Impulsive force due to a falling chain
In summary, a uniform chain with mass M and length L is released from rest in a vertical position, with its lower end touching the floor. As the chain falls, any portion that strikes the floor comes to rest. To calculate the force exerted by the chain on the floor when a length x has reached the floor, we assume that the chain is made up of small mass elements and an impulsive force from the floor brings each of these elements to rest. Taking into account the impulse and change in momentum, the correct answer is 3Mgx/L, which includes the normal force from the floor.
vikvaryas1
A uniform chain of mass M and length L is held in vertically in such a way that its lower end just touches the floor. The chain is released from rest in this position. Any portion that strikes the floor comes to rest. Assuming that the chain does not form a heap on the floor, calculate the force exerted by it on the floor when a length x has reached the floor.
I assumed chain that the chain is made up of many small mass elements and an impulsive force exerted by the floor brings each of these to rest.
Velocity of the mass element at height of x when it reaches the ground is √2gx
Impulse is change in momentum by time that is (m*v-m*0)/dt.
m=M*dx/L
So Impulse = Mv*dx/dt*(1/L)
=Mv2/L
v=√2gx
so 2Mgx/L
But the answer was given as 3Mgx/L
Please show where i was wrong
You missed the normal force due to floor. :wink:
Ok i got it thanks.
Related to Impulsive force due to a falling chain
1. What causes the impulsive force in a falling chain?
The impulsive force in a falling chain is caused by the sudden change in momentum as the chain accelerates towards the ground. This change in momentum creates a force that is transmitted through the chain and can be felt by the hand holding the end of the chain.
2. How does the length of the chain affect the impulsive force?
The length of the chain does not have a significant effect on the impulsive force. As long as the chain is falling freely, the impulsive force will be the same regardless of its length. However, a longer chain will take longer to reach the ground, resulting in a longer duration of the impulsive force.
3. Is the impulsive force always in the same direction as the falling chain?
Yes, the impulsive force is always in the same direction as the falling chain. This is due to the fact that the force is caused by the change in momentum in that direction as the chain falls towards the ground.
4. Can the impulsive force be measured?
Yes, the impulsive force can be measured using a force sensor or by calculating the change in momentum of the falling chain. However, it is important to note that the force will vary depending on the length and weight of the chain, as well as the height from which it is dropped.
5. How does the mass of the chain affect the impulsive force?
The mass of the chain has a direct impact on the impulsive force. A heavier chain will have a greater change in momentum as it falls, resulting in a stronger impulsive force. This is why it is important to consider the weight of a chain when working with or handling it to avoid potential injuries.
