and come up with equations like$$V_0 e^{i \omega t} = I(R + i\omega L + \frac{1}{\omega C} i)$$where ##I## would also differ from ##V## by a complex phase.
But if you set ##\omega = 0##, which would appear to correspond to the case where the source voltage is constant, you get nonsense results. If there is a capacitor then you get an infinity, and the effects of any inductor disappears completely (as if it were no longer in the circuit) because ##i\omega L = 0##.
I wondered if anyone could explain what's going on here. Is this approach only valid for a sinusoidal source? Or if not, then how do we interpret these weird results? If we were to solve the above example with ##\omega = 0## in the normal way, we'd be dealing with the constant coefficients differential equation ##\ddot{I} + \frac{R}{L}\dot{I} + \frac{1}{LC}I = 0##.
For ##\omega=0## you have the limiting case of time-independent fields and sources, i.e., magnetostatics. It's not so easy to take the limit ##\omega \rightarrow 0##.
Likes etotheipi
etotheipi said:
If a voltage source is sinusoidal, then we can introduce a phasor map and come up with equations like$$V_0 e^{i \omega t} = I(R + i\omega L + \frac{1}{\omega C} i)$$where ##I## would differ from ##V## by a complex phase.
Is this for a RLC in series?
Likes etotheipi
It should be, yes. Did I make a mistake?
etotheipi said:
It should be, yes.
If the equation describes the long term behavior (ω has been constant for a long time), then for ω = 0 the source voltage has been constant for a long time, the capacitor is charged, and I = 0. So the RHS is indeterminate, which is not wrong, but not useful to determine the LHS.
But take this with a grain of salt. I'm no expert on circuits.
Likes etotheipi
etotheipi said:
But if you set ω=0, which would appear to correspond to the case where the source voltage is constant, you get nonsense results.
That's a great question. Fortunately, it has a simple answer.
In AC analysis, we ignore the startup transient and ignore zero or nonzero initial conditions. Think of the source as V=0 when t<0 and V=sin(wt) when t>0. That's the startup transient. But we treat is as if the sin(wt) extended back to t= minus infinity.
But in your case, when w=0, the only conditions remaining are the initial conditions, so our sinusoidal equation reduces to a DC equation.
Likes cnh1995 and etotheipi
Interesting, so if I understand correctly the transient solution we'd get from solving ##\ddot{I} + \frac{R}{L}\dot{I} + \frac{1}{LC}I = 0## in the ##\omega = 0## case (which, even in underdamped conditions, would be enveloped by a negative exponential) would die away pretty quickly.
And if we were to instead use the AC analysis assumptions, we'd ignore that phase and go straight to our weird indeterminate solution, that @A.T. alluded to in #5.
etotheipi said:
... our weird indeterminate solution, that @A.T. alluded to in #5.
It's not that weird, if you think about it. If ω = 0 then any value of V will result in I=0 after a while. So you cannot reverse the relation to get a specific V from the final I, because I is the same for all V.
Likes etotheipi
There's another way to look at it. ##\ddot{I} + \frac{R}{L}\dot{I} + \frac{1}{LC}I = 0## is not the complete equation, because it ignores initial conditions. With initial conditions, we would also get decaying expotential terms superimposed.
Yet another way to look at it: sin(wt) is valid for ##-\infty < t < +\infty##. But adding an initial condition V=0 for t<0 makes it an aperiodic waveform. In your w=0 case, either V and I are zero for all time, or it is aperiodic.
Edit: I should have said, adding an initial condition V=0 and ##\frac{dV}{dt}=0## for t<0
Likes etotheipi
I just thought of a fun theorem to prove. Is it possible to generate a periodic solution with an aperiodic forcing function? No doubt, someone did that before, but it might be fun to prove from scratch.
The term in the brackets is the complex impedance ##Z## of a series RLC circuit. In case ##\omega\rightarrow 0##, the magnitude of the impedance becomes infinite, ##|Z| \rightarrow \infty##, viz. ##I\rightarrow 0##. Nothing strange.
Likes etotheipi
where ##Q## is the charge on the capacitor. Now usually you are interested in AC with a given frequency ##\omega## and it's most convenient to use the complex approach with the understanding that the physical quantities are the real part of the corresponding complex functions.
In addition we are only interested in the stationary final state, i.e., we don't consider the damped transient states but look a long time after having switched on the circuit (long means long compared to the damping time of the homogeneous solution of the linear ODE).
