sharpener
- 5
- TL;DR Summary
- Will circulating the water in a hot water tank improve the rate of heat transfer from the heating coil?
A typical UK domestic hot water tank holds c. 200 litres of water. Hitherto the common method of heating it to say 60C has been by means of an internal coil of copper pipe through which is pumped hot water from a gas boiler at ~ 70C. Heat transfer on the outside of the coil is by natural convection in the tank.
The advent of heat pumps has resulted in lower available temperatures and so a widespread recommendation is to use special "heat pump" hot water tanks which have a coil with 3 to 4 x the surface area. This results in many heat pump installers insisting on replacing tanks that are otherwise perfectly sound.
It occurs to me that the heat transfer might be improved by circulating the body of water in the tank to replace the heated water in contact with the coil with fresh colder water more quickly than can be achieved by convection alone. This could be done by adding a small external pump which would cost only a fraction of replacing the whole tank.
Can someone tell me if this idea would give a worthwhile improvement and say what factor it might be, or point me to a calculation method or empirical heat transfer coefficient I can use for this?
TIA
TIA
