In a circuit, what causes current to go from L1 to L2?
In summary, the photograph above shows a simple 2 leg circuit of alternating current with a light switch and a light bulb. The current flows from one line to another based on the applied voltage from the power source, and a changing magnetic field can induce voltage in the circuit to cause charges to move. Current cannot flow in both directions simultaneously, and the direction of the current flow is determined by the polarity of the applied voltage.
fourthindiana
162
25
The photograph above this sentence is a photograph of a simple 2 leg circuit of alternating current with a light switch and a light bulb. I know how alternating current constantly switches direction from line 1 to line 2 and then goes from line 2 to line 1, etc. In the diagram in the above photograph, when the switch is closed, if the current goes from line 1 to line 2 first, what causes the current to flow from Line 1 through the switch and into the light bulb (lighting up the light bulb) and to Line 2? If the current goes from line 2 to line 1 first, what causes the current to flow from line 2 through the switch and into the light bulb (lighting up the light bulb) and to line 1?
I have a feeling that the answer somehow involves electron's attraction to positive charges, but I don't know how it would work since there are negatively charged electrons in both the wire of line 1 and line 2.
Is it the case that when you have a 2 leg circuit, one leg always has more electrons than the other and the current first flows from the leg with more electrons to the leg with less electrons?
The applied voltage from the power source.
Same answer. The applied voltage from the power source.
No separation of charges is necessary. A changing magnetic field can induce a voltage in the circuit, causing current flow, yet the electrons have no isolated positive charges anywhere in the circuit to be attracted to.
No, circuits don't work by changing the number of charges in one area as to attract/repel electrons. A change in the local electromagnetic field is generated by your power source in such a way as to cause charges to move. Explanations for this range from very simple (but very shallow) to extremely complex.
Likes fourthindiana
I don't know exactly what you mean when you say that a changing magnetic field can induce voltage in the circuit.
In the diagram in the attached photograph, is it the case that when the switch is closed, current will flow from Line 1 to Line 2 and current will flow from line 2 to line 1 simultaneously? If not, what determines whether the electrons will first flow from line 1 to line 2 or from line 2 to line 1?
https://en.wikipedia.org/wiki/Electromagnetic_induction
No. Current will only flow in one direction at a time.
The polarity of the applied voltage at the time you close the switch.
Likes Asymptotic and davenn
Related to In a circuit, what causes current to go from L1 to L2?
1. What is the definition of current in a circuit?
The flow of electric charge through a conductor is known as electric current. In a circuit, this flow of charge is typically driven by a voltage difference between two points, such as L1 and L2.
2. How is current measured in a circuit?
Current is measured using a device called an ammeter. This instrument is connected in series with the circuit and measures the amount of charge passing through a specific point per unit time.
3. What causes current to move from L1 to L2 in a circuit?
The movement of electric charge is caused by the presence of an electric field. In a circuit, this electric field is created by the voltage difference between L1 and L2. The charges in the circuit will flow from L1 to L2 in order to balance out this difference.
4. How does resistance affect the flow of current in a circuit?
Resistance is a measure of how difficult it is for current to flow through a material. In a circuit, materials with high resistance will impede the flow of current, while materials with low resistance will allow for a larger flow of current.
5. Can current flow in both directions in a circuit?
Yes, current can flow in both directions in a circuit. This is known as alternating current (AC) and is commonly used in household electricity. In contrast, direct current (DC) only flows in one direction and is commonly used in batteries and electronic devices.
  • Electrical Engineering
