Impulse Question (Really Difficult)
  • Thread starter ll Source ll
  • Tags
    Impulse
In summary, a bird with a mass of 52 g is initially perched on a swing with a mass of 153 g and a height of 8 cm. The bird takes off horizontally at 2 m/s and we need to find the height that the base of the swing will rise to. By considering the bird as a projectile, we can use the conservation of momentum to determine that the perch will have an equal and opposite momentum backwards. This can help us find the height of the swing.
ll Source ll
A bird is initially perched on a swing with a mass of 153 g. The bird has a mass of 52 g. The swing is 8 cm below the point of attachment to the top of the cage. The bird/swing are initially at rest. The bird takes off horizontally at 2 m/s. How high will the base of the swing rise above its original level? Disregard friction.
Where do i start?
ive used several formulas that don't work out i just need to know which formula to use I am completely and utterly lost on this problem. I've tried m1v1 + m2v2 = m1v1f + m1v1f , didnt work. and mgh = 1/2mv^2. Any help ? :(
What's the momentum of the bird when it leaves? The perch will have an equal and opposite momentum backwards. (This is treating the bird as more of a projectile than a flyer - but I think that's the intent of the problem).
sweet thanks dood! :) (I figured it out)
FAQ: Impulse Question (Really Difficult)
What is an impulse question?
An impulse question is a type of question that is designed to challenge the person being asked. It typically requires a high level of critical thinking and problem-solving skills to answer.
How do you come up with an impulse question?
An impulse question can be created by thinking about a topic from a unique or unconventional perspective. It should also have multiple layers and require the person to think outside of the box.
What is the purpose of an impulse question?
The purpose of an impulse question is to stimulate critical thinking and encourage individuals to approach a problem or topic in a new and creative way. It can also help to deepen understanding and uncover new insights.
Are there any tips for answering an impulse question?
When faced with an impulse question, it is important to take a moment to fully understand the question and consider all possible angles. It can also be helpful to break the question down into smaller parts and tackle each one individually.
Can anyone answer an impulse question?
Yes, anyone can answer an impulse question. However, it may require practice and training in critical thinking and problem-solving skills to effectively answer these types of questions. With practice, anyone can improve their ability to answer impulse questions.
