Python Import python list from .txt file into Mathematica
The discussion revolves around importing a list of numbers from a k.txt file into Mathematica. The initial approach using ReadList["k.txt", String] results in the entire list being imported as a string, complicating the extraction of numbers. A user suggests an alternative method for exporting the list from Python to Mathematica, highlighting that the square brackets in the output pose a problem. The recommended solution is to modify the Python export code to use output.write(str(result)[1:-1]), which removes the square brackets, allowing Mathematica to read the data correctly using Import["k.txt", "CSV"]. The user expresses gratitude for the assistance received, indicating a strong appreciation for the community's support.
member 428835
Hi PF!
I am trying to import k.txt file into Mathematica as a list of numbers. The k.txt looks like this:
[5.315967917338153e-06, -3.204321972222162e-08, 3.6041782425371564e-09, -3.853442465663655e-08, 8.699510604529962e-07, -1.4284341965847237e-08, 2.855341882658808e-09, -1.1022087781880504e-08, 2.884254278951357e-07]
Currently I'm trying ReadList["k.txt", String] but this imports the entire list as a string (obviously) which I then don't know how to extract numbers. Any ideas? Alternatively, since k.txt is being created in Python, perhaps there's a way to export python list to mathematica list (I've googled it but can't seem to get it working).
Technology news on Phys.org
How are you exporting the list in Python?
Sorry, I'm using
Python:
    with open("k.txt", "w") as output:
        output.write(str(result))
where result is a list of numbers. Is there a better way so Mathematica can read it?
The square brackets are a problem. If you could export without them, then
Code:
should work.
Likes member 428835 and pbuk
Python:
# use
# instead of
Likes member 428835 and DrClaude
Wow, amazing! Thank you both so much. PF is a life saver. Gonna have to donate money now, because the help here is insane and I want it to keep running.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
