I In Freefall orbiting Jupiter versus Earth
An astronaut in freefall around Jupiter, like one around Earth, does not feel their weight due to the absence of a normal force acting on them. Despite Jupiter's strong gravitational pull, the astronaut would not experience biological effects from this gravity while in freefall, as they would not feel the weight unless they were in contact with a surface. The significant gravitational force is uniform across their body, preventing any internal stress or strain that could be measured. Tidal gravity, which occurs when there is a differential gravitational force, would only be notable if the astronaut were on a surface or if larger bodies were involved, such as Earth falling toward Jupiter. Thus, in freefall, the astronaut would feel weightless regardless of the planet's gravity.
Albertgauss
TL;DR Summary
Jupiter g ~ 25 Would you feel it?
I know that in Earth, an astronaut feels weightless in orbit but actually is not. The astronaut would not feel his own weight until he actually stands on a floor where his feet point towards the Earth as the Normal Force is the perception of weight.
So, in Jupiter, where g ~ 25, an astronaut in freefall also would not feel their own weight. However, does that mean there would be no biological effects despite the increased gravity?
I have heard it said that a person who normally has a weight of 600 Newtons on Earth would then weigh ~ 1500 Newtons on Jupiter, enough to have a heart attack since a normal heart could not pump blood through such excess weight. But if the person is in freefall in Jupiter, this would not happen as they would need to have their feet on the surface of a ship to feel this 1500 Newton. Is this correct?
Please ignore everything else about Jupiter except for what is the discussion here. I am well aware of all the problems of falling into Jupiter, just had a question of this one detail.
Let's stick to the classical theory of gravity. There is a significant gravitational force acting when you are in freefall. But, because the force is the same on each particle, there is no additional internal stress or strain that would enable you to measure the overall gravitational force. For that reason, you would feel nothing, whether it's Jupiter or the Earth.
The only time you would feel anything is if the differential in gravitational force between, say, your head and feet was large. This will be negligible for a planet even the size of Jupiter. This is called tidal gravity, and it's this difference in the Moon's gravity between one part of an ocean and another that causes the tides. If, say, the Earth was falling towards Jupiter, then this tidal gravity between the part of the Earth that was closest to Jupiter and the part that was furthest away would be significant and the Earth would be stretched as a result.
Likes vanhees71 and russ_watters
Sounds good. I see where I was getting confused. Consider this answered.
Likes vanhees71, Dale and berkeman
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
