Importance of optical period in coherent radiation
Summary: In summary, the authors state that coherent radiation can occur in light-matter interactions even when considering lengths much smaller than the wavelength, due to phase coherence in the medium. However, they also mention that the regime where the time scale of the coherent bursts of radiation is shorter than the optical period is not physically possible. This is because it would require the atoms to emit radiation at a rate faster than the natural frequency of the light wave, which violates the laws of physics. This is not a limitation of coherent radiation, but rather a limitation of how fast atoms can emit radiation.
TheCanadian
367
I am reading a text on coherent radiation and not quite understanding a particular statement. To provide some background, the authors state that coherent radiation can arise from light-matter interactions even when considering lengths, ##L##, much smaller than the wavelength (i.e. ##V \sim L^3 << \lambda^3##) due to phase coherence in the medium if it satisfies certain conditions (e.g. initial population inversion, dephasing effects are negligible on the time-scale, ##T_P##, of the coherent bursts of radiation). Now the author states the following about the regime where ##T_P < \frac{\lambda}{c}##:
"This regime is not physical: in order to observe it, one would have to realize the inversion of the medium in a time shorter than the optical period."
It may be quite obvious what the author is saying, but why exactly cannot the burst occur on a timescale quicker than the optical period? If an ensemble of atoms, with ##L < \lambda## can coherently radiate, why can't atoms radiate on timescales of less than ##\frac {\lambda}{c}##? As long as they are sufficiently close and the interactions causal (i.e. ##T_P > \frac{L}{c}##), why can't coherent radiation occur? Perhaps at such high densities, dipole-dipole interactions may disrupt the process, but I don't quite understand the significance of ##T_P## being larger than the optical period. Any thoughts?
Thank you for your question regarding coherent radiation and the statement made by the authors in the text you are reading. I can understand your confusion and will try my best to provide a clear explanation.
Firstly, let's define what we mean by the optical period. The optical period is the time it takes for a light wave to complete one full cycle, which is equal to the wavelength divided by the speed of light, ##\frac{\lambda}{c}##. This is a fundamental property of light and is determined by the frequency of the light wave.
Now, let's consider the regime where ##T_P < \frac{\lambda}{c}##. This means that the time scale of the coherent bursts of radiation, ##T_P##, is shorter than the optical period. In other words, the burst of coherent radiation is occurring at a faster rate than the natural frequency of the light wave. This is not physically possible as it would require the atoms in the medium to undergo population inversion and emit radiation at a rate faster than the natural frequency of the light wave. This violates the laws of physics and is therefore not a physically realizable scenario.
To further understand this, let's consider the example of a pendulum. The natural frequency of a pendulum is determined by its length and mass. If we try to make the pendulum swing at a faster rate than its natural frequency, it will not be able to do so and will eventually stop. Similarly, in the case of coherent radiation, if we try to make the atoms emit radiation at a faster rate than the natural frequency of the light wave, it will not be able to do so and the process will eventually stop.
In summary, the statement made by the authors is highlighting the fact that the regime where ##T_P < \frac{\lambda}{c}## is not physically possible and cannot be observed in reality. It is important to note that this is not a limitation of coherent radiation itself, but rather a limitation of how fast atoms can emit radiation.
I hope this explanation helps to clarify the significance of ##T_P## being larger than the optical period. If you have any further questions, please do not hesitate to ask.
Related to Importance of optical period in coherent radiation
What is the definition of optical period?
The optical period, also known as the optical cycle or optical wavelength, is the time or distance it takes for one complete oscillation of electromagnetic radiation in the optical range. It is measured in seconds or nanometers.
Why is the optical period important in coherent radiation?
The optical period is important in coherent radiation because it affects the coherence of the radiation. Coherence refers to the synchronization of the waves in terms of their phase and amplitude. In order for radiation to be considered coherent, the waves must maintain a constant phase relationship, which is influenced by the optical period.
How does the optical period affect the properties of coherent radiation?
The optical period affects the properties of coherent radiation in several ways. Firstly, it determines the frequency of the radiation, which is directly related to its energy. Secondly, it affects the polarization of the radiation, which is the direction of the electric field. Lastly, it influences the diffraction and interference patterns of the radiation.
What is the relationship between the optical period and the speed of light?
The speed of light is inversely proportional to the optical period. This means that as the optical period decreases, the speed of light increases. This relationship is described by the formula: c = λf, where c is the speed of light, λ is the optical period, and f is the frequency of the radiation.
How is the optical period measured?
The optical period can be measured using various techniques, such as interferometry or spectroscopy. In interferometry, the interference patterns of two or more coherent waves are analyzed to determine the optical period. In spectroscopy, the absorption or emission spectra of a material can be used to calculate the optical period. Additionally, specialized instruments such as optical spectrum analyzers can provide direct measurements of the optical period.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
  • Math Proof Training and Practice
