Importance of the frequency of AC mains power lines
In summary, the rms voltage in much of the world is 240 V, with a peak voltage of 340 V. While the line voltage can vary depending on the total load, the frequency of 60 Hz or 50 Hz remains extremely steady. It is important to keep the frequency steady in order to maintain equal generating capacity to the load. Fluctuations in frequency can cause generators to go out of synchronism and can lead to large variations in load in small grids.
skepticwulf
74
From textbook: "In much of the world (Europe, Australia, Asia) the rms voltage is 240 V, so the
peak voltage is 340 V. The line voltage can vary, depending on the total load; the
frequency of 60 Hz or 50 Hz, however, remains extremely steady"
Why is it so important to keep it steady? what happens if fluctuations occur?
You wouldn't want different frequency sinusoidal outputs overlapping from different power stations.
I guess it is important to keep the frequency steady because otherwise all the devices that contain capacitors and/or inductors would have their power rating altered because the reactances of the inductors and/or capacitors inside the device depends on the frequency, and the power which depends on current, which depends on reactance. It is not only that the power rating will be altered but the operation of the device will be disturbed because the distribution of currents within the device elements will change (again due to the reactance changes due to frequency change).
I guess TV's and motors are also design for a specific Htz
Now that i read it more carefully, i think what the book is trying to say is that while load affects the rms/amplitude of the voltage of the line, load does not have any effect on the frequency of the line. What happens if fluctuations occur in the frequency (due to problems in the generators and the power plants i guess), me and Puma tried to answer in the previous posts.
To be operated in parallel, AC generators must be in synchronous frequency and providing proportional load, else the lagging machine will be driven as a synchronous motor with resultant increase in current. Load should not affect regulated voltage, imbalanced voltage regulators cause circulating reactive currents that will overload a machine just as real current.
look to the definition of reactance for the effect of varying frequency from nominal.
The generating stations are connected together in a grid system. If one station senses that the frequency of the grid is falling, it will automatically work harder to inject more energy. In addition, if the frequency changes, all the generators in the grid, which have a lot of inertia, will have to adjust their speed whilst remaining in synchronism.
The frequency is sensitive to load, because the turbines slow down if they have to work harder. With an electricity grid, all the alternators run in synchronism, but each one has a "cruise control" which senses frequency changes in the grid and controls the amount of steam being delivered to the turbine. The frequency is kept as constant as possible because that indicates that the generating capacity in the grid is equal to the load. If the frequency is allowed to change too quickly, generators will not be able to stay in synchronism, because of their large rotating mass.
Likes Delta2
Tech99 gave the best answer, "as constant as possible".
In huge grids, such as the USA eastern interconnection, frequency variations are tiny, because changes in load or generation are tiny compared to the grid.
In small grids, such as on an isolated island, the frequent variations are much larger, because variations in load can be large compared to the grid. I recall vacationing on Grand Canary Island and listening to the refrigerator motor rev up,and down. Another case in Queensland Austrailia, they had a drag bucket machine for coal mining. Every time that bucket hit the ground it added 25% to the total grid load.
Big or small, "as constant as possible" is the best answer.
Related to Importance of the frequency of AC mains power lines
1. Why is the frequency of AC mains power lines important?
The frequency of AC mains power lines is important because it determines the rate at which the alternating current switches direction. This is crucial for the proper functioning of electrical devices and systems that rely on a steady and consistent flow of electricity.
2. What is the standard frequency for AC mains power lines?
The standard frequency for AC mains power lines varies depending on the country, but it is typically either 50 Hz or 60 Hz. This frequency is chosen based on factors such as historical precedent, economic considerations, and compatibility with neighboring countries.
3. How does the frequency of AC mains power lines affect electrical equipment?
The frequency of AC mains power lines can affect electrical equipment in several ways. For example, a higher frequency can result in increased energy consumption and heat generation in devices. It can also affect the performance and lifespan of motors and other equipment that rely on precise timing.
4. What are the consequences of a mismatch in frequency between electrical devices and the AC mains power lines?
A mismatch in frequency between electrical devices and the AC mains power lines can lead to malfunctions, damage, or even failure of the devices. This is because the devices may not be designed to operate at the different frequency and may not be able to handle the increased energy or voltage.
5. Can the frequency of AC mains power lines be changed?
Yes, the frequency of AC mains power lines can be changed, although it is a complex and costly process. It typically involves adjusting the power grid infrastructure and replacing or modifying equipment such as transformers. Therefore, it is only done in special circumstances or by government agencies for specific purposes.
  • Electrical Engineering
  • Electromagnetism
