Implanting a barcode scanner/NFC/RFID reader
  • Thread starter Shauli
In summary, the conversation discusses the challenge of creating a small PCB with a reader that can identify a signal 0.5cm away. The options of using NFC, barcode, RFID, or optical identification are considered, with RFID being the preferred choice for its small module size. The discussion also touches on the possibility of adding additional parts on a larger PCB and the issue of attenuation and noise when the two PCBs are 2.5 meters apart. The conversation also briefly mentions the use of an external antenna and the possibility of stacking the coil and module to save space. Finally, the idea of using a degrading circuit or magnetic field for disposable identification is brought up as a potential solution.
Shauli
Hey there,
Let me give you some background;
I have PCB at around the size of 1.8cm X 6 cm , on this board I need to implant a reader (up to me which type - NFC/Barcode/Rfid/Any kind of optical identification) that can identify a signal 0.5cm away.
At first I thought using NFC is the best solution, however the antenna seems too large in my case as I don't have the spacing.
What should I do? Let's assume at this moment that pricing is not the problem.
Thanks,
Shauli
Hi
welcome to PF :smile:
is the reader ( whichever type) the only thing on this small board
how much of the reader can be on the board and how much situated elsewhere
that is ... just the sensor on the board or the whole reader system ?
physical size limitations may be a much bigger challenge than price
Likes Shauli
It'll be Rfid then. For that the reader size is a tradeoff for sensitivity//read distance: for 0.5cm distance you can get pretty small modules ready.
Likes Shauli
There are a lot more parts on the PCB; optical sensor, noise filter and such.
I am sort of trying to get a grip on what sizes are we talking about to conclude if this is even possible.
I
davenn said:
Hi
I can add additional parts on the main board which 2.5meters away (cable).Thanks again for the super quicky response.
got a link to something tiny that you had in mind ?
you may have to ... let's see if rive has something suitable in mind :smile:
Likes Shauli
Thanks for being so helpful!
Well, if the width is really so stritch then maybe this: https://shop.sonmicro.com/SM125-M1
For this external antenna coil is needed, but the requirements are easy to met. Can be used as module or chip, so it'll fit.
If there is some more space then the good old EM-18 which contains everything for that distance.
Likes Shauli
Hey Rive,
Thanks for the support on this matter.
I have few more questions;
I am not sure what kind of external antenna is needed, I mean the size of it is probably related to the distance that is needed so it should be small (hopefully). How should I choose the right one? Also, is it a good idea to place only the antenna on the smaller board, and the SM125 on the larger PCB - I am not really sure how problematic will the attenuation/noise be if the larger PCB is around 2.5meters away.
I am really not too familiar with RF so any help would be extremely useful.
Thanks,
Shauli
125kHz is not a big frequency, but 2.5m is out of spec anyway. You should put the module and the coil close to each other.
If you check the IND125 coils there (IND125-3 might be OK for you if you don't want to make one for yourself), you will see that the requirement is 860uH 10-12Ohm. That's all.
You have to find an online calculator for coil inductance/resistance, then pick a suitable size and calculate the turns. At the target distance it won't be really sensitive for quality, so you are free to do some experiments.
Likes Shauli
So if the antenna is 2.5 meters away from the module, nothing is going to work.
Well the module is 1x1.7 cm^2 and the antenna is 4.2x1.8 cm^2 so I'm not really sure how can I squeeze this whole thing together. Is looks like it might just not work.
I guess any other solution is custom?
The antenna won't interfere with the circuit, so you can put it on top of the module, for example.
Ot you can glue it on to the box if there is some room (guess it's not a project to be presented as bare PCB?).
The whole system is surprisingly insensitive to creativity...
Ps: you said you have something like 18*60mm or so? Stack up the coil and the module then.
Likes Shauli
Well in theory I, but when taking into account that there are few more parts other then the PCB on the board (I haven't measured exactly, just trying to get a figure on things).
Yeah, this is indeed a time for creativity.
Hey there,
Well it seems like the parts cannot fit to my design properly.
I was wondering; Is it possible to create some sort of a degrading circuit (instead of a readable barcode), that if a very low current passes through it for X amount of time, it stops working. Maybe even a magnetic field that depolarizes another magnetic field on a disposable unit.
Thanks,
Shauli
Related to Implanting a barcode scanner/NFC/RFID reader
1. How does implanting a barcode scanner/NFC/RFID reader work?
Implanting a barcode scanner, NFC, or RFID reader involves surgically inserting a small device under the skin that is capable of reading and transmitting information. These devices use wireless technology to communicate with external devices such as scanners or smartphones. When a barcode, NFC tag, or RFID tag is scanned, the implanted device sends the information to the external device, allowing for easy access to data or identification.
2. Is implanting a barcode scanner/NFC/RFID reader safe?
Implanting a barcode scanner, NFC, or RFID reader is generally considered safe. The devices are made of biocompatible materials and are small enough to minimize the risk of complications. However, as with any surgical procedure, there is always a small risk of infection, rejection, or other complications. It is important to consult with a trained medical professional and carefully consider the potential risks before undergoing the procedure.
3. What are the benefits of implanting a barcode scanner/NFC/RFID reader?
The main benefit of implanting a barcode scanner, NFC, or RFID reader is convenience. These devices eliminate the need for physical cards or key fobs, allowing for easy access to information or entry into secure areas. They can also be used for contactless payments, medical records, or tracking personal information. Additionally, these devices can be customized and updated, making them more versatile than traditional methods of identification.
4. How long does an implanted barcode scanner/NFC/RFID reader last?
The lifespan of an implanted barcode scanner, NFC, or RFID reader varies depending on the specific device and how it is used. On average, these devices can last anywhere from 2-10 years before needing to be replaced. Factors such as the frequency of use and the environment in which the device is implanted can also impact its lifespan.
5. Can an implanted barcode scanner/NFC/RFID reader be removed?
Yes, an implanted barcode scanner, NFC, or RFID reader can be removed if necessary. However, this should only be done by a trained medical professional. The removal process is similar to the initial implantation procedure and may involve a small incision. It is important to carefully consider the permanence of this procedure before undergoing it.
