In dealing with trigonometric substitution and integration
In summary, by using the substitution x = sec(theta), the limits of integration for the given integral are changed from sqrt(2) and 2 to pi/4 and pi/3, respectively. This can be derived by solving for theta in terms of x and then evaluating at the given limits.
Badgerspin
Here's the equation:
∫(sqrt(2),2) (1/(x^3*sqrt(x^2 - 1))
I have the entire indefinite integral worked down to this (using x = a*secø):
ø/2 + 1/4 * sin2ø
Now I have the answer book, so I know that's right so far. What I don't understand is how it converted the points of the integral. Where we started with the integral from sqrt(2),2. The book is telling me that the points now being worked with are pi/4, pi/3.
How did we go from sqrt(2), 2 to pi/4, pi/3 ? I don't understand where that came from. Beyond that, how do I derive those points in general? I'm the first to admit that anything involving trig is by and far my weakest aspect of calculus.
Any help would be greatly appreciated.
Try [tex]x=\sec\theta[/tex]
My problem is that I really don't know how they went from 2 to pi/3 and √2 to pi/3. I'm well aware of what substitution I needed to use. I have no idea what sec(ø) does to help answer this.
This is probably basic trig, but I'm finding that there are a lot of things in basic trig that I never learned that are now being applied in Calculus 2.
Your notation is a bit on the inscrutable side, but this is what I think you're working with.
[tex]\int_{\sqrt{2}}^2 \frac{dx}{x^3 \sqrt{x^2 - 1}}[/tex]
The limits of integration are sqrt(2) and 2.
ø/2 + 1/4 * sin2ø
If you make a substitution, including a trig substitution, in a definite integral, you can skip the step of undoing the substitution by changing the limits of integration.
With the substitution x = sec(theta), if x = sqrt(2), then theta = pi/4. If x = 2, then theta = pi/3. As a check, cos(pi/4) = sqrt(2)/2 = 1/sqrt(2) ==> sec(pi/4) = sqrt(2). Also, cos(pi/3) = 1/2 ==> sec(pi/3) = 2.
FAQ: In dealing with trigonometric substitution and integration
What is trigonometric substitution?
Trigonometric substitution is a technique used in integration to simplify complex algebraic expressions by replacing them with simpler trigonometric functions.
How do I know when to use trigonometric substitution?
Trigonometric substitution is typically used when the integrand (the function being integrated) contains a quadratic expression or a square root.
What are the most common trigonometric substitutions?
The most common trigonometric substitutions are:
- x = a sin θ for integrands with (a2 - x2)1/2
- x = a cos θ for integrands with (a2 + x2)1/2
- x = a tan θ for integrands with (x2 - a2)1/2
What are the steps to perform trigonometric substitution?
The general steps for performing trigonometric substitution are:
1. Identify the trigonometric function to substitute.
2. Substitute the function and its derivative into the integrand.
3. Simplify the new expression using trigonometric identities.
4. Integrate the simplified expression.
5. Substitute back in the original variable.
What are some tips for solving problems with trigonometric substitution?
Some tips for solving problems with trigonometric substitution are:
- Check for any restrictions on the domain of the function before substituting.
- Choose the most appropriate trigonometric substitution based on the form of the integrand.
- Simplify the expression using trigonometric identities before integrating.
- Check your answer by differentiating it to make sure it matches the original integrand.
