In which direction a spherical particle moves under torque?
In summary, we are considering a small rigid spherical particle immersed in a viscous incompressible fluid with a hard-wall boundary condition. A positive external torque is applied to the particle, leading to motion in the y direction due to hydrodynamic interactions. However, calculations and intuition suggest that the motion should be in the opposite direction, and further analysis is needed to determine the cause of this discrepancy.
Eric
Consider a small rigid spherical particle of radius a, fully immersed in a viscous incompressible Newtonian fluid of shear viscosity η above a hard-wall with stick (no-slip) boundary conditions, located at the plane z = 0. A constant positive (external) torque Tx is applied on the particle.
My question is:
Assuming low Reynolds number hydrodynamics, the particle will move along the y direction due to hydrodynamic interactions. But, does the velocity along y have a positive or negative sign?
Any help would be highly appreciated.
Thank you
Eric
You need to tell us how the torque is oriented relative to the no-slip plane. Maybe you're trying to do that by calling the torque "Tx". Do you mean the torque is parallel to the x direction, and pointing in the positive x direction? This would make the bottom of the marble want to move toward +y and the top of the marble want to move toward -y, since positive torque is counter-clockwise.
Likes Eric
Thanks for your reply.
Here the torque is oriented in the positive direction (contour-clockwise) leading to particle motion in the y direction due to hydrodynamic interactions.
Also the wall is stationary (fixed). My calculations lead to motion in y+ while intuitively one would rather expect hat the particle will move in y- (analogy with a particle rolling on a wall) I am totally confused..
It would be great if you could please provide with some hints that may help a bit to figure out what is going on.
Thank you
E
I agree with your intuition. Motion should be in -y direction. I don't think you can solve Navier Stokes very easily by hand in this geometry... what calculations are you doing?
Likes Eric
Here only the Stokes equation are solved (nonlinear term is dropped out). The mobility calculations are used, see e.g. Swan,[/PLAIN] J. W. and Brady, J. F., Phys. Fluids 19, 113306 (2007)
Likes dreens
Wow that's an interesting paper. I'm impressed that this can be solved, even for a pair of particles as in the appendix. I don't have the heart to look at it closely enough to try and figure out why the math is giving you the wrong sign. Not that it's worth more than two cents, but I'll bet 90:10 odds that the sign error lies somewhere in the math or your implementation of it, and not that the particle really rolls backward when you torque it near a wall.
If you really need a faith boost before you start hunting back through your math, maybe try this out with a xylophone mallet (sphere with attached stick so you can torque it) and a bowl of syrup haha.
Likes Eric
Thanks dreens for your helpful insights. The equation stated above corresponds to Eq. (B2) of Swan's paper (the RT tensor is the transpose of TR tensor) and clearly the sign is positive, i.e. counter-intuitively (The equation seems to be a known result and it was first derived by Goldman some decades ago [Slow viscous motion of a sphere parallel to a plane wall- I Motion through a quiescent fluid, Chem. Eng. Sci. 1967]) I will think about it
Thanks again
Kindest regards,
Er
Related to In which direction a spherical particle moves under torque?
1. What is torque?
Torque is a measure of the rotational force that is applied to an object. It is calculated by multiplying the force applied to the object by the distance from the axis of rotation.
2. How does torque affect the movement of a spherical particle?
Torque causes a spherical particle to rotate around its center of mass. The direction of rotation depends on the direction of the applied torque.
3. Does the size of the spherical particle affect its movement under torque?
Yes, the size of the particle does affect its movement. A larger particle will require more torque to rotate it compared to a smaller particle.
4. Can a spherical particle move in a straight line under torque?
No, a spherical particle will always rotate when torque is applied to it. This is due to the symmetry of the particle and the direction of the applied force.
5. How does the direction of the applied torque affect the movement of a spherical particle?
The direction of the applied torque determines the direction of rotation of the particle. If the torque is applied in a clockwise direction, the particle will rotate in a clockwise direction, and vice versa for counterclockwise torque.
  • Other Physics Topics
