MHB Improper integral (ThinleyDs question at Yahoo Answers)
The integral of exp(-b(x-a)^2) from -infinity to +infinity converges only if b is greater than zero. By substituting t = √b(x-a), the integral simplifies to a form involving Euler's integral. The calculation shows that the integral evaluates to √(π/b). This result is derived using the properties of the gamma function, specifically Γ(1/2). The final answer is that the integral equals √(π/b).
Mathematics news on Phys.org
Hello ThinleyD,
Necessarily $b>0$, otherwise the integral is divergent. Using the substitution $t=\sqrt{b}(x-a)$: $$\int_{-\infty}^{+\infty}e^{-b(x-a)^2}\;dx=\frac{1}{\sqrt{b}}\int_{-\infty}^{+\infty}e^{-t^2}\;dt=\frac{2}{\sqrt{b}}\int_{0}^{+\infty}e^{-t^2}\;dt$$ We get the well known Euler's integral. Using $u=t^2$: $$\int_{0}^{+\infty}e^{-t^2}\;dt=\int_{0}^{ + \infty} e^{-u}\frac{du}{2\sqrt{u}}=\frac{1}{2}\int_{0}^{ +\infty}e^{-u}u^{-\frac{1}{2}}\;du=\frac{1}{2}\Gamma\left(\frac{1}{2}\right)=\frac{\sqrt{\pi}}{2}$$ As a consequence: $$\boxed{\displaystyle\int_{-\infty}^{+\infty}e^{-b(x-a)^2}\;dx=\sqrt{\frac{\pi}{b}}}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
