Impulse and Momentum problem on skaters
In summary, the conversation discusses a problem involving impulse and momentum with two skaters colliding and moving off at an angle. The main concept needed to solve the problem is the conservation of momentum, treating velocities as vectors. The final angle and speed can be found by using the Pythagorean theorem and setting the initial momentums equal to the new mass of the skaters together.
DMOC
100
[SOLVED] Impulse and Momentum problem on skaters
A 50.0-kg skater is traveling due east at a speed of 3.00 m/s. A 70.0-kg skater is moving due south at a speed of 7.00 m/s. They collide and hold on to each other after the collision, managing to move off at an angle theta south of east, with a speed of v(f). Find (a) the angle theta and (b) the speed v(f), assuming that friction can be ignored.
Tangent of
Momentum = mass * volume
I first decided to find the angle theta. I drew a picture on a separate sheet of paper (sorry, I don't have a way of posting an image here, but it should be easy to reproduce) to make the problem look easier. I used tan theta=(opposite/adjacent) but I got 66.8 degrees as my answer with 7 as the opposite and 3 as the adjacent, whereas my answer booklet says 73.0 degrees. I thought velocities could be treated as vectors.
Also, for part b, the answer is 4.28 m/s, but I also don't know how to get this answer. I thought I could use the pythagorean theorem, but that doesn't work. It seems like I'm missing some vital concepts here. Any help would be appreciated.
The "vital concept here" is simply conservation of momentum. we have 2 objects each moving in one direction then they collide and begin moving in a 2 dimensional path. So find the initial momentum south m*v and set it equal to the new mass of the skaters together. This will give us the first component of our final velocity vector. Then do the same with the eastward momentum. then once you have a final east velocity and a south velocity you can add them using the Pythagorean theorem.
Hi DMOC! :smile:
You're finding the relative velocity! :rolleyes:
Hint: momentums can be treated as vectors also. :wink:
Thank you! I found both answers (well, I got 4.27 m/s for part b but that's just 0.01 off) correctly!
FAQ: Impulse and Momentum problem on skaters
What is the relationship between impulse and momentum in the context of skaters?
The relationship between impulse and momentum in the context of skaters is that impulse is the change in momentum that occurs when a skater applies a force to their body, such as pushing off the ground or changing direction. This change in momentum affects the skater's speed and direction of motion.
How does the mass of a skater affect their momentum?
The mass of a skater directly affects their momentum. The more mass a skater has, the more momentum they will have, meaning they will be harder to stop or change direction. This is why larger skaters, such as professional ice hockey players, have a harder time stopping or changing direction compared to smaller skaters.
Can you explain the concept of conservation of momentum in the context of skaters?
Conservation of momentum states that in a closed system, the total momentum before an event will be equal to the total momentum after the event. In the context of skaters, this means that the initial momentum of the skaters before they interact (e.g. one skater pushing off the other) will be equal to the final momentum of the skaters after the interaction.
How do you calculate the impulse on a skater?
The impulse on a skater can be calculated by multiplying the force applied to the skater by the time interval over which the force is applied. This can be represented by the equation I = F * Δt, where I is the impulse, F is the force, and Δt is the time interval.
What factors can affect the momentum of a skater?
The momentum of a skater can be affected by factors such as their mass, speed, and direction of motion. Additionally, external forces such as friction or air resistance can also affect a skater's momentum. For example, if a skater is moving at a constant speed on a flat surface, the net external force on them is zero and their momentum will remain constant. However, if they encounter a hill, the force of gravity will act on them and change their momentum.
