In what ways do high altitudes affect speed of sound?
In summary, at high altitudes, lower temperatures slow down the movement of gas molecules, making it more difficult for sound to travel through the medium. The formula ## c_s = \sqrt (\frac{\gamma*k*T} {m}) ## indicates that the mass of gas molecules is a factor in determining the velocity of sound. Increasing the mass of gas molecules will decrease the velocity of sound due to their higher inertia.
Clueless
This is what I am pondering about: At high altitudes, it makes sense that lower temperatures will correspond with velocity of sound traveling through the air at higher altitudes. With lower temperatures the movement of the gas molecules will slow down, making it more difficult for sound to travel through this medium (I am aware that I might be too general in my explanation).
But a formula I came across - ## c_s = \sqrt (\frac{\gamma*k*T} {m}) ## - where ## \gamma ## is the adiabatic exponent, ## k ## Boltzmann's constant, ## T ## the temperature, and ## m ## the mass, seems to indicate to me that there is another variable, ## m ## to consider.
So how could mass of the air affect sound's velocity as it passes through? I don't know. I suppose the mass of the air correspond with the number of air molecules as well as what the air is made up with. Does increasing the number of air molecules decrease the speed of sound? If so, how? Do more particles make it more difficult for energy to travel? If so, why?
PS I apologize if I am asking way too many questions...please tell me so if this is the case!
In your equation, m is the mass of a gas molecule. You could have found that out by looking up "speed of sound" on Wiki. It took me less time to do that than it did for you to write out your question.
Chet
Chet
My goodness...that was a daft thing to do on my part :wink: Made things much clearer but I would like to clarify...
So increasing the mass of gas molecules will decrease the velocity of sound because heavier particles (intuitively and by Newtonian mechanics) would need have the same velocity as lighter particles if both are given the same energy?
I have no idea what this means. More massive molecules have more inertia than less massive molecules, and require more force to accelerate.
Chet
Related to In what ways do high altitudes affect speed of sound?
1. How does air density at high altitudes affect the speed of sound?
As altitude increases, air density decreases. This means that there are fewer molecules in the air to transmit sound waves, resulting in a decrease in the speed of sound.
2. Does temperature have an impact on the speed of sound at high altitudes?
Yes, temperature does have an impact on the speed of sound at high altitudes. In general, as temperature increases, the speed of sound also increases. However, at extremely high altitudes where temperatures are very low, the speed of sound can actually decrease due to the decrease in air density.
3. How much does the speed of sound decrease with each increase in altitude?
The decrease in speed of sound with each increase in altitude varies depending on factors such as air temperature and humidity. On average, the speed of sound decreases by about 1% for every 330 meters increase in altitude.
4. Why does the speed of sound decrease at higher altitudes?
The speed of sound decreases at higher altitudes because there are fewer molecules in the air to transmit the sound waves. This results in a decrease in air density, which in turn affects the speed at which sound can travel.
5. How does the speed of sound at high altitudes affect aircraft travel?
The decrease in speed of sound at high altitudes can affect aircraft travel in several ways. It can result in a decrease in engine performance, as the engines need to work harder to produce the same amount of thrust. It can also affect the efficiency of communication systems, as sound travels slower and can cause delays in communication between pilots and air traffic control. Additionally, this decrease in speed of sound can also lead to changes in the aerodynamics of the aircraft, which can impact its overall performance and stability.
  • Mechanics
