Impossible to understand physics teacher
In summary: I need to be able to see it in my head rather than just memorize the equation.I have read, I mean dissected chapter one, I don't have a problem with self-teaching because I've had to do that with a few of my classes so far ex: csc 201, which was c++ programming.
mathwhiz
Okay so I started my first calculus based physics class, the first day I realize he has a very bad accent but I feel like I might be able to understand him. The second day we really start getting into vectors, magnitude, cross product, dot product, etc, I'm sure the supposedly really easy stuff, if I had a professor I could understand. I believe I have a pretty good hold on the beginnings now, but I really need to find a good alternative book that I can use to help me get through this course because I have a good feeling this will be a self-taught class. Any suggestions would be greatly appreciated. Oh by the way I do have the study guide for my book and although it helps a little it isn't nearly enough.
Do you sit in the front row? That sometimes helps.
I found that spending 20 minutes reading about the material that will be covered in the next class makes it much easier to follow!
My first year college physics teacher was from China. Durta Wee was "Delta V". You will eventually catch on. Be patient. However, make use of tutors and don't wait until you are lost. Consider finding or forming a study group, as it can help you throughout your college years. Stay on top of the material, and go for help any time you are uncertain. All will be good.
Read the book yourself. Now is a good time to teach yourself how to learn independently.
My freshman calculus teacher was from BOSTON. I had to work out what "delters" and "omegers" were!
I once told my students that my main goal was to teach them to learn independently. They told me I was giving them a lot of practice at that!
Just picture this.
lol
I blame the way high school is structured. Everyone just expects to be spoon fed. Not many people develop the critical thinking needed to because they let other people do the thinking for them. How do we expect to let the future generations think for themselves if we do the thinking for them?
I know it sounds like pretty words and all, but there is nothing better to improve your critical thinking than trying to teach yourself. It doesn't do much justice to just memorize and regurgitate the information that is passed to you.
That's why I read the entire chapter and attempt the exercises before the lecture on the subject -- it seriously helps so much in aiding understanding.
Good. And it might also help the OP understand the professor a bit clearer.
One other thing that I want to add. It is sad that a percentage of students blame all of their inadequacies on the professors and refuse to independently learn the material after the class if they haven't understood something. You can usually see this on ratemyprofessors.com lol
Yes, I sit in the front row of all my classes
I guess I have a better grasp on than I though I had on chapter 1, because I got basically all the homework problems right.
I think my problem is going to be that I like to know exactly WHY something is a certain way for example why acceleration always points towards the center in circular motion, I believe knowing the why of things helps me really understand what I'm doing, but when I ask why he either doesn't understand the question, or in the case of acceleration pointing towards the center, I was told I would just have to accept the concept. That is why I was asking if there were any other good books, outside of the book and study guide for the book that I have. Maybe good books anyone has ran across.
Hahahaha I'm starting to key in on certain words he uses already, like teeta is "Theta" hahahaha.
This I will definitely start doing. Thank you
I'm afraid that IS just something you have to accept. It's exactly the same as how 'uniform gravity points downards' is just something we have to accept at that level.
I realize that clarifying this particular point wasn't the reason for your post, but an easy way to understand this is like this: for uniform circular motion of a particular angular velocity, and radius [itex]R[/itex], imagine you just have a mass sitting on a slippery surface attached by a string of length [itex]R[/itex] to a post. Now give the mass a push perpendicular to the string giving it the appropriate angular velocity. The mass will just whip around in a circle as the string stays taught. The only force acting on the mass is the string tension (which must be directed towards the post in the centre since tension is always parallel to the thing that's tense) and Newton's second law says that acceleration is always parallel to the net force. Thus, acceleration must be towards the centre. We can do this with any uniform circular motion, so we conclude that this is a true in general. This is a dynamical explanation and relies on some of your physical intuition, but I'd say qualifies as a "why" explanation. You can also construct a purely kinematic proof (that is, no mention of forces) by fiddling around with vector geometry, as your professor may have done.
As for your larger problem, hopefully you have an easier to understand (and somewhat motivated) TA for this class. I'll second what everyone said about using this an opportunity to improve your self-study skills. Fortunately, physics at the introductory level (and even more advanced levels) is pretty standard wherever you go, so you will likely be able to find explanations for things you're having trouble with online. For a supplementary text, you might find the first volume of the Feynman Lectures in Physics helpful. Khan Academy videos also have decent coverage for standard first year physics material, though perhaps at an overly simplified level.
That stuff is only easy compared to the hard stuff. I'm going into the final year of my undergraduate and the easy stuff still surprises me sometimes.
Make sure you also read about those subjects online. It's pretty easy to find material on that stuff and learning it from several different sources really helps retention.
For that example, your textbook should have some kind of explanation, at least a qualitative one using a vector diagram. Probably not in the first chapter, though.
It would help if you tell us which book you're using, so people don't waste time recommending it. (Tip: it helps to mention the authors, e.g. "Halliday, Resnick & Walker" rather than only the titles which are usually pretty generic.)
I agree completely, and understanding something makes it a whole lot easier to remember.
I found in that situation you either have to figure it out yourself, accept it or find someone else who can answer it, the first is definitely the most rewarding of the three (Dopamine!).
I came across a related question today: "Show that the acceleration of a particle always points toward the concave side of its path."
The book we use is Sears & Zemansky's University Physics with Modern Physics, Young and Freedman
FAQ: Impossible to understand physics teacher
Why does my physics teacher always seem to speak in complex jargon that is impossible to understand?
It is common for physics teachers to use technical terms and jargon in order to accurately convey complex concepts. This can be overwhelming for students who are not familiar with these terms. However, it is important to communicate with your teacher and ask for clarification when needed.
How can I make sense of the equations and formulas my physics teacher uses?
Understanding equations and formulas in physics requires a thorough understanding of the underlying concepts. It is important to practice and review regularly, and seek help from your teacher or peers when needed. Additionally, breaking down equations into smaller parts and understanding each component can also help with comprehension.
Why does my physics teacher seem to have a different approach to teaching than other teachers?
Physics is a subject that requires critical thinking and problem-solving skills. Therefore, many physics teachers use a more hands-on and interactive approach to teaching, rather than simply lecturing. This can be challenging at first, but it allows for a deeper understanding of the subject.
How can I keep up with the fast pace of my physics class?
Physics is a subject that builds on previous concepts, so it is important to stay on top of your learning and not fall behind. This can be done by actively participating in class, taking thorough notes, and reviewing material regularly. It is also helpful to seek extra help from your teacher or a tutor if needed.
What can I do if I still don't understand my physics teacher after trying different study methods?
If you are still struggling to understand your physics teacher, it is important to communicate with them and express your concerns. They may be able to provide additional resources or explanations to help you understand the material better. It can also be helpful to form study groups with classmates to discuss and work through difficult concepts together.
