How to Calculate Impulse and Average Net Force in a Baseball Collision
In summary: Have a good night!In summary, the conversation involves a student seeking help with a physics problem involving a baseball being struck by a bat. The problem requires finding the impulse experienced by the ball and the average net force acting on it. The conversation includes the homework statement, given values, homework equations, and the attempt at a solution. The solution includes breaking down vectors into components and calculating the magnitude and direction of the change in momentum, as well as the net force experienced by the ball. The conversation ends with a student thanking the expert for their help and planning to continue working on the remaining questions.
SohailS
Hello, I am taking physics 12U through correspondence. I am having issues with this problem. I don't know why but I feel like I made a mistake in this. Can you guys check this question and verify my results.
Thanks, very much. :smile:
A baseball with a mass of 0.152 kg is moving horizontally at 32.0 m/s [E], when it is struck by a bat for 0.00200 seconds. The velocity of the ball just after the collision is 52.0 m/s [W 20° N].
a) Find the impulse experienced by the ball. (6 marks)​
b) Find the average net force of the ball. (2 marks)​
Given:
[itex]m_{} = 0.152 kg[/itex]​
[itex]v_{1} = 32.0 m/s [E][/itex]​
[itex]t{} = 0.00200 s[/itex]​
[itex]v_{2} = 52 m/s [W 20° N][/itex]​
[itex]\vec{ΔP}=\vec{F}_{NET}Δt[/itex]​
[itex]F_{NET}Δt=m(v_{2}-v_{1})[/itex]​
a)​
[itex]\vec{ΔP}=?[/itex]​
Break down vectors into components
solve for components
[itex]\vec{P}_{x}=0.152(-45.033-32)=-11.7 Ns[/itex]​
[itex]\vec{P}_{y}=0.152(26-0)=39.52 Ns[/itex]​
[itex]P=\sqrt{(-11.7)^{2}+(39.52)^{2}}=41.2 Ns[/itex]​
[itex]θ=tan^{-1}\frac{39.52}{11.7}=73°[/itex]​
[itex]∴\vec{ΔP}=41.2 Ns [W 73° N][/itex]​
b)​
[itex]F_{NET}Δt=41.2 Ns[/itex]​
[itex]\vec{F}_{NET}=\frac{41.2}{0.002}=20,609 N [W 73° N] [/itex]​
Check your arithmetic here.
Thanks for pointing that out. I have corrected that error.
Is there anything else wrong with the solution?
[itex]\vec{P}_{y}=0.152(26-0)=3.952 Ns[/itex]​
[itex]P=\sqrt{(-11.7)^{2}+(3.952)^{2}}=12.4 Ns[/itex]​
[itex]θ=tan^{-1}\frac{3.952}{11.7}=19°[/itex]​
[itex]∴\vec{ΔP}=12.4 Ns [W 19° N][/itex]​
b)​
[itex]F_{NET}Δt=12.4 Ns[/itex]​
[itex]\vec{F}_{NET}=\frac{12.4}{0.002}=6179 N [W 19° N] [/itex]​
Check your computation of those components of the final velocity.
Wow, I can't believe I did that. I used 30 degrees instead of 20 there. hah!
I need to pay attention when I input the values into the calculator.
I have made the changes. Please let me know if you see anything else wrong with it. particularly part b) I don't know if that is how it is supposed to be calculated.
[itex]\vec{P}_{x}=0.152(-48.86-32)=-12.29 Ns[/itex]​
[itex]\vec{P}_{y}=0.152(17.79-0)=2.703 Ns[/itex]​
[itex]P=\sqrt{(-12.29)^{2}+(2.703)^{2}}=12.58 Ns[/itex]​
[itex]θ=tan^{-1}\frac{12.29}{2.703}=78°[/itex]​
[itex]∴\vec{ΔP}=12.6 Ns [W 78° N][/itex]​
b)​
[itex]F_{NET}Δt=12.6 Ns[/itex]​
[itex]\vec{F}_{NET}=\frac{12.6}{0.002}=6300 N [W 78° N] [/itex]​
I think you mixed up your components when calculating the angle.
Other than that, your solution looks good. (Since the force of the bat is so much greater than the weight of the ball, it's OK to ignore the weight of ball in calculating the net force from the bat.)
Thanks, I am going to get some sleep and then do the rest of the questions. I really botched that lol.
I really appreciate your help.
FAQ: How to Calculate Impulse and Average Net Force in a Baseball Collision
What is the Impulse Baseball problem?
The Impulse Baseball problem is a physics problem that involves determining the change in momentum of a baseball after it is hit by a bat.
What factors affect the impulse of a baseball?
The impulse of a baseball is affected by the mass of the baseball, the velocity of the baseball before and after impact, and the time of impact between the ball and the bat.
How is the impulse of a baseball calculated?
The impulse of a baseball is calculated by multiplying the force applied to the baseball by the time of impact. This can be represented as the equation J = F * ∆t.
How does the impulse of a baseball affect its trajectory?
The impulse of a baseball affects its trajectory by determining the direction and speed of the baseball after impact. The greater the impulse, the greater the change in momentum and therefore, the greater the change in trajectory.
Why is the Impulse Baseball problem important?
The Impulse Baseball problem is important because it helps explain the physics behind hitting a baseball and can be applied to other sports and real-life situations. It also helps scientists and engineers design better equipment and improve athletic performance.
