Implicit Differentiation of 5=2x^2y+7xy^2
  • MHB
  • Thread starter karush
  • Tags
    Implicit
In summary, you are trying to find the derivative of the function $5=2x^2y+7xy^2$. You are integrating rather than differentiating and the derivative of a constant is 0.
karush
MHB
3,269
find dy/dx of
$$5=2x^2y+7xy^2$$
ok didn't know how to set this up with the $5=$
karush said:
find dy/dx of
$$5=2x^2y+7xy^2$$
When you take the derivative of both sides you wind up with \(\displaystyle \dfrac{d}{dx}(5)\). What is the derivative of a constant?
-Dan
5x
But how do we know it is x not y
karush said:
5x
You are trying to find the derivative \(\displaystyle \dfrac{dy}{dx}\) right?
\(\displaystyle 5 = 2x^2 y + 7x y^2\)
\(\displaystyle \dfrac{d}{dx}(5) = \dfrac{d}{dx} (2x^2 y) + \dfrac{d}{dx} (7x y^2) \)
-Dan
karush said:
5x
NO! You appear to be integrating rather than differentiating. The derivative of any constant is 0.
$\displaystyle \dfrac{d}{dx}(5) = \dfrac{d}{dx} (2x^2 y) + \dfrac{d}{dx} (7x y^2)$
d/dx
$0=4xy-2x^2yy'+7y^2-14xyy'$
isolate y'
$-2x^2yy'-14xyy'=4xy+7y^2$
$y'(-2x^2y-14xy)=4xy+7y^2$
simplify
$\displaystyle y'= \frac{(4 xy + 7 y^2)}{(-2x^2 - 14x y)}=- \frac{y (4 x + 7 y)}{2 x (x + 7 y)}$
d/dx
$0=4xy {\color{red}{+} 2x^2 y'}+7y^2 {\color{red}{+}} 14xyy'$
corrections ... try again
done try more!
$0=4xy-2x^2y'+7y^2-14xyy'$
isolate y'
$-2x^2y'-14xyy'=4xy+7y^2$
$y'(-2x^2-14xy)=4xy+7y^2$
simplify
$\displaystyle
karush said:
done try more!
isolate y'
simplify
$\displaystyle
Look more carefully at skeeter's post.
\(\displaystyle \dfrac{d}{dx}(2x^2 y) = 4xy + 2x^2y'\)
\(\displaystyle \dfrac{d}{dx}(7x y^2) = 7y^2 + 14xy y'\)
Why are you putting the negative sign in there?
-Dan
like this
$0=4xy+2x^2y'+7y^2+14xyy'$
isolate y'
simplify
$\displaystyle
FAQ: Implicit Differentiation of 5=2x^2y+7xy^2
What does "implicit dy/dx" mean?
"Implicit dy/dx" refers to the derivative of a function that is expressed implicitly, meaning that the dependent variable is not explicitly written in terms of the independent variable. In other words, the function is not in the form y = f(x).
How is "implicit dy/dx" different from "explicit dy/dx"?
The main difference between "implicit dy/dx" and "explicit dy/dx" is that in implicit differentiation, the dependent variable is not isolated on one side of the equation, making it more challenging to find the derivative. In explicit differentiation, the dependent variable is explicitly written in terms of the independent variable, making it easier to find the derivative.
What are some examples of functions that require implicit differentiation?
Functions that involve radicals, logarithms, and trigonometric functions often require implicit differentiation. For example, y^3 + x^2 = 5, ln(y) = x, and sin(xy) = 3x + 2y.
How do you find the derivative using implicit differentiation?
To find the derivative using implicit differentiation, you first take the derivative of both sides of the equation with respect to the independent variable. Then, you use the chain rule to differentiate any terms that involve the dependent variable. Finally, solve for dy/dx to get the derivative.
Why is implicit differentiation useful?
Implicit differentiation is useful because it allows us to find the derivative of a function that cannot be easily solved for y in terms of x. It is also essential in solving problems involving related rates, optimization, and implicit equations.
