Impulsive delta v hyperbolic and elliptical orbit
In summary, the Cassini spacecraft approached Saturn on July 1, 2004 with a hyperbolic excess velocity of 5.5 km/s and a closest approach distance of 80,680 km. To transfer the spacecraft into a 116-day elliptical orbit with the same periapsis point as the approach trajectory, an impulsive ΔV maneuver would be required. Using the equation vinf = √(GM/a), a semi-major axis of 1,253,923 km is calculated. Further calculations would be needed to determine the initial and final velocities of the spacecraft for the transfer.
orbitsnerd
On July 1, 2004, the Cassini spacecraft approached
Saturn with hyperbolic excess velocity 5.5 km/s to
swing by the planet at the closest approach distance
rp = 80,680 km. Compute the impulsive ΔV
required for a maneuver performed at the closest
approach to Saturn to transfer the Cassini spacecraft
into a 116-day elliptical orbit having the same
periapsis point as the approach (hyperbolic)
trajectory.
rp=80,680 km
vinf=5.5 km/s
T=116 days
GMsaturn=3.7931187e7 km^3/s^2
vinf=sqrt(GMsaturn/a)
I know it is an in-plane maneuver going from a hyperbolic approach to an ecliptic approach. If the vinf=sqrt(GM/a) is correct, I get a=1,253,923 km.
I am pretty much lost on how to complete this problem. I have done previous examples of Hohmann transfers and heliocentric orbits including the various velocities involved. Any help would be appreciated.
Thanks!
Hi orbitsnerd, welcome to PF!:smile:
What does vinf physically represent? Does that really correspond to the value of 5.5km/s excess velocity you are given?
What must be true of the total energy (kinetic plus gravitational potential) of Cassini for it to be captured by Saturn's gravity? If Cassini is traveling at 5.5km/s in excess velocity, doesn't that mean it is traveling 5.5km/s too fast to be captured? What does that tell you it's total energy is? What would its total energy be if it were traveling in a 116 Day elliptical orbit having the same
periapsis point as the approach (hyperbolic)? What is the difference in these two energies? What chance in speed would account for this difference?
I was able to begin the problem (so I hope) this way:
T=2Pi sqrt(a^3/mu) where a=299290 km
e=1-(rp/a) so e=.7304
a=ra+rp/2 where ra=517900 km
vp=sqrt((2mu/rp)-(2mu/rp+ra))=28.53 km/s
I am using mu=musaturn=3,7931187e7 km^3/s^2.
Is this this correct initial approach? I am still a bit lost by what you meant by 5.5 km/s not being vinf.
For the energy equation are you referring to the E=(v^2/2)-(mu/r)?
Thanks.
I haven't checked your numbers, but your approach looks good.:approve:
This tells you what final speed you want the satellite to have at the periapsis point. Now you need to find its initial speed at that point...
If I told you that the velocity of the spacecraft was 5.5km/s in excess of 100km/s, would you tell me its velocity was 5.5kms or 105.5km/s?
In this case, the "hyperbolic excess velocity of 5.5km/s" tells you that the spacecraft is traveling 5.5km/s faster than the maximum velocity it could have if it were in a bounded orbit. You'll need to figure out what that maximum velocity is if you want to find the velocity of the spacecraft .
Thanks.
Close, shouldn't the mass of the satellite be in that equation as well?
FAQ: Impulsive delta v hyperbolic and elliptical orbit
1. What is an impulsive delta v hyperbolic orbit?
An impulsive delta v hyperbolic orbit is a type of orbit in which a spacecraft makes a single instantaneous burn (impulse) to change its velocity (delta v) and enter a hyperbolic trajectory. This type of orbit is typically used for interplanetary missions or for spacecraft entering or leaving a planet's sphere of influence.
2. How is an impulsive delta v hyperbolic orbit different from a regular orbit?
In a regular orbit, the spacecraft's velocity changes continuously over time due to the gravitational pull of the central body. In an impulsive delta v hyperbolic orbit, the spacecraft's velocity changes abruptly in a single moment, causing it to enter a hyperbolic trajectory instead of a closed elliptical orbit.
3. What are some applications of impulsive delta v hyperbolic orbits?
Impulsive delta v hyperbolic orbits are commonly used for interplanetary missions, such as flybys of other planets or moons, or for spacecraft entering or leaving a planet's sphere of influence. They can also be used for spacecraft to escape Earth's orbit and travel to other planets or deep space.
4. What is an elliptical orbit?
An elliptical orbit is a type of orbit in which a spacecraft travels around a central body in an oval-shaped path. This type of orbit can have varying levels of eccentricity (how elongated the ellipse is) and can be used for various purposes, such as communication satellites, weather satellites, and scientific missions.
5. How do impulsive delta v hyperbolic orbits differ from elliptical orbits?
Impulsive delta v hyperbolic orbits are different from elliptical orbits in that they are not closed trajectories and do not return to their starting point. They also require a single instantaneous burn to enter the orbit, whereas elliptical orbits are achieved through a continuous application of thrust over time. Additionally, impulsive delta v hyperbolic orbits are typically used for interplanetary travel, while elliptical orbits can be used for a variety of purposes including communication and scientific missions.
