In order for something to be conductive?
  • Thread starter LogicalAcid
In summary, the conversation discusses the concept of electric charge and current. The flow of charge is known as current and it is necessary for charges to move into something else. The movement of electric charge is similar to a river, where the amount stays the same at any given position. Negative charges repel each other and diffuse. In order for charges to move, they need a way to flow away from each other. The current is also dependent on the material through which it is observed, with conductors having loosely bound electrons that are easily moved.
LogicalAcid
137
There has to be flow of charge, right? And that is current? Something can have very high voltage, which is a lot of electric charge (notice the question marks), but if it has no current, the charge won't flow into something else. This is what confuses me, first of all, how does electric charge flow? I know every charged particle has a charge, and proto has a plus one charge, an electron has a minus one charge. But how does electric charge move, what exactly has to happen to make charges move?
It's like a river. Even though there is flow, the amount (water level in the river) stays the same at any given position.
If you bunch up a lot of negative charges together, they don't like it because they repulse each other and they diffuse. So if they have some way to flow away from each other, they do. Then you have a current.
I think it should also be mentioned that the current is also dependent on the material through which you are observing a current.
Typically when you run a current through a wire it is a conductor. In materials that are conductors there are electrons that are only loosely bound to the nucleus of any given atom. What this means is that the protons attractive force in a conductor is not very strong in relation to these essentially "free" electrons.
Yes, in order for something to be conductive, there must be a flow of charge. This flow of charge is what we refer to as electric current. Voltage, or electric potential difference, is a measure of the potential energy of the charges in a circuit. However, in order for the charges to actually move and create a current, there must be a complete circuit for the charges to flow through. This circuit can be created by connecting conductive materials, such as wires, to a voltage source.
Electric charge can move through a conductor, such as a wire, due to the presence of free electrons. These free electrons are able to move through the material and carry the charge with them. When a voltage is applied, the electric field created by the source pushes the free electrons in the direction of the positive terminal, creating a flow of charge or current.
In summary, for electric charge to flow and create a current, there must be a complete circuit, conductive materials, and a voltage source. The movement of charge is facilitated by the presence of free electrons in the conductor and the electric field created by the voltage source.
FAQ: In order for something to be conductive?
What does it mean for something to be conductive?
Conductivity is the ability of a material to allow the flow of electrical current through it. This is due to the presence of free electrons that can easily move through the material.
What factors determine the conductivity of a material?
The conductivity of a material is determined by its atomic structure, temperature, and impurities. Materials with a higher number of free electrons, lower temperature, and fewer impurities tend to have higher conductivity.
How is conductivity measured?
Conductivity is typically measured using a device called a conductivity meter, which measures the amount of electrical current that can pass through a material. The unit of measurement for conductivity is siemens per meter (S/m).
What are some examples of highly conductive materials?
Metals, such as copper, silver, and gold, are known to be highly conductive materials. Other examples include graphite, which is used in pencils, and saline solutions, which are commonly used in science experiments.
Why is conductivity an important property to consider?
Conductivity is an important property to consider because it affects the efficiency and safety of electrical systems. Materials with low conductivity may cause electrical resistance and generate heat, potentially leading to malfunctions or hazards. In addition, conductivity is an important factor in the design and development of electronic devices.
