In Fermi V-A theory, where does the Weak Interaction occur
In summary, Fermi VA theory is an effective low-energy theory which treats the nucleons as elementary fields.
charlesmartin14
Where is the electron-nucleon interaction? On the surface of the nucleus, or at the origin (R-0) ?
Can you write down the interaction term or, even better the whole, Lagrangian density?
The Lagrangian contains a 'contact potential' , which Fermi assumed is a contact coupling of two vector currents. (prior to when parity breaking was discovered. This is now part of the Standard Model, in some cryptic form.
IMHO, you can not see it obviously in the Lagrangian until you specify the Dirac Spinors explicitly and evaluate the invariant matrix elements The Weak Interaction Hamiltonian element is
[tex]\mathcal{H}(x)=-\dfrac{G_{F}}{\sqrt{2}}\left[J^{\mu}(x)L^{+}_{\mu}(x)+h.c.\right][/tex]where
[tex]J^{\mu}[/tex] and [tex]L_{\mu}[/tex]
are (in modern parlance) the Hadron and Lepton currents, resp.,
The question is really how to evaluate the invariant matrix element -- at the surface of the nucleus, or at the origin ? That is, say, given some expression that appears in a cross section or a rate
[tex] \sum_{fi}\big\vert\mathcal{M}_{fi}\left[p_{ep}\rightarrow i\nabla)\right]\psi_{ep}(\mathbf{x})\big\vert_{\mathbf{x}=0}\big\vert^{2}[/tex]
or would we compute the electron density at the surface ?
for example, we do compute the rate of Electron Capture , a typical weak process, we can write the capture rate as
[tex]\Gamma_{EC}=\big\vert\Psi_{ep}(0)\big\vert^{2}\mathbf{v}^{in}_{ep}\sigma_{EC}[/tex]
where [tex]\big\vert\Psi_{ep}(0)\big\vert^{2}[/tex] is the electron density at the origin, representing the nuclear charge.
Or , again, should this be the charge on the surface of the nucleus ?
How would you define the „surface of the nucleus”?
Whatever the experimentalists tell me their best estimate it.
The nuclear radius can be estimated using a simple formula
[tex]R\sim A^{\frac{1}{3}}[/tex]
where A is the Atomic mass number.
I am asking how the Fermi VA theory is typically used in very detailed calculations.
Me neither, I have only seen a „finite nuclear radius” hypothesis only in a Dirac equation context (as a perturbative effect). AFAIK, it was described only in section 13.4 of Akhiezer and Berestetskiis book on QED. A finite nuclear hypothesis in case of a weak coupling is not known to me.
Likes charlesmartin14
Fermi theory is an effective low-energy theory which treats the nucleons as elementary fields.
To define a "proton radius" you need a context, how you measure it. One way is to use electron scattering, defining a charge radius. Another way is to consider the fine structure of the atomic hydrogen transition lines, also defining a charge radius. There's some "crisis" there, because measuring the charge radius with the transitions in muonic atoms, you get a different (smaller result). For a review, see this recent talk from our Nuclear Physics Colloquium:
http://th.physik.uni-frankfurt.de/~hees/np-colloquium/ss17/talk-gao.pdf
Related to In Fermi V-A theory, where does the Weak Interaction occur
1. What is Fermi V-A theory?
Fermi V-A theory is a mathematical framework used to describe the weak nuclear force, one of the four fundamental forces of nature. It was developed by Enrico Fermi and others in the 1930s and 1940s.
2. How does Fermi V-A theory explain the Weak Interaction?
Fermi V-A theory explains the Weak Interaction as a force that is responsible for radioactive decay and interactions between subatomic particles. It is mediated by the exchange of W and Z bosons between particles.
3. Where does the Weak Interaction occur in Fermi V-A theory?
The Weak Interaction occurs in the nucleus of an atom, between subatomic particles such as protons and neutrons. It is also involved in interactions between leptons, such as electrons and neutrinos.
4. How does Fermi V-A theory differ from other theories of the Weak Interaction?
Fermi V-A theory differs from other theories of the Weak Interaction in that it describes the Weak Interaction as a contact force, meaning that particles involved in the interaction must physically touch each other. This is in contrast to other theories that describe the Weak Interaction as a force acting at a distance.
5. What are some practical applications of Fermi V-A theory?
Fermi V-A theory is used in various fields of physics, including nuclear physics and particle physics. It has also been applied in other areas such as astrophysics and cosmology. Additionally, the principles of Fermi V-A theory have been used in the development of nuclear reactors and medical imaging techniques.
  • Quantum Physics
