In fluid mechanics what does pressure energy mean?
In summary: I can't think of the word...potential energy?...Pressure is still, in a certain sense, a form of potential energy. If you want to view it that way, then it is more akin to the potential energy in a compressed spring than it is to gravitational potential energy. Also like potential energy, it must be "expended" in order to increase the kinetic energy (in the form of dynamic pressure) of a flow.
Villa
In Bernoulli equation we use pressure energy... Pressure* volume gives the unit of energy... But what does this mean... If someone says it is potential energy per unit volume, then what does datum head refers to?... Please help... Can't go ahead without having thorough knowledge about this..
Pressure energy is simply pressure. Force per unit area, or energy per unit volume are just two ways to express the same thing.
Villa said:
If someone says it is potential energy per unit volume...
Pressure and potential energy per unit volume are related by Bernoulli's equation, but they are not the same thing.
[itex]P + 1/2*\rho*v^2 + \rho*g*h = constant[/itex]
Where:
[itex]P[/itex] is the pressure (energy/volume)
[itex]1/2*\rho*v^2[/itex] is the kinetic energy per unit volume
[itex]\rho*g*h[/itex] is the potential energy per unit volume
Have you dove to the bottom of a pool before? If so, you've experienced the exchange of potential energy for pressure energy. The water at the bottom of the pool doesn't have the same potential energy as the water at the top, but it is at a higher pressure.
The head form of Bernoulli's equation simply divides through by density * force of gravity. This leaves the equation in units of length. For why that's called the head form, I'll defer to someone more knowledgeable.
I think you are referring to the thermodynamic pressure, due to the movement of air molecules. The kinetic and potential pressure energies are just due to the net velocity and relative height of a fluid respectively.
jackwhirl said:
Pressure energy is simply pressure. Force per unit area, or energy per unit volume are just two ways to express the same thing.Pressure and potential energy per unit volume are related by Bernoulli's equation, but they are not the same thing.
Where:
Where:
U can see that in the equation u have written...the pressure energy (P) and potential energy (ro*g*h) are the same...isnt it?...really confused
P
please elaborate more...with the spring as eg.
Are thermodynamic pressure and hydraulic pressure different??
I am not really sure how much more elaborate I can make this. Bernoulli's equation is a conservation of energy statement. The ##\rho v^2/2## term (dynamic pressure) is kinetic energy, the ##\rho g z## term (hydrostatic pressure) is the gravitational potential energy, and ##p## (static pressure) is sort of like spring potential energy in the sense that it comes from a bunch of moving molecules being in some space together and as you relax how much it is compressed, the pressure goes down and is transferred into some other sort of energy. In the case of a flow that is subject to Bernoulli's equation, that other form of energy is either kinetic or gravitational depending on the system.
I understand your confusion. No, they are not the same. However, they are closely related.
Imagine a column of water 10 meters tall open to the atmosphere. Assume zero velocity and incompressible (water is very nearly incompressible.)
With no velocity, the kinetic energy portion will drop out and leave:
[itex]P + \rho*g*h = constant[/itex]
Now image two points in the water; point one at the top and point two at the bottom. You can use the reduced Bernoulli's equation to describe their relationship.
[itex]P1 + \rho*g*h1 = P2 + \rho*g*h2[/itex]
For the h terms, h1 is 10m and h2 is 0m (at the bottom of the column.)
This leaves you with:
[itex]P1 + \rho*g*10 m = P2[/itex]
Now, because point one is open to the atmosphere we know that P1 (the static pressure at point one) is equal to about 101 kPa (atmospheric pressure) or more usefully, zero gauge. Taking the second option (0 gauge pressure) leaves this:
[itex]\rho*g*10 m = P2[/itex]
So you can see that the static pressure at the bottom of the column is equal to the potential at the top of the column.
For the sake of completeness:
[itex]P2 = \rho*g*10m = 1000 kg/m^3 * 9.81 m/s^2 * 10 m = 100kPa (gauge) [/itex]
If you are calling "pressure energy" P*V in the Bernoulli equation, then you should be using the form of the Bernoulli equation expressed in terms of ##P/\rho##. This quantity has units of energy per unit mass, and is equal to the pressure times the volume per unit mass. If you have a fixed specified control volume, then, from the open system version of the first law of thermodynamics, ##P/\rho## at the exit of the control volume represents the amount of work required to push a unit mass of fluid out of the control volume against the back pressure of the downstream fluid. ##P/\rho## at the entrance to the control volume represents the amount of work required to push a unit mass of fluid into the control volume by the forward pressure of the upstream fluid. If you want to call these quantities "pressure energy," knock yourself out.
Cht
Related to In fluid mechanics what does pressure energy mean?
1. What is pressure energy in fluid mechanics?
Pressure energy in fluid mechanics refers to the energy that is associated with the pressure exerted by a fluid. It is a form of potential energy that is stored in the fluid due to its pressure, and can be converted into other forms of energy, such as kinetic energy, as the fluid flows.
2. How is pressure energy calculated in fluid mechanics?
The calculation of pressure energy in fluid mechanics depends on the properties of the fluid, such as its density and pressure. It can be calculated using the equation: PE = (P/ρg), where PE is the pressure energy, P is the pressure, ρ is the density of the fluid, and g is the acceleration due to gravity.
3. What is the importance of pressure energy in fluid mechanics?
Pressure energy is an important concept in fluid mechanics because it helps us understand the behavior of fluids and their ability to do work. It is also a key factor in many engineering applications, such as pumps, turbines, and hydraulic systems.
4. How does pressure energy affect the flow of fluids?
Pressure energy plays a significant role in the flow of fluids. As a fluid flows from a high pressure area to a low pressure area, the pressure energy decreases and is converted into kinetic energy, which increases the fluid's velocity. This is known as the Bernoulli's principle.
5. Can pressure energy be converted into other forms of energy?
Yes, pressure energy can be converted into other forms of energy, such as kinetic energy, thermal energy, and electrical energy. This conversion is the basis of many fluid mechanics applications, such as the generation of electricity from hydropower plants.
  • Mechanical Engineering
