Implicit Mapping Theorem for a Surface
In summary: Your name]In summary, Edward's question is about using the Implicit Mapping Theorem to represent a surface as a function of z near the point (0,2,1). The expert confirms that his approach is correct and clarifies that the theorem can be applied to a single equation. They also offer encouragement and advice for approaching problems.
Parmenides
37
The question, from Edward's Advanced Calculus (which is becoming a rather frustrating book), asks if the following surface can be represented as a function of ##z(x,y)## near the point ##(0,2,1)##:
[tex]xy - ylog(z) + sin(xz) = 0[/tex]
Naturally, this should invite me to use the Implicit Mapping Theorem, but I've seen this theorem presented mostly for systems of equations, rather than a single case. But anyhow, let the surface be called ##G({\bf{x}},{\bf{y}})##, where ##{\bf{x}} = (x,y)## and ##{\bf{y}} = z##. Then,
[tex]\frac{\partial{G}}{\partial{z}} = xcos(xz) - \frac{y}{z}[/tex]
So at ##(0,2,1)##, ##G'((0,2),(1)) = -2##. Thus, since the invertible "matrix" is non-singular, there exists a neighborhood near ##(0,2,1)## for which the surface can be represented as a function of ##z##.
I suspect this is correct, but being confused by some notation, I just wanted to make sure. Thanks.
Dear Edward,
Thank you for your question. You are correct in using the Implicit Mapping Theorem to approach this problem. The theorem can indeed be applied to a single equation, as long as it meets the criteria of being continuously differentiable and having a non-singular matrix.
In this case, your calculations and reasoning are correct. The partial derivative of G with respect to z is indeed -2 at the point (0,2,1), and since it is non-singular, there exists a neighborhood near (0,2,1) where the surface can be represented as a function of z.
I hope this helps clarify any confusion you had. Keep up the good work and don't let the frustration with the book discourage you. Sometimes, approaching a problem from a different angle can help make it more understandable. Best of luck with your studies.
FAQ: Implicit Mapping Theorem for a Surface
What is the Implicit Mapping Theorem for a Surface?
The Implicit Mapping Theorem for a Surface is a mathematical theorem that states that under certain conditions, a function can be expressed as the graph of a continuously differentiable function. This means that the graph of the function can be represented as a surface in three-dimensional space.
What are the conditions for the Implicit Mapping Theorem to hold?
The conditions for the Implicit Mapping Theorem to hold are that the function must be continuously differentiable and the Jacobian determinant of the function must be non-zero at a given point on the surface. In other words, the function must have a well-defined tangent plane at that point.
Can the Implicit Mapping Theorem be applied to any function?
No, the Implicit Mapping Theorem can only be applied to continuously differentiable functions. If the function is not continuously differentiable, the theorem does not hold and the function cannot be expressed as the graph of a surface.
What is the significance of the Implicit Mapping Theorem?
The Implicit Mapping Theorem is significant because it allows us to visualize and work with functions in three-dimensional space. This can be useful in many areas of mathematics and physics, such as in the study of surfaces and their properties.
How is the Implicit Mapping Theorem related to the Inverse Function Theorem?
The Implicit Mapping Theorem and the Inverse Function Theorem are closely related, as they both deal with the representation of functions in different forms. The Inverse Function Theorem states that under certain conditions, a function can be inverted, while the Implicit Mapping Theorem deals with the representation of a function as a surface. Both theorems involve the Jacobian determinant of the function and have similar conditions for their validity.
