In what way are computer science and physics related?
In summary, Quantum computing and quantum information are very interesting fields, but the CS "component" is at the moment very small. Most of the work on quantum computing and QIP is experimental and the theorists in the field are almost exclusively working on particular implementations. It is actually quite difficult to do meaningful work unless you specify the system. There is a potential overlap between physics and computer science in that programming is important for both fields, but this is not computer science as the study of algorithms. Quantum programming languages exist, but you do not have to know quantum mechanics to use them. Knowing quantum mechanics will not help you design a quantum algorithm. It might be worth pointing out that computing skills
Niaboc67
249
I am considering a dual-major in Physics and Computer Programming. But i'd like some input on how the two can be used together first. What are your thoughts and opinions on a majoring these two? How might this be useful/practical in the real world and how might it be impractical.
Thank you
Quantum computing and quantum information. Exciting and interesting field in the intersection of Physics and Computer science.
But the CS "component" of quantum computing is at the moment very small, there are only handful of people in the world working on e.g. "general" algorithms; most of the work on quantum computing and QIP is experimental and the theorists in the field are almost exclusively working on particular implementations; it is actually quite difficult to do meaningful work unless you specify the system, and if you do that you are essentially doing theoretical physics, concepts from CS are rarely important.
Hence, I don't think QC or QIP would be a good reason for choosing a double major.
Likes ShayanJ
Electronics and communication engeneering... i like building robots. so you need to know programming and good knowledge in circuits.
The computer is arguably the physicists most important tool. Programming is done in every field of physics and computers are used for both theory and experiment.
Likes Jakeness, ellipsis, ShayanJ and 2 others
Interesting input guys. So many interesting fields so little time...
I am really fascinated by electrical & computer engineering as well seems there would be a overlap with physics as well in there.
Programming is extremely important for physics*, but programming isn't computer science. Computer science, as the study of algorithms, operating systems, compiler design, etc... has extremely little to do with physics.
I have a passion in both, but...
The highest physics you would likely use in computer science is basic kinematics and calculus (to design a physics engine for a game).
The highest computer science you would likely use in physics is programming (to model a simulation).
To address QM mentioned earlier: Quantum programming languages exist, but you do not have to know quantum mechanics to use them. Similarly, knowing quantum mechanics will not help you design a quantum algorithm. Also, it's difficult and different from most programming - not something most CS work with. Look up a tutorial.
It might be worth pointing out that computing skills are one of the major marketable skills that physics majors use to get jobs in the real world once they are finished with academia (at whatever stage).
@ellipsis any projects or past projects that you'd care to share with us? I'd like to hear what sort of endeavors you've gotten to into so I know what to expect.
@Choppy everything nowadays seems to revolve around computers. It was my first inclination to get into programming for financial reasons but I soon began get a knack for it. Now i'd like to make a career out of it. My interests are so broad in the sciences. It's hard to just stick to programming I want to overlap into other fields like physics, engineering, electronics.
Niaboc: I was actually on PF today to ask a question about a personal project. Namely, orbital simulation using polar coordinates. If you've ever heard of a game named "Kerbal Space Program", it's about that - I'm interested in what the optimal ascent profile for a given rocket is. My 1D models work (emulating a rocket going straight up, with dynamic gravity and drag), but I'm having trouble implementing vectors correctly... never took vector calculus.
An old project of mine was using search algorithms (and the Quine McCluskey algorithm) to find the minimal representation of truth tables as digital circuits (logic gates including ANDs, ORs, XORs, etc...). I didn't completely solve the problem to my satisfaction, but I got a number of interesting results. For example, you can use that method to generate gate-minimal circuits, like a seven-segment-decoder in 27 logic gates. The closest thing I've seen to this is superoptimization, where you iterate through every possible machine instruction until you find the shortest that matches your specified function. The problem with both is that proving optimality is NP. Also, the generated circuits are completely incomprehensible to a human.
Then there was that time I compiled a list of 'mathematical cheat codes'... things like defining a function such that f(x) = 1 when (x==5) but f(x) = 0 when (x!=5) using only the operations we normally use in math. This turns out to be f(x) = 0^abs(x-5). If you wanted a function such that it outputs 1 iff x > 5, you could use (tanh(1000(x-5))+1)/2. There's a bunch like that, but it isn't too useful unless you have to bound functions within their expressions for some rare reason. And of course, when you do need to do it, you will forget how.
There's a few others things I've done. This is all stuff done of my own volition, though. The things a college (or business) will ask you to do are much less interesting. That would consist of writing a few template-based classes in C++ to demonstrate knowledge of object-oriented nonsense.
I hope I answered you question, and didn't bore you!
PS: Oh, you're the guy from the other thread too. That's the second thesis you've evoked from me.
FAQ: In what way are computer science and physics related?
1. How are computer science and physics related?
Computer science and physics are closely related in many ways. Both fields involve the study of patterns and systems, and use mathematical models to understand and solve problems. Additionally, computer science heavily relies on principles of physics, such as electricity, magnetism, and optics, to develop and improve technology.
2. Can computer science be considered a branch of physics?
While there are certainly overlaps between the two fields, computer science is not considered a branch of physics. Computer science has its own distinct principles, theories, and applications that make it a separate discipline. However, the two fields do complement each other and often work together in various areas, such as data analysis and computational modeling.
3. How does computer science contribute to advancements in physics?
Computer science has greatly contributed to advancements in physics by providing powerful tools for data analysis, simulations, and modeling. With the increasing complexity of experiments and data in physics, computer science has become essential in processing and interpreting this information. Additionally, computer simulations have allowed physicists to study complex systems and phenomena that are difficult or impossible to observe in real life.
4. How has the use of computers changed the study of physics?
The use of computers has greatly impacted the study of physics in many ways. Firstly, it has allowed for more efficient and accurate data collection and analysis, allowing physicists to make new discoveries and advancements. Secondly, computers have enabled the development of sophisticated simulations and models, giving researchers a better understanding of complex systems and processes. Lastly, computers have also made it possible to share and collaborate on research globally, accelerating the pace of scientific progress.
5. What career opportunities are available for those interested in both computer science and physics?
There are many career opportunities available for individuals with a background in both computer science and physics. Some popular options include working as a data scientist, software engineer, or research scientist in fields such as artificial intelligence, robotics, or computational physics. Additionally, graduates with a dual degree in computer science and physics are highly sought after in industries such as finance, healthcare, and energy, where advanced technology and data analysis are crucial.