Then we can write
$$Q=Q_0 \exp(\mathrm{i} \omega t), \quad U=U_0 \exp(\mathrm{i} \omega t),$$
and the ODE turns into a linear algebraic equation,
$$(-L\omega^2 + \mathrm{i} \omega R +\frac{1}{C}) Q_0=U_0.$$
Of course we are rather interested in the current, which is
$$I=\dot{Q}=\mathrm{i} \omega Q_0 \exp(\mathrm{i} \omega t)\; \Rightarrow \; Q_0=-\mathrm{i} I_0/\omega,$$
leading to
$$Z I_0=\left (R+\mathrm{i} \omega L-\frac{\mathrm{i}}{\omega C} \right) I_0=U_0.$$
This example leads to the usual AC circuit theory for the stationary state. It works exactly as DC circuit theory when instead of resistances you use impedances for the various elements, i.e., ##Z_R=R## for a resistor, ##Z_L=\mathrm{i} \omega L## for a coil, and ##Z_C=-\mathrm{i}/(\omega C)## for a capacitor. This of course only works for ##\omega \neq 0##.
For ##\omega=0## you have ##U=U_0=\text{const}##, and of course the stationary state is ##Q=Q_0=\text{const}## and thus ##I=0## and ##\dot{I}=0##. Then the above ODE gets simply
$$\frac{Q_0}{C}=U_0=\text{const},$$
as it should be. There's of course no current because of the capacitor.
Likes etotheipi and Lord Jestocost
vanhees71 said:
Then we can write
Maybe a silly final question... do we also need account for a phase here, e.g. putting ##U = U_0 e^{i \omega t} e^{i \delta}##? I have the feeling that generally, excluding cases where we just have resistors, ##\delta## will often be non-zero.
What do you mean by phase? ##I_0## and ##U_0## are complex numbers. You can write them of course in "polar" form as ##I_0=|I_0| \exp(\mathrm{i} \phi_Q)## and ##U_0=|U_0| \exp(\mathrm{i} \phi_U)##. The same holds for ##Z=|Z| \exp(\mathrm{i} \phi_Z)##. Usually you are only interested in the relative phase shift between ##U## and ##I##, and that's encoded in ##\phi_Z##.
Likes etotheipi
Okay yes that makes sense if ##U_0##, ##I_0## etc. are complex, I thought you had used them for the magnitude only. Thanks for clarifying!
Yes, the term i/(ωC) in you original equation should be 1/(iωC) = -i/(ωC).
Likes etotheipi
Whoops, yes I meant to put it in the denominator. :doh:
If you think of each of the terms R, iωL, and 1/(iωC) as impedances (i.e V/I), then the 0 and ∞ values you get when ω→0 make sense. In a DC circuit an inductor behaves as a short circuit (|Z|=0), and a capacitor behaves as an open circuit (|Z|=∞). If you apply a finite voltage across each of these impedances individually you will either get I→0 or I→∞.
Likes etotheipi
Strictly speaking, no, not in linear circuits. The circuit would have to have no response at each of the frequencies of the forcing function but have a finite response at the periodic frequencies (the fundamental, natural response, plus perhaps harmonics). This, in the frequency domain, would look like a delta function (plus perhaps harmonics). Which is impossible to construct (it's not causal, I think). In practice, it's easy to approximate it, like a guitar string, or a high Q LC tank, for example.
Related to Impedances for RLC circuits in the limit of zero frequency
1. What is the significance of the limit of zero frequency in RLC circuits?
The limit of zero frequency in RLC circuits is important because it represents the behavior of the circuit at DC or steady state. In this limit, the reactance of the inductor and capacitor approach infinity, causing the circuit to behave like a purely resistive circuit.
2. How do you calculate the impedance of an RLC circuit at zero frequency?
The impedance of an RLC circuit at zero frequency can be calculated by simply adding the resistance of the circuit. This is because at zero frequency, the reactance of the inductor and capacitor disappear, leaving only the resistance to contribute to the impedance.
3. What is the effect of varying the resistance in an RLC circuit at zero frequency?
Varying the resistance in an RLC circuit at zero frequency will change the overall impedance of the circuit. A higher resistance will result in a higher impedance, while a lower resistance will result in a lower impedance. This can affect the behavior of the circuit and the flow of current.
4. How does the behavior of an RLC circuit change as the frequency approaches zero?
As the frequency approaches zero, the reactance of the inductor and capacitor decreases, causing the circuit to behave more like a purely resistive circuit. This means that the current will be in phase with the voltage and the power factor will approach 1.
5. Can an RLC circuit have a zero impedance at zero frequency?
No, an RLC circuit cannot have a zero impedance at zero frequency. This is because the resistance component of the impedance will always be present, and cannot be eliminated by changing the values of the inductance or capacitance. However, the impedance can approach zero as the frequency approaches zero.
  • Electromagnetism
