Impulse and momentum in one dimension - Two carts are moving
In summary: The compression of the spring is the same in all frames of reference, so why are you so anxious to switch...In summary, a head-on collision between two carts moving at different speeds results in the carts moving at the same speed and the spring being compressed by 1.14 m/s.
Specter
120
[/B]
In an elastic head-on collision, a 0.60 kg cart moving at 5.0 m/s [W] collides with a 0.80 kg cart moving at 2.0 m/s [E]. The collision is cushioned by a spring (k=1200 N/m).
a) Find the velocity of each cart after the collision
b) Find the maximum compression of the spring.
Conservation of energy
1/2 mv^2
[/B]
I'm not sure if this question is correct so any help would be great.
a) Find the velocity of each cart after the collision.
Let east be positive.
Drawing the carts in different frames of reference
https://i.imgur.com/56uRFk8.png
Cart 1 (.80kg) is the moving mass and cart 2 is stationary.
v1f=m1-m2/m1+m2 v1o
= 0.80-0.60 / 0.80+0.60 (7.0)
= 1.0
Switch back to Earth's frame of reference by adding (-5.0).
1.0 + (-5.0)= -4.0
Cart 1 is moving at 4.0 m/s [W] after the collision
Cart #2:
v2f=2m1/m1+m2v1o
=2(0.80)/0.80+0.60 (7.0)
= 8.0
8.0 + (-5.0) = 3.0
Cart 2 is moving at 3.0 m/s [E] after the collision.
This is where I am having the most trouble. I have seen different answers online than what I arrive at.
To find the maximum compression of the spring I need to know fast the carts are moving when the spring is at max compression.
PTO=PTF
m1v1o+m2v2o=(m1+m2)vf
(0.80)(2.0)+(0.60)(0)=(0.80+0.60)vf
1.6=1.4
=1.14 m/s
At max compression the two carts are moving at 1.14 m/s.
Now use conservation of energy to find the maximum compression.
1/2 m2v1o2+1/2 m2v2o2=1/2(m1+m2)v2f2+1/2 kx2
1/2 (0.8)(2.0)2+1/2 (0.6)(-5)2=1/2 (0.8+0.6)(3.0)2+1/2 (1200)x2
9.1 = 6.3+600x2
9.1 = √606.3
9.1 = 24.62315
2.17 m
I don't know what I did wrong but the answers I have seen online are around 0.12m. Where did I go wrong? I've looked it over many times and I can't figure it out.
PTO=PTF
You seem to have gone wrong here. You have speeds on ##2.0 m/s## and ##0 m/s##.
Okay so this is what I have done.
(0.8)(2.0)+(0.6)(-5)=(0.8+0.6)Vf
-1.4 =1.4
=-1.0
=1.0 m/s [W]
So is this answer v2f? Is this the number that will get substituted into the conservation of energy for v2f? Would I use -1.0 or 1.0 [W] when substituting?
Thanks!
-1.4 =1.4
=-1.0
=1.0 m/s [W]
Thanks!
Okay, although maybe you could have stayed in the rest frame of one of the masses, as you did for part a).
KE involves ##v^2## so the direction doesn't matter.
What do you mean by stayed in the rest frame? Do you mean use the speeds 7.0 and 0.0 instead of 2.0 and -5.0? I'm a bit confused.
The calculations look easier, as in part a), with only one mass initially moving.
Likes Specter
So if I use the speeds of the reference frame where only one mass is moving I would have to add (-5) to my end answer to switch it back to Earth's reference frame just like in part a, right?m1v1o+m2v2o=(m1+m2)vf
(0.8)(7.0)+(0.6)(0.0)=(0.8+0.6)Vf
5.6=1.4
=4
Switch back to Earth's reference frame by adding -5.
4+(-5)=-1 m/s
5.6=1.4
=4
Why not keep going in that frame?
I didn't know I could do that! So would I substitute 4 into the conservation of energy? When do I switch back to Earth's frame of reference?
The compression of the spring is the same in all frames of reference, so why are you so anxious to switch back?
I thought that I would get a different answer if the velocity was different. Wouldn't the maximum compression be different if the velocity were 1 instead of 4?
You mean the maximum compression is frame dependent?
PS why not do the calculations in both frames - just to see?
I guess it wouldn't be frame dependant. I tried this but I guess I'm still doing something wrong.
Here's my work for the frame when only one mass is moving:
1/2 (0.8)(7.0)2+1/2(0.6)(0)2=1/2(0.8+0.6)(4)2+1/2(1200)x2
19.6=11.2+600x2
8.4=600x2
x=√0.014
x=0.12Here's my work for the frame when both masses are moving:
1/2 (0.8)(2.0)2+1/2(0.6)(5.0)2=1/2(0.8+0.6)(1)2+1/2(1200)x2
9.1 = 0.7 +600x2
8.4=600x2
x=√0.014
x=0.12Edit: Forgot to add my answers
19.6=611.2x2
That's just an error. I've no idea where you got ##611.2## from. ##\frac12(1200) = 600##, surely?
9.1 = 0.7 +600x2
I'm still pretty confused.
That looks right. Just solve for ##x##.
Likes Specter
From my post above. I edited it to include my answers.
19.6=11.2+600x2
8.4=600x2
x=√0.014
9.1 = 0.7 +600x2
8.4=600x2
x=√0.014
x=0.12
Does this look correct? I assume it is because both answers are the same.
Thanks for your help!
Likes PeroK
19.6=11.2+600x2
8.4=600x2
x=√0.014
9.1 = 0.7 +600x2
8.4=600x2
x=√0.014
x=0.12
Looks right.
Are you familiar with Newton's Experimental Law? It's mainly for partially elastic cases, but in the special case of fully elastic it can be derived from the momentum and energy conservation laws and has the advantage of avoiding quadratics. It says the relative velocity (regardless of mass) merely swaps sign. So if the first mass bounces back at speed u West and the second bounces back at speed v East then u+v=5+2=7 m/s.
Likes Specter
haruspex said:
Looks right.
I've never heard of it but I will keep that in mind. Thanks!
Related to Impulse and momentum in one dimension - Two carts are moving
1. What is the difference between impulse and momentum?
Impulse is the change in momentum of an object over a period of time, while momentum is the quantity of motion an object has.
2. How is momentum calculated?
Momentum is calculated by multiplying an object's mass by its velocity.
3. Can two objects have the same momentum but different masses?
Yes, two objects can have the same momentum if their masses and velocities are different. This is because momentum takes into account both mass and velocity.
4. How do collisions affect momentum and impulse?
In a collision, momentum is conserved, meaning that the total momentum of the objects before and after the collision remains the same. Impulse is also affected, as it is equal to the change in momentum during the collision.
5. How can we use impulse and momentum to analyze the motion of two carts?
By measuring the masses and velocities of the two carts before and after a collision, we can calculate the change in momentum and the impulse experienced by each cart. This can help us understand the forces involved in the collision and how the carts' motions are affected.
